Question about Gaggia MDF Electric Burr Grinder
Internal fuse in gaggia mdf. In an earlier post it has been suggested that it is possible to remove the internal fuse by using a right-angled flat blade screwdriver, thus avoiding the need to take off the hopper and remove the motor assembly. if using the screwdriver method, do you access the fuse from the top or bottom of the grinder?
SOURCE: Grinder spins but won't grind coffee
You have fill a water in your coffee grin
Posted on Jul 17, 2007
  • 833 Answers
SOURCE: Broken Handle on Coffee Grinder
Nice unit! Replace the part. Try www.smallappliance.com.
If you want to try to glue it first, get a product from 3 M. I think they call it super strength glue. Scrape off all traces of whatever you used before. Follow the instructions exactly.
Posted on Dec 03, 2007
  • 833 Answers
SOURCE: Coffee Beans Empty - but the hopper is full!
Caffeind...the problem is likely still some bean remnants stuck in a switch which is causing the problem. Get some newspaper and open it up on a flat surface. Invert the grinder and give it a couple of thumps on the newspaper. The chips should loosen up and fix it. Remember, beans are both sharp in shape and oily in makeup...perfect for getting stuck.
Posted on May 09, 2008
SOURCE: Gaggia MDF Electric Burr Grinder
It could well be gummed up with years of coffee bean residue
Very simple to take apart. There are two screws holding the cannister. They are hidden under 5mm round rubber covers that you have to pry off. Then remove the two screws holding the plastic cover. Mark the position of the numbered dial relative to the brass burr assembly then remove it. Once exposed, you should be able to figure out why it is locked. Scrape away as much gunk as you can.
Posted on Dec 13, 2008
EsWorld
  • 1618 Answers
SOURCE: GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
Posted on Jun 09, 2009
Buttons on TV suddenly not responsive
If they are actual buttons check to see if one is stuck. Listen for a click on each button while it is turned off so you can hear it and feel it. Another possibility could be when you moved it around somehow the internal cable that connects the buttons to a connector has slipped out or just has a bad connection. Would require you to take the bezel off to see if the internal connections are ok. Not sure what else to suggest. At least the remote works.
Feb 11, 2014 | Insignia 42" Flat-Panel Plasma HDTV
Need operating & maintenance manual for brevetti gaggia mdf burr grinder.
Hello, your instruction manual can be found on this link by clicking or copy and pasteing it to your browser http://www.gaggia.com/dam/bo/allegati/files/31_mdf.pdf if you are unable to obtain these instructions by copy and pasteing to your browser please message me back and I will provide my email so that I may send you them directly.
Thank you
Rick
Nov 08, 2011 | Gaggia MDF Electric Burr Grinder
Is there a fuse inside the grinder to protect it from an electrical surge. I accidentally plugged it into a 220 volt outlet.
My MDF was built in September 1993. It has a fuse inside a black cylindrical fuse holder on the electronics board that sits aside the motor. If you have a right-angle flat blade screwdriver, you can get the fuse out without removing the motor unit from the case. I didn't have the right tool, so I ended up removing the motor/grinder unit from the case to replace the fuse. The fuse is a 2A/250V Slow Blow. I used a Buss CDC-2A to replace the factory "5TT 2A/250V" fuse.
May 09, 2011 | Gaggia MDF Electric Burr Grinder
I have a Gaggia burr grinder, Brevetti Gaggia SA Model MDF, s/n 7262. The handle that you flick back and forth to let the grinds come out broke off inside the unit.fixable? 707=837-8916 Thanks Anne
Look inside the grinder, The lever is attach to a SPRING .
May be the lever is disconnected (unhooked) from the spring.
AND YES IS FIXABLE.
It cost you about $15-$30 for the parts.
Jan 15, 2011 | Gaggia MDF Electric Burr Grinder
Cleaned the Gaggia MDF grinder and now it won't start
  1. check the supply wire IF IT NEEDS CHANGING CHANGE IT
  2. check the switch IF IT NEEDS CHANGING CHANGE IT
  3. check the thermo fuse if it is built in ( if it is resettable than reset) if it is not resettable than just make one bridge from wire for testing( you will need to input resettable one if motor is ok)
  4. check the electro motor and bearings IF REWINDING IS NEEDED GO TO MOTOR REWINDING WORKSHOP (ASK FOR CHANGE OF BEARINGS TOO)
Dec 12, 2010 | Gaggia MDF Electric Burr Grinder
How can I clean my Gaggia burr coffee grinder?
For parts you can see, use an artists paintbrush. If you want to clean the internals, grind some panko breadcrumbs or raw rice grains, then run some coffee through it a few times before using.
Dec 10, 2009 | Gaggia MDF Electric Burr Grinder
Can't disasseble burr set
take an oil filter remoover for cars(the model with 3 legs and gears will do better job). 2 man required one holding grinder other one start turning left and right the upper holder(during turning hold down the brake pin.) it is bit boring and job wich requires patience. but i think you will manage it
here is the diagram:
http://www.partsguru.com/images/Img844.jpg
Jul 12, 2008 | Gaggia MDF Coffee Grinder
ESPRESSO MACHINE LOST POWER AND WILL NOT TURN BACK ON
Try a different outlet.
The internal thermal fuse could be damage.
Apr 23, 2008 | Gaggia Titanium Espresso Machine
MDF very coarse grind
Several possibilities loom:
1. Same burrs for 25 years? don't be cheap replace them!
2. Dirt in the threads of the burr carrier, or the threads that recieve it?
Let us know what works
Dec 18, 2007 | Gaggia MDF Electric Burr Grinder
Gaggia MDF Electric Burr Grinder Logo
55 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
