Question about youtube.com
Where timeing marks are on 1.2 cleo
Not sure were they are located
    Problem Solver:
  • 18 Answers
) there are two timings marks, one on the crankshaft, the second is on the camshaft pulley, it's the rectangular one next to the e1-e3 lettering (i think) and aligns at roughly 12 o'clock again the corresponding mark is likely on the rear cover.
If you align up the camshaft pulley timing marks then look for the crank shaft pulley marks before takin off the belt these will be aligned up at TDC.
Well worth usin some crayon on the pulleys and where the marks are just incase you lose sight of them not that you should
Posted on Jan 14, 2013
Spark@fuel,new timing belts,but it will not start.1988 subaru wagon 1.8
If you have Spark and Fuel There is only two things that
will be the problem.
1.
Start CRYING the timing marks were not properly aligned
when the belts were installed.
2.
The Distributor is not installed with the rotter
pointing to the number 1 sparkplug wire terminal with the number 1 piston at
top dead center, and on the compression stroke. Compression stroke means the
intake and exhaust valves are both closed and the piston is at the top of the
cylinder. To get the piston in proper location at the proper time, remove the
number 1 sparkplug use the starter and just bump the starter until the timing
mark on the harmonic balancer is located close to the timing tab mounted on the
engine. To get the balancer mark to line up with the the timing tab, don't
crank the engine just bump the starter each time so the balancer mark only rotates
a short distance at a time. With the balancer mark close to the ZERO point on
the tab take a stiff long peace of wire, I say long wire, I mean one that will not
fall down in the cylinder to where it can't be retrieved without removing the cylinder
head. Use the wire to feel inside cylinder to see if the piston is at the top
of the cylinder. If it isn't rotate the balancer one revolution and feel for
the piston again. When the piston is at the top with the mark on the balancer aligned
with the tab on the engine, remove the distributor cap locate the number 1
sparkplug wire tower on the cap replace the cap on the distributor making sure
it sets down properly the cap has a tab made on the mounting edge that mates
with a notch in the distributor housing. Make sure they line up. Note the
location where the number 1 sparkplug tower is located you can use a peace of
chalk an make a mark on the side of the distributor housing indicating where
the rotter should point to. Before removing the distributor housing from the
engine notice where the vacuum canister is pointing so when the distributor is
properly timed the canister will be pointing in the same location. Make sure
the distributor gasket is in place before installing the distributor. When installing
the distributor the rotter will rotate in the distributor housing as it is
inserted in the Cam Shaft Gear, on some automobiles there is only one place the
distributor will completely go in to the distributor hole and let the base of
the distributor mate up with the top of the hole surface. If the rotter is not
pointing to the proper place continue removing and turning the rotter a little until
when the distributor is properly seated the rotter is properly alighned. Continue removing and installing the distributor
until the rotter points to the mark you made on the distributor housing and at
the same time the distributor housing is setting on the gasket not about a
quarter of a inch from bottoming out.
Oct 30, 2013 | Mr Gasket Timing Cover Chevrolet El Camino...
Fold down
You can find product instructions for the Graco Cleo - and how to fold it - here: http://www.gracobaby.com/CustomerService/ProductInstructions/Pages/ByBrand.aspx?page=ProdInst&Subcategory=Lightweight%20Strollers&Model=G091158&CategoryName=Strollers
May 06, 2013 | Graco Cleo 6D00TRF3 Truffle Travel System
Need a picture of the crankshaft and cam shaft alignment marks
Fig. 1: Timing marks are located on the camshaft pulleys as shown-1.8L engines
Fig. 2: Make sure that the crankshaft sprocket (timing belt pulley) and oil pump timing marks are aligned-1.8L engines
Fig. 3: Align the timing belt pulley mark with the tension set mark, at approximately the 10 o'clock position-1.8L engines
I hope helps with this (reemmber rated this help) Good luck.
Dec 29, 2009 | 1997 Ford Escort
Timing belt timing marks, 1997 ford escort where are they?
Ford Escort/Tracer 1991-1999 Repair Guide
REMOVAL & INSTALLATION 1.8L Engine
(see Figures 1, 2, 3 and 4)
  1. Disconnect the negative battery cable.
  2. Remove the timing belt covers.
  3. Rotate the crankshaft and align the timing marks located on the camshaft pulleys and the seal plate.
  4. Remove the crankshaft pulley and hub.
  5. If the timing belt is to be reused, mark an arrow on the belt to indicate its rotational direction to enable correct re-installation.
  6. Loosen the timing belt tensioner lockbolt and remove the timing belt.
To install:
  1. Temporarily secure the timing belt tensioner in the far left position with the spring fully extended, then tighten the lockbolt.
  2. Make sure the timing marks on the timing belt pulley (crankshaft sprocket) and the engine block (oil pump housing) are aligned.
  3. Make sure the timing marks on the camshaft pulleys and the seal plate are aligned.
  4. Install the timing belt.
  5. Loosen the tensioner lockbolt. Using a suitable prying tool, position the timing belt tensioner so the timing belt is taut, then tighten the tensioner lockbolt.
  6. Turn the crankshaft two turns clockwise and align the timing belt pulley mark with the mark on the engine block.
Fig. 4: Check the timing belt deflection at the location shown-1.8L engines
  1. Make sure the camshaft pulley marks are aligned with the seal plate marks.
If the timing marks are not aligned, remove the belt and repeat the procedure.
I hope help you with this; remember rated this help. Good luck.
Sep 11, 2009 | 1997 Ford Escort
My timing belt broke on my '99 Ford Escort ZX2. Please tell my husband how to replace it. Than k you
Timing Belt
1.8L Engine
To install:
Fig. 1: Timing marks are located on the camshaft pulleys as shown — 1.8L engines
Fig. 2: Make sure that the crankshaft sprocket (timing belt pulley) and oil pump timing marks are aligned — 1.8L engines
Fig. 3: Align the timing belt pulley mark with the tension set mark, at approximately the 10 o'clock position — 1.8L engines
Fig. 4: Check the timing belt deflection at the location shown — 1.8L engines
Mar 28, 2009 | 1999 Ford Escort
No instructions for a graco cleo!
how do i fold the graco cleo rear facing
Mar 18, 2009 | Graco Quattro Tour Travel System
Intermittanwipers t inop on renault cleo
try replacing the wiper relay
or could be a faulty wiper intermittent part of the switch
Apr 11, 2017 | 2003 Renault 181
Timing marks
If u cannot obtain the itming marks, u mite have to time the engine by first pricnciple. Ensure that #1 cylinder is @ TDC (compression stroke). Install the camshaft making sure that the cam lobes for #1 cylinder are on the lower side and not on the tip of the cam. Also when installing the distributor, ensure that it's set to spark @ #1 cylinder. In modern day vehicles, the distributor can only be fitted one way so theree is no need to time the ignition timing via distributor. If this is too much, u can check the crankshaft & camshaft sprocket for distinct timing markings . This should be checked when the components are clean
Oct 23, 2008 | 1997 Toyota Camry
youtube.com Logo
43 people viewed this question
Top youtube.com Computers & Internet Experts
Mike
Are you a youtube.com Computer and Internet Expert? Answer questions, earn points and help others
