Question about Acer Aspire Computers & Internet
My laptop suddenly offs automatically... When I swith on my laptop it normally work... but after some time it turns to off automatically... even though when I am working in dat particular time.
  • chandaravite
    chandaravite Jan 15, 2013
    But how can I open my Laptop with out a proffessionnel..?
  • Acer Master
  • 5,660 Answers
A) You may have your Power Settings set to turn off at a specified amount of time.
However I doubt this is the case.
Why?
Most of the time when this problem occurs with a laptop, it's because it is dirty inside.
If you have never had the laptop cleaned inside, and have had the laptop for some time; this is probably the problem.
The hardware components inside a laptop are cooled by air.
The Processor and graphics chipset, are the two hardware components that give off the most heat.
When a Processor overheats, (Exceeds it's thermal limit), it turns off.
(BIOS turns it off)
This is a fail safe feature built-in. Keeps the Processor from burning up. (Literally)
Let me show you an average laptop that is dirty inside, chandaravite,
http://www.youtube.com/watch?v=AkAeE5I5E_A
The example is using a model of Dell XPS 1710 laptop.
It's cooling system is similar to yours.
The copper colored flat curved tubes you see, are Cooling Tubes.
They are a slightly flattened copper tube, sealed on both ends, and filled with Nitrogen.
Here is a better look,
http://www.txcesssurplus.com/servlet/the-4182/Dell-XPS-M170-M1710/Detail
This example is upside down, in relation to the example in the video.
The X shaped metal plate you see, with four mounting screws in it's corners, is the metal plate that sits on the Processor.
Heat is absorbed from the Processor by that metal plate. The Cooling Tube then absorbs heat from the plate.
Heat is then transferred up to the Heatsink, at the far right.
That black Heatsink is rectangular in shape, and composed of Tall, Thin fins.
The Heatsink absorbs heat from the Cooling Tube, then radiates the heat away with the Tall, Thin fins.
What you don't see attached in the video, is the Fan Assembly.
The Fan Assembly draws air from the bottom of the laptop, (With most models), then pushes air out through the fins of the Heatsink.
The air flow helps carry heat away from the fins of the Heatsink.
This particular laptop also has a separate Cooling Tube, for it's graphics chipset.
The bottom of a laptop is in VERY close proximity to the object it is resting on. Table, or hard surface.
(Not supposed to be on your lap, bed, couch, or directly on a carpet floor. BLOCKS the air intake OFF. Makes the laptop overheat)
The air intake of the laptop at the bottom, or at the side; will draw in a lot of 'Gunk'.
Gunk = Dirt, dust, hair, carpet deodorizer, lint, food crumbs,......you name it.
As you can see in the video, the 'Gunk' has formed a thick wad, and blocked off the fins of the Heatsink.
The cooling capacity has dropped Tremendously.
It is my humble opinion, that this may be what is going on with your laptop, also.
Do you wish to attempt cleaning? If so I need the model number, and see what information I can come up with.
Perhaps pictorial guide/s, and of course step by step info from me.
The model number is on the bottom of the laptop.
Post back in a Comment.
It could be also that the Thermal Paste has dried up.
This is used to help transfer heat from the top of the Processor, to the metal plate on the Cooling Tube.
Thermal Paste MUST always be used.
There also may be a Thermal Pad on top of the graphics chipset.
This is a semi-spongy type of material, that is impregnated with Thermal Paste.
A Thermal Pad CANNOT be reused.
Regards,
joecoolvette
Posted on Jan 14, 2013
  • joecoolvette
    joecoolvette Jan 15, 2013
    It may be that I can find a free Service Manual to give to you, and perhaps also pictorial guidance. Plus me.http://www.fixya.com/support/t15656727-h...
  • joecoolvette
    Is it an Acer Aspire? OK. Now I need the model number. This can be found on the bottom of the laptop.
It might be because your computer is overheating. Try installing Speed-Fan in order to check the temperature values your computer reaches. Also try cleaning the heatsink. you might want to consult the Hardware Maintance Manual of your computer.
