Question about Yamaha RX-V473 A/V Receiver Black
Yamaha rx v473 cuts off
System shuts off and check speaker wire message comes on
    Problem Solver:
  • 17 Answers
Disconnect all speakers, turn it on. If it stays on, connect one pair of speakers at a time and when it shuts off, that speaker is the problem. There may be a short in the wire or the speaker may be bad. If you get that far, try connecting the bad speaker with another speakers wires.
Posted on Jan 16, 2013
hbsurfdawg
  • 95 Answers
SOURCE: Yamaha RX-V1400 receiver powers off, in case it becomes louder
Hey, yeah that can be frustrating.
When you turn it up do you hear the relay or a clicking sound, then you turn it on and it comes back below the +2db?
Try unplugging All the speaker wires from the unit. Turn on the unit and listen for the click.
after the click, turn it up past the 2+ db mark and see if you hear it click or shut down. If it did not click off, then suspect a shorted crossover on one of your speakers.
2nd test is to plug in One speaker, and test it at high volume, it will not harm it. If it shuts off disconnect that speaker and try another. Only one at a time.
If it works at high volume, you need to isolate one of your speakers and i bet it has a shorted crossover that has been cooked. P.S. If one is bad, suspect they will fail at a later date.
If they all fail, use a friends speaker and try it before sending it to a repair shop.
P.S. i found one on ebay i think you can get for under $100 bucks in the box.
http://cgi.ebay.com/Yamaha-RX-V1400-7-1-THX-Select-Receiver-MINT-Condition_W0QQitemZ330311512027QQcmdZViewItemQQptZReceivers_Tuners?hash=item330311512027&_trksid=p3286.c0.m14&_trkparms=72%3A570|66%3A2|65%3A12|39%3A2|240%3A1318
E
Posted on Mar 02, 2009
  • 44 Answers
SOURCE: My Yamaha HTR-6050 shuts off at random times and says "Check SP Cable"
i think it means speaker cable?
http://www.fixya.com/search/p514076-yamaha_rx_v2700_7_1_channels_receiver/check_sp_cable
Posted on Apr 23, 2009
smarthome2
  • 1114 Answers
SOURCE: Yamaha RX-V361 cuts off: check SP cable
Disconnect the speakers and turn on. If your receiver is ok, it will not go into protection "check spkrs" Then connect speakers, one by one, each time make sure the receiver is off, then turn it on. When you find the speaker that's causing the problem it will go into protection. At this time, disconnect the speaker at the speaker, then turn on again, if it still goes into protection, you have a speaker wire problem. If it stays on, you have a problem with the speaker. If you have a multimeter and know how to read it, check the impedance and the resistance. Check the internal workings of the speaker, bad surround from dryrot or smoked crossovers, etc. look for the obvious first. Hope this helps
Posted on Jun 04, 2009
  • 4234 Answers
SOURCE: MY YAMAHA RECIEVER KEEPS SHUTTING OFF
The unit is going into protection mode. The message is a generic one and usually means that the output section is drawing too much current and has been shut down. Defective speakers can cause this, but in this case, I suspect that there is a problem in the front end that is allowing DC current to pass to the output circuits. This will cause a problem that will shutdown the system. Yamaha designs are not the most straightforward nad I would not suggest you attempt this repair without prior repair experience. Take this to a service center and request a detailed repair estimate and report the results here. Armed with that info, we canguide you further.
Dan
Posted on Jul 19, 2009
SOURCE: Yamaha RX-V2400
Had same problem. Display would read, "Check Speaker Wires". Rear speakers were shorted by a carpet nail. Works fine now.
Posted on Dec 28, 2009
My yamaha rx-v473 wont turn on
disconnect all wires from behind unit, speakers, input, and then try to power it up ,
if problem persist then try to tighten screws on back panel of the unit,
may sound silly but if amp board does not have good ground connection it can do that , go in protect mode .
happened to me ...
Jan 26, 2013 | Yamaha RX-V473 A/V Receiver Black
Yamaha rx v473 system cuts off periodically - check speaker wires message comes on
You have a short in a speaker or speaker wire, or you are over-driving a speaker.
Jan 14, 2013 | Yamaha Audio Players & Recorders
My Rx-V473 won't turn on
It couldn't start after an update. I found how to fix it on the product page : http://download.yamaha.com/search/detail/?language=en&site=europe.yamaha.com&asset_id=58063&category_id=16446&product_id=1643029&1375038490
Receiver doesn't power up after the update.
Error message appeared when confirming the firmware version.
Recovery method using USB method:
1. Unplug the AC power cable from wall outlet.
2. Insert the USB thumb drive which has the firmware data stored inside, into the USB port located on the front panel.
3. Press and hold the INFO key and keep it pressed while you plug the AC power cable back into the wall outlet again.
" USB UPDATE " will appear on the front display. Then, release the INFO key.
4. The update will start automatically.
5. When " UPDATE SUCCESS " appears on the display, firmware update is completed.
Power off the receiver and remove the USB thumb drive.
6. Confirm updated firmware version.
Oct 18, 2012 | Yamaha RX-V473 A/V Receiver Black
Amp keeps shutting off
• Check again with no speakers connected, if it doesnt shut off,
Check speaker system, connect one at a time to find the cause.
• If the receiver still shuts down without the speakers,
troubleshoot inside the unit.
Aug 04, 2012 | Yamaha Rx-a710 Aventage 7.1 Home Theater...
Yamaha RX-V793 receiver shuts down when I turn up volume. Checked the speaker wires and they seem okay. I then hooked it up to an older DVD player I had and it works fine. Don't know if it's 5.1 bu
My first thought would be that when you moved the receiver to connect another DVD, the problem quit since the speaker wires moved. The best way to test would be to re connect the original unit the same way as the new unit and test again. If it still cuts out, disconnect the speaker wires and re test. if it still cuts out, try the new player and test again. if it does not cut out, there may be a problem with the old units audio output. Generally if its a problem with the receiver it would not matter what source you are using, even the tuner on the receiver, if there was a short in the receiver it would cut out. Let me know what your results are and I will help more if needed. Best of luck!
Nov 24, 2011 | Yamaha Audio Players & Recorders
I have yamaha v863 receiver. when i play movies on dvd. Any times
Check to make sure no wires are touching at the reciever. Next step is process of eleminaton. Unhook each speaker until it works or if you have a meter you could always check to see if you have a blown speaker or shorted wire. I would first disconnect all speakers and check to see if unit does it with no speakers connected.
Jul 06, 2009 | Yamaha RX-V863 Receiver
Yamaha RX-V361 DVD cuts off w/ check SP cable message
This message means that speakers are not connected properly. What is their impedance? What is the impedance set on the receiver via Advanced Setup menu (see manual)? Check if it is not short-circuited.
Try the receiver without speakers connected. If the message goes away, receiver is OK and problem is in the connection to the speakers.
Jun 04, 2009 | Yamaha RX-V361 Home Theater Receiver
Apr 23, 2009 | Yamaha RX-V757 Receiver
RX-V2600 shuts down
Try checking your speaker impedance. If you have 6 ohm or 8 ohm speakers make sure the impedence matches. On the front panel hold down button that says "straight effect" while pressing Stanby/On button, it will default to SP IMP 8 min, press straight effect again, if you have 6 ohm speakers, then press Standby again to exit setting. Also, double check your speaker wires to make sure they are all connected, and none are loose.
I hope this helps.
Mar 31, 2009 | Yamaha RX-V2600 Receiver
Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Jun 04, 2007 | Yamaha RX-V2600 Receiver
Yamaha RX-V473 A/V Receiver Black Logo
254 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
