Question about Sewing Machines
I need a picture of the bobbin case for huskystar e10
  • 8 Answers
SOURCE: Bobbin problem: Huskystar by Husqvarna Viking E10 sewing machine
This has happened to me, even though I have been sewing for 30 yrs. When I take the bobbin holder out I realise what I have done wrong. When placing a bobbin into the bobbin holder the thread must be running around the bobbin CLOCKWISE. If incorrect take bobbin out of holder turn it over, so now the thread will run clockwise.If bobbin placed in holder and thread runs anti-clockwise, when you tried to turn wheel to bring bobbin thread up, it will either not do it at all or will make a huge tangle of the threads. Happy Sewing
Posted on Nov 17, 2008
  • 192 Answers
SOURCE: Bobbin case keeps on breaking on my Husqvarna Huskystar C20
What part of the bobbin case is breaking? I've never seen one break before.
Now if the bobbin case is rotating slightly in the machine and the needle is punching holes in it, there is a very simple way to fix this problem.
Set the bobbin case into the hook assembly as if reassembling the machine. There is a metal finger that it fits under on the left rear section of the case. If you place your index finger in the case where the bobbin fits and lift the back edge up against that metal finger, it should only come up about 0.8-1mm. If it raises up 2-3mm, this is the problem and the finger can be mechanically reformed to set closer to the bobbin case. Mechanical reforming is also known as bending. Push it down to the case and when you release pressure it should be close enough. This will keep the case from lifting so that it can't rotate during operation.
You may also be able to use a craft knife to remove all of the rough edges caused by the needle strikes on the bobbin case. I often do this for my customers so that we can be sure that a new case won't be damaged. When the customer brings it back for an annual service, I replace the bobbin case at that time.
Posted on Apr 09, 2009
SOURCE: Bobbin Case Spins - in Huskystar C20
I had this problem when I first bought my machine. I took it in and they told me it was a recall problem. All the machines were having the same problem. They fixed it and I have not had the problem since. I bought mine at a Joanne fabrics. Hope this helps.
Posted on May 28, 2009
Zenqi
  • 208 Answers
SOURCE: i am searching for the User Manual Huskystar E10
Your Viking dealer can get it or you can call Viking directly and they will send you a PDF of it.
440-808-6550
Posted on Jul 11, 2009
  • 152 Answers
SOURCE: I have a Huskystar C20 sewing machine and the
Take off the needle plate. There is a bracket near the front right area of the bobbin case. It is the position bracket that supports the case. First smooth the case of any rough edges, the put it in place and loosen the screw of the position bracket and align it in an area that will keep the case from spinning. There should be about 0.5mm of distance available when you use your finger and push the case from left to right, between the case and the bracket. Remember that the thread flows through this area, the case is held in place by the bracket but not tightly.
Posted on Nov 21, 2009
I need to know how to lower the feed dogs on my Huskystar Viking E10
There is a switch on machine to raise feed dogs up/down. Remove any extension table to locate it because many of these options are located in the back of machine & hidden by table! Jimmy :)
Apr 07, 2012 | Husqvarna Sewing Machines
I can not get my bobbin thread to sew but my top thread does on my Huskystar 207 sewing machine
have you checked to may sure the bobbin is turned the right way & inserted
in the bobbin case the right way?
try changing the needle --flat side goes to the back of the machine
Apr 05, 2012 | Sewing Machines
Bobbin thread jams
try changing the needle--flat side goes to the back of the machine
check the thread take up lever & see if the thread is still on it
it's also possible that the machine is out of time & needs to serviced
Feb 19, 2012 | Husqvarna Huskystar 207 Sewing Machine
My Huskystar C10 Bobbin keeps popping out. I followed the instruction manual's directions to place it back in after cleaning but it will not stay in place. Help!
If you have any rough spots on the outer edges of the bobbin case, usually caused by the needle going through it, you will continue to turn it until the rough spots are smoothed off. I scrape the rough areas with a knife so the edges are smooth and uniform.
You may want to take it to a repair center to have this done. Don't be surprised if they recommend replacing the bobbin case. That is the quickest and cleanest fix.
Oct 15, 2011 | Husqvarna Huskystar 215 Sewing Machine
Mar 29, 2009 | Husqvarna Viking 1
Mar 21, 2009 | Husqvarna Viking 1
Needle Sticks - Huskystar E10
When it feels like the needle is jammed, open the bobbin cover and release the two black retaining levers, one on either side of the bobbin case. The hook cover that is visible will be released. If the machine turns by hand smoothly, you may have a piece of the broken needle, or just a piece of thread stuck behind the hook or hook cover causing the bind. This problem will sometime make you swear that the needle is stuck in something because it will usually bind while the needle is down in the fabric.
Apr 04, 2008 | Husqvarna Viking 1
Nov 17, 2007 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
