Question about Dryers
Maytag neptune dryer will not start
Have checked start switch, high limit thermostats
  • Richard Dicarlo
    Richard Dicarlo Jan 14, 2013
    fuses check out
  • Richard Dicarlo
    Richard Dicarlo Jan 16, 2013
    I've checked all the fuses on the dryer and all shoe to be good. I believe that I checked the fuse on the motor and it looks good.
  • Dryers Master
  • 8,220 Answers
Some of them neptunes have 2 fuses. One is behind the filter housing.
Neptune dryer service manual
Posted on Jan 14, 2013
  • 2 more comments
  • Richard Dicarlo
    thank you for your help. Both fuses and the high temp thermostat show conectivity.
  • Dan Webster
    Dan Webster Jan 14, 2013
    even the fuse beside the control t-sts /thermistor on the blower housing? You checked everything with the wires removed?
  • Richard Dicarlo
    Richard Dicarlo Jan 15, 2013
    rechecked the thermal fuse, thermal fuse heater, and high limit thermostat with wires removed and all show connectivity (I cheked them with the wires attached the 1st time)
  • Dan Webster
    Dan Webster Feb 26, 2013
    You must have either a bad door switch, a bad motor or a bad timer IF you have power going to the unit. these are what I would check next. I made a video of a roper dryer repair. Even though they do not look the same, all dryers work the same. It will give an idea what to look for:
4 Suggested Answers
Greg20
  • 149 Answers
SOURCE: Maytag Gas Dryer - Flame trips high limit Tstat
firstly..is venting blocked? disconnect venting and try it. if problem persists then replace hi limit. assuming what you just told me was correct.
Posted on Jun 11, 2009
heatman101
  • 43501 Answers
SOURCE: My maytag neptune dryer won't start. The control
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jun 01, 2010
  • 113 Answers
SOURCE: Maytag Neptune Dryer Model #MDE4000AYW
It is dangerous to do but you have to turn dryer on while it is apart and wait for limit to open up, then test. !st make sure all connections are ok. The clips and the nuts all need to be tight. If any look dark or burnt that may be your weak link. If you are sure that everything is else is working ok, a set of high limit switches is not very expensive. The voltage is 220 so if your careful you can test at each junction, but be careful..
Posted on Sep 18, 2010
MDE5500AYW Maytag Neptune not heating. Heating Element, both high limit thermostats and thermal fuse have been replaced. What could be the problem?
Firstly, you have not mentioned that you have verified the presence of a power source of 240 volts, so make certain of that issue. If you have proper voltage, then the motor centrifugal switch could be at fault
Below is a link for trouble shooting your model.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-4-563862-/Maytag-Dryer-not-heating-MDE5500AYW?r=%2fShop-For-Parts%2fa8b4d563862%2fModel-MDE5500AYW-Maytag-Dryer-Parts
Sep 28, 2016 | Maytag Dryers
Hi Jerry ,on my simpson Neptune two of the elements will only burn high,what can I do? Thanks.
Check the "high limit thermostat" on your dryer.
Take a look at this troubleshooting tip for the no heat problem for your dryer.
Oct 19, 2011 | Maytag Neptune MDE5500AY Electric Dryer
How much can I expect to pay to have the thermostat replaced on my Maytag Neptune gas dryer?
If you are inquiring about the high limit thermostat on the side of the heat canister it sells for $40.00 U.S.
Service call and labor rates vary in your area.
Do It Yourself for $40.
Aug 08, 2011 | Maytag Neptune MDG9700A Gas Dryer
Neptune dryer proble. The dryer works except no heat. Flame starts, but then turns off. Igniter element was checked and is good. What else should I check in order of probability? - flame sensor? -...
Hi
Thanks for using FixYa. Things that could stop an electric dryer from heating: - house fuse or breaker (needs two of them), heating element, burnt wire, thermostat(s), thermal fuse (not all models), motor heat switch, timer, selector switch, burnt power cord/plug.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer model mde3000ayw
you want to start at high limit thermostat or thermal fuse
its white and has two small wires
it sits on the heat tube
it could be black too
it is shaped like a warped ball
and is rather flat
sears has them in stock
ive included the part number to help
307473
Oct 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Heats upon start-up then heat shuts off
This could be caused by a partially burnt heating element or a faulty high limit thermostat. The more likely cause ( I think) would be the high limit thermostat. It is a small round black device mounted on a metal plate. It is usually attached to the internal ductwork with two screws. You can test it with a multimeter for continuity. It should have none. If it has continuity, then it is stuck open and is defective. Hope this helped and best wishes.
Aug 05, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Neptune mdg3000aww starts heating and runs fine but stops heating shortly after start up can restart heater starts again and shuts down
If the machine keeps running but just not heating you have a thermostat issue. It could be the operating therm. or the high temp limit therm malfunctioning, shutting off the element.
If the machine stops running completely, check the door switch.
Jul 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag elec. neptune dryer won't heat
The first thing I would check would be your high limit thermostat. It is located near the heater and is wired in series with the heater. The contacts in a high limit thermostat remain closed at temperatures below 250 degrees. The contacts will open and interrupt the circuit to the heater when the operating thermostat, thermistor or electronic control fails to cycle properly. The most common condition that causes the high limit thermostat to operate are vent restrictions, blower failure or a defective operating thermostat or thermistor.
If those are good, then,
Check your dryer heater. With both heater power terminals disconnected you can check for resistance. The typical dryer heater resistance is around 20 Ohms.
If you can not read resistance on the dryer heater then it is an open circuit and needs replaced. Also if your meter indicated an electrical path between either of the heater terminals to the heater frame (ground) then it’s bad. The heater must be isolated from its mounting frame.
Jul 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Slow to dry cloths
Remove the vent from the back of the dryer and see what the temps are. The cycling (or operating) thermostat is on the blower housing and opens more than 100* lower than the 266 you are reading. That, combined with the long dry times indicates an airflow issue. Check your lint screen....fabric sheet and lint can combine to coat and restrict air flow through it. Also check down in the blower housing with the lint screen removed. You'll see lint build up by looking down the slot with a flashlight. If it's restricted, so is the blower wheel and the blower housing. Also make sure the flap, or lovers at the vent hood outside are opening fully. Remove any accumilation of lint from there.
The high limit control is just that........If you cycling thermostat has failed, or does not open because there is no airflow, the limit control opens as a safety. On a normally operating dryer, the high limit control will never open.
The neptune dryer is designed to move more air than a regular dryer due to the higher capacity load it get's from the neptune washer. That is the case with most front load laundry pairs.
May 06, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune dryer overheating
Hello
Welcome to Fixya
My name is Huum,
Yes, I agree it is the high limit thermostat, or the motor is bad!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
93 people viewed this question
Top Dryers Experts
