Question about Mitsubishi WD-65C9 65" DLP HDTV
Picture starts out dark then gets lighter after a couple of seconds
How to get a clear picture?
The brightness control makes the dark bit of the picture lighter.
Sep 10, 2014 | Sony BRAVIA Televison & Video
Delay in lighting from dark to light scenes and then back.
Look for auto-contrast or something. Turn it off. Picture will be steady. I hate this feature in most flat panel tv's and it's not needed. You may have to set static contrast after that.
Jan 30, 2014 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Turns on dark and then gets lighter
ic circuit is the problem, see TV Tech.
Nov 09, 2013 | RCA F32650 32" TV
Picture "flickers" from dark to a lighter
This is a board level fix.
The part is about $10. + time to solder on the part
Capacitor C809 is failing.
390mfd @250V
Mar 05, 2011 | Proscan 42LA30H 42 in. LCD Television
Philips 50" rear projection- Washed out picture.
You need to change the CRT Fluid. This is a common problem on the  older projection TV sets.
You can get the fluid and instructions on how to change it from www.TvRepairKits.com.
Dec 19, 2008 | Philips 9P5034C 50" Rear Projection...
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Espresso is dark and rich at first; then shifts to water
This is suppsed to happen, every espresso machine out there on the market does this.
All the taste for the coffe comes in the first couple of seconds and after that it gets less and less.
So the problem is not that it gets lighter and lighter, but that you dont get enough taste in the start of the brewing.
And this can be caused by alot of things.
Bad beans?
Not set the grinding to fine?
it will not heat enought and thereby not get enough taste.
etc.
Apr 12, 2008 | Saeco Talea Giro Espresso Machine
Problems recording VHS
hi bro i guss u have to buy new dvd not the rental one might have code on it for recording (copy right ) so u can't record
sorry
Dec 29, 2007 | JVC HR-S9600 S-VHS VCR
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Dark pictures
You did not say what sensitivity setting you had the camera set at- the higher the sensitivity the lighter the picture. Actually- all the image information is there so all that needs to be done is to edit the image lighter in a graphics editing program[You did say whether or not you import images to a computer] Come back back with more info on what you do with the images.
Apr 27, 2007 | Olympus Camedia C-3020 Zoom Digital Camera
Mitsubishi WD-65C9 65" DLP HDTV Logo
57 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
