Question about Exercise & Fitness
Error 51 Treadmill Kettler Track Performance
I have Error 51 on my Treadmill Kettler Track Performance. Help please to fix this problem
    Top Expert:
  • 12,223 Answers
This a problem with the elevation motor. You are working with the treadmill without put in level.
You need LUBE the gear+shaft see the picture. But most importante adjust the POTENTIOMETER a little see the diagram attached.
God bless youError 51 Treadmill Kettler Track Performance - 1_14_2013_8_52_42_pm.jpg1_14_2013_8_53_05_pm.jpg
Posted on Jan 14, 2013
5 Suggested Answers
  • 218 Answers
SOURCE: how do i raise nordic track treadmill?
if that is where it catches then that is how far it goes there is no adjustments. Make sure the incline is the whole way down
Posted on Aug 11, 2010
  • 3 Answers
SOURCE: Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
Posted on Aug 30, 2009
ercupa190
  • 12223 Answers
SOURCE: Treadmill KETTLER PACER error code E7, what I have to do?
see the next steps and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Posted on Nov 28, 2012
ercupa190
  • 12223 Answers
SOURCE: Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Kenapa kettler treadmill dengan error 11?
If you wish to get some details about treadmill Error codes; check the site linked here. http://electro-medical.blogspot.com/
Nov 10, 2016 | Kettler Exercise & Fitness
I have kettler pacer treadmill it is not getting start,when I press start button the display shows system fault and also shows error dc6
Motor controller...these are typically motors that have speed controllers. When they fail, just test and replace. Call the manufacturer for parts.
Nov 25, 2014 | Kettler treadmill Pacer
Error code e11 I have kettler track motion , treadmill stopped working what do I do
Reset the treadmills, disconnect the power for 30 seg. or reset the small switch to the side of power button. and try again.
However you must RUN the software calibration for e11. and fix it
go to the HOOD cover motor, and follow the steps .
God bless you
Sep 30, 2013 | Exercise & Fitness
High speed and error 91 and treadmill stop
Please recalibrate the machine with software calibration, for easy diagnose, troubleshooting and fix it
If the problem persist, you must need some basic parts or need service for repair. See hte block diagram attached.
God bless you
Jan 07, 2013 | Kettler TX1 Treadmill with FREE INSIDE...
TX3 folding treadmill. switch on says ERR how to fix is the question>
This is probably a 1) faulty speed sensor or
2)the speed sensor is not plugged in properly.
3)Its also possibly a faulty motor control board or
4) lower board. T
he error codes will differ between makes and models but could be e1.
However if you send the complete information, if can not fix you treadmill, how model, mark, serial number, I can handle more specific.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Nov 16, 2011 | Kettler TX3 Folding Treadmill
Kettler Treadmill TX 3 gives error 91 supplier told it was the Power supply print. We changed it including the motor and the problem was solved for a couple of weeks. Now it is back again? Please...
Problem with Trendmil TX-3 err-91 problem is solved ... speed sensor (photo transistro in photo cell is damaged).The palsis in colector is 5V Amplitud .
Apr 05, 2011 | Kettler TX3 Folding Treadmill
Hi Rendra,
Try this:
May 10, 2009 | Exercise & Fitness
Exercise & Fitness Logo
292 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