Posted on Jan 15, 2013
3 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Frequent interrruptions
Initially, I would suspect the battery (even when plug to the AC). To confirm, pls try running without the battery and purely on AC adapter. Alternately, it could be a loose component internally such as the memory, LAN or WiFi card and in some models, video card. In my Toshiba, it turned out that the WiFi was consuming too much power that it discharges the battery rapidly and the charger was having a hard time coping up. My solution was to turnoff the built-in WiFi and install a D-Link USB.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 15, 2008
bunnydawg
  • 5158 Answers
SOURCE: hi my laptop will turn
it may be shutting off due to thermal shutdown... basically the fan isn't keeping the cpu cool enough... check to make sure the fan is running and that the fan/cpu heatsink is clear of dust and dirt.
Robert
Posted on Dec 22, 2008
Dell 3537 laptop my vga adapter was changed but after that my laptop swithed off suddenly , sometimes it swithes on most of the time not switching on
Hello there
First things first:
1) perhaps its a bad VGA piece componet, or damage.
2) it will be connecting bad, on the mobo, or soldering
3) the swith for VGA and onboard its bad, or need to be check.
4) other than these, verify with your tech near you! for the VGA mode or inverter mode to VGA/Onboard .
Good Luck
Carl
Apr 24, 2017 | Dell Computers & Internet
Slow booting and sudden switch off
The reason may be one or more problems acting together. The problem nowadays is that it is very difficult and time consuming to monitor and take care of your Lenovo laptop. Even experienced users find it hard to perform such tasks on regular basis because you might need to prepare a huge amount of time and energy to deal with each issue separately.
If you want to fix the problems more efficiently, try the Lenovo speed up program. Regards!
Aug 02, 2012 | Lenovo 3000 Y500 7761 Laptop AC Power...
My dell inspiron 1501 does not swith ON is this due to motherboard problem
There could be problem with motherboard. But before that can check with a different battery(fully charged).
Jan 18, 2012 | Dell Inspiron 1501 Laptop
Black screen with flashing horizontal lines
it can be the fibre or someone pressed the screen on the topside or plced something heavy on it
Apr 14, 2017 | Compaq Presario C700 Series Laptop...
Audio window comes on and off on its own
problem with moniter front panel MENU swithes.Replace all the swithes on the front panel.
If one swith is problem, automatically on or off will happen on its own.
This solution wil be the same even if brightness or contrast control will vary on its own!
Dec 10, 2010 | HP W19b LCD Monitor
The troubleshooter says that my wireless capability is turned off. It was working all last night and just randomly quit working.
You have to find the wireless switch because your swith is somehow turned off.
If that does not works go to
Device manager (Right click my computer go to properties, under properties go to hardware and then to device manager) and then uninstall the wireless drivers. Then restart the computer give your computer some time so that it can reinstall the drivers automatically.
99% it will help
Jul 10, 2010 | HP Pavilion dv6000z Notebook
White Screen Problem while starting Acer Aspire 2710z laptop
Unfortunately it sounds like bad memory. Depending on your memory configuration you can try swithing out memory sticks. Check with your manufacture about memory configuation requirment before trying this. If you're unsure how to do this it's best to take it to someone who does know how.
Mar 25, 2010 | Computers & Internet
I have automatic headlights in 2005 Silverado. I
turn headlight swith to the parking light position...press the spring loaded buttons 4 times quickly and you should go into overide lights
Dec 21, 2009 | Chevrolet Silverado 1500HD Cars & Trucks
My nokia 6600 swith off automatically
There can be many reasons for which you are having this problem
  • Faulty battery (battery dead discharging slowly)
  • The display is damaged .
  • Certain virus in the mobile can cause this problem . If so you need to reset your mobile .
Jan 30, 2009 | Nokia 6600
Ps3 wont turn back on
if you cant get your disk out of your ps3 turn off in back of console hold down the power button with the eject button at the same time turn on the console in back while holding both buttons keep holding until disk ejects might take few times
Oct 20, 2007 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
