Question about OKI C8800dn Led Printer
Oki c8800 yellow wont print - OKI C8800dn Led Printer
4 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: Oki c5100n printing yellow color offset
What is the stats % of drums if low under 50% change them, soon as you add non Gen you throw a spanner in any attempt to fault find, fix is possible toner more than likely drum/drums, do a print of each colour and change drums as indicated by failure in its colour to print, check transport belt is OK and led heads are clean
Posted on Jan 02, 2008
Soulvisitor
  • 1113 Answers
SOURCE: Oki c5100n printing colors offset
posted by Halfwalkeer on Nov 13, 2007 Report abuse
Just replaced the color toner cartridges in the c5100N, two OKI (cyan and yellow) and one non-OKI (magenta). Now it appears that registration is completely off.
When printing an image, there is a band of yellow at the top about 6mm high, and a band of purple (not cyan) at the bottom about 6mm high. It seems that the yellow printing LED array is printing offset. I've verified this with a typical test page that shows yellow blipped up by several mm.
What the hell happened ? How can I fix it ?
Thanks -
Dean.
Comment by Halfwalkeer, posted on Jan 02, 2008 Drums are all at 34%. Please don't tell me that the drums only have a 50% lifetime on them, because that would just suck royally. When you say the problem is most likely drums, in what way ? What could have gone wrong ?
I was able to more or less fix the problem ... It took several iterations of ColorMenu->Adjust Registration followed by Maintenence Menu->Menu Reset, but it was finally able to pull the registration back into line.
I got worried at one point - after it was "fixed" the printer was powered off. Upon powerup again, registration was off by several centimeters ! Another round of the above finally "fixed" it again, but I haven't powered it down again.
It was a cheap printer. Maybe this is why ...
postsolution.gif Post Solution addwq.gif Work Queue sameproblem.gif Have the same problem? X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Solution #1 posted on Jan 02, 2008 0%20stars.png
4d566c2.jpg Soulvisitor
Rank:guru_s.gif Guru
Rating: 86%, 674 votes
Comment by Soulvisitor, posted on Jan 02, 2008 I was thinking about the band of yellow being caused by cleaning blade wearing on drum, drums are garenteed by oki if over 50 %, under that one is on their own ie purchase new if having problems with them
If you can fix problem doing colour calibration then faulty drum is not likely the issue.
Cant stress how many problems are caused by non gen consumables in machines, highly dont recommend their use.
Posted on Jan 13, 2008
omerboo
  • 424 Answers
SOURCE: PRINTING PROBLEM FOR OKI B4250
Driver download link: Oki B4250 Printer Driver
Posted on Feb 02, 2010
Oki C9650 not printing Yellow
remove the unit
open the cleaning lamp cover (front of unit)
turn O.P.C drum gear and check that toner is always applied to the developer roller
Sep 27, 2012 | Oki Printing Solutions C9650 Led Printer
Colors are not printing the acutal color
It all depends on the meaning of 'not properly'.
Try creating a document with four different squares, or words, of these colours: yellow, magenta, cyan and black. If all of them print (albeit not with the correct shades) it is probably an ICM driver error. But my guess is that only one of those four colors will print badly, due to a defective color cartridge.
The OKI 5150 makes all perceivable colours using cyan, magenta, yellow and black toners, so if one of these malfunctions, the resulting colors will lack the required shade of, say, yellow, and will appear to be "wrong". The yellow colour itself, of course, would simply disappear (the "yellow" you use might actually be 95% yellow and 5% cyan; then the "yellow" square will be printed as a very light shade of cyan, while the other colors - say, 95% magenta and 5% yellow - will turn out almost exact).
Try with the color test and replace any failing cartridge; if all four (almost) pure colours do print incorrectly, it's unlikely to be a cartridge problem, and we'll have to dig deeper.
Sep 09, 2009 | OKI C5150n Led Printer
Printing with 190gsm paper
Max paper weight is 203gsm so you are near the upper end of specs, you must feed via manual pass and exit from face up tray (out of rear), paper type(heavy/card stock) must be set on print driver. User guide can more than likely be found www.oki.com.
Dec 31, 2007 | OKI C5200n Laser Printer
B4100 - Yellow Light
U can have stuck a little piece of paper, that it mess whit some sensor. Try to open the Oki, push the drum unit out and watch if there is no paper stucked.
Nov 26, 2007 | OKI B4100 Laser Printer
Nov 13, 2007 | OKI C5100n Laser Printer
Thanks -
Dean.
Yellow Lines on every print
If the optics are clean (use lint free cloth on 4 rows of black thingys underside of lid)
Then it sounds like the yellow drum needs to be replaced, when printing in word I'm guessing that you have it set to B/W prints hence no colour is engaged, no lines
Oct 17, 2007 | OKI C5100n Laser Printer
OKI C8800dn Led Printer Logo
7,881 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
