Question about Tappan Dishwashers
Water not being pumped out
I was told to take the pump apart and see if anything was caught in it. I need details on how to take the pump out.
  • btwinston1 Jan 24, 2009
    That didn't work. Where do I go next?
    Sergeant:
  • 311 Answers
Hello btwinston1,dont start at the pump for a no drain issue on DW.start under your sink with the drain hose,air gap or disposer.thats where i have found blockages most of the time.after cleaning inspecting their ,then work your way back following that hose and checking at each connection.then if not there you can think about the pump .just email thru fixya and we take care of it.God bless ,tom
Posted on Jan 23, 2009
Vibration sound coming from pentair pump
take pump apart see if anything is caught in the impeller or if impeller is broken
Dec 29, 2013 | Pentair Pool & Spa
My GWL15 washer keeps alarming out between the wash cycle and the rinse cycle. The agitator works but seems like a struggle to get moving, It has been repaired twice under warranty and ther was a string...
Tip the unit back, the pump is where you would need to look, it should be on your right towards the front. If the water level in low you can do this with out getting wet, If full, you will need to remove the water before trying this. There is a clip to the drain pump, lift the clip easy, rotate the pump and pull down, if clogged you should see it there.
I am here if you need more information
Aug 27, 2011 | Fisher Paykel EcoSmart GWL15
Pentair whisper flow pump makes whinning sound
Thank you for posting your question here on Fixya.com.
Your motor bearings are failing. It is most often caused by a leaking pump seal. It is a relatively inexpensive repair if it is caught early enough; before the shaft is damaged from the corrosive water eating into the steel.
Take it to a local electric motor repair shop for inspection. It will likely need a set of 203 bearings for the motor and a mechanical seal for the pump. All told, depending on the labor rates, it should be less than $75. You could try to repair this yourself however if you are not familiar with the process it is money well spent having someone who is do the repair for you.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Feb 13, 2011 | Pentair Wf 6 1.5hp Whisperflo Inground...
Pump makes a load noise
John
Jan 09, 2011 | Century New Magnetek Pool Spa Pump Motor...
The pump has gotten where it pumps a few seconds and stops ,I thought maybe it's low on oil
Most sump pumps are sealed so they have no way to add oil. I would see if your pump discharge line has a check valve installed in it.It should have a check valve installed so that waste can only flow away from pump.Otherwise the pump can cycle for a short period,shut off and have water in vertical pipe flow back into sump basin causing pump to cycle again. Also if your pump does have a check valve in it make sure that it doesn't have anything caught in it that would stop it from closing completely. Some pumps have a check valve installed on the pump. It is also possible that you may have something caught in the pump impeller. you will need to remove pump to inspect the impeller. Hope this helps you. Thanks
Nov 22, 2010 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
I have a Hayward pump that is making a wining noise.
Your motor bearings are failing. It is most often caused by a leaking pump seal. It is a relatively inexpensive repair if it is caught early enough; before the shaft is damaged from the corrosive water eating into the steel. Take it to a local electric motor repair shop for inspection. It will likely need a set of 203 bearings for the motor and a mechanical seal for the pump. All told, depending on the labor rates, it should be less than $75. You could try to repair this yourself however if you are not familiar with the process it is money well spent having someone who is do the repair for you.
John
Nov 15, 2010 | Hayward Pool Products HAYWARD 1 HP 2 SPEED...
JANDY JHPU 2.5 PUMP is making a noise.
John
Feb 28, 2010 | Jandy PUMP SHAFT SEAL - FITS PUMPS
Wont pump out water
first of all does it wash? if it does the motor does not need replacing. the drain pump is located on the front of the motor and has a clip at the top and one at the bottom. it has 2 hoses attatched to it. remove the pump and check if anything is caught inside it. if not the pump will need replacing. let me know how you go
Feb 18, 2008 | Washing Machines
Dishwashers Logo
91 people viewed this question
Top Tappan Dishwashers Experts
neilmoto
marley mcelhinney
Melissa Martin
Melissa Martin
Are you a Tappan Dishwasher Expert? Answer questions, earn points and help others
