Question about Harley Davidson HarleyDavidson FLHTCU Ultra Classic Electra Glide
I have a 1991 flhs and when i turn left or right the engine cuts out ,perfect going straight.its gradually gotton worse and now wont start at all.thers is no kill switch on the side stand and neither on the clutch leaver.ive checked the wires behind the headlight and under the clockes and all the connectors are clean and tight.i checked to see if the plugs are sparking but they arnt now. the ht leads seem clean so iam wondering would the coile cause a problem like that,bearing in mind it was running perfect on the straight until i do a sharp bend
SOURCE: Rear cylinder not firing
95 Evo, new plugs, new wires, started backfireing like a machine gun, front cyl. no spark at plug sometimes - would this be the coil, have not ohmed the coil yet . Thanks
Posted on May 13, 2009
  • 4565 Answers
SOURCE: ok here is an update... the crank sensor is about
Ok, I assume that you are talking about the large spark plug wire connections on your coil. The book says that the resistance should be 10,000 to 12,500 OHMs. I would assume that is between the two towers as it does not show the lead connections.
Here's how I test a coil. Turn the switch on and check for 12 volts on one end of the coil. Have a set of plugs in the wires and have them grounded well. Disconnect any wires from the other small connection and connect a temporary jumper wire. Momentarily ground the jumper wire and then remove it from ground. Each time your REMOVE the short jumper wire from ground, you should get a spark from the spark plugs. If not, make sure you still have the 12 volts on the other end and the plugs are well grounded. If this correct and you do not get a spark, your coil is bad.
Posted on Feb 15, 2010
Testimonial: "this is a good way to learn but damn on the soul"
  • 4565 Answers
SOURCE: 2002 sportster 12 evolution,doesnt keep spark to
Harley has been moving things around since 2000 and it makes life tough for people that do what I do. Try to fix bikes over a computer. I used to tell people that I couldn't fix a bike over the phone. LOL
On your bike, I don't know of any way to test the ignition module. Harley has a way to do it if you use a meter exactly like the one they use but I have never seen one of their meters.
Before you spend a lot of money on a new unit, first check your ground on the unit. Check the plug on the unit. It's also got a cam position sensor in the timer cavity on the left side of the engine as best as I can remember. This part is a lot less expensive but I'd rather solve the problem and replace a part rather than replace parts until I solved the problem.
I'd go to the auto parts store and buy a set of Autolite 4164 spark plugs and try those. The two best brands of plugs in my opinion are Autolite's and NGK's. Not those expensive copper or titanium or whatever they are plugs. Those things are made of auto engines that are running a lot hotter ignition system than your Harley is running. In an air cooled motorcycle, the cheaper the plug, the better they run. Don't waste money on the expensive plugs.
Try that, at least it's cheap. If it doesn't work, start checking connections. I'll say this, when a solid state ignition unit it working, it works. When one stops working it's usually for good. They very rarely stop then start back. Look for that loose connection.
Good Luck
Posted on Aug 19, 2010
Testimonial: "Steve, Thanks man, you have filled in the spot for me I'll go over it all sure the plugs are ok,bike runs great, aside from loosing fire."
  • 4565 Answers
SOURCE: 93 flhs. evo, bike just
If your bike has been converted to a Crane ignition, all you have is the Crane unit, two spark plugs, two wires, and a coil. Seems you've replaced everything else so the unit is all that is left.
Now, before you replace the unit, you see there are two wires on the hot side of the coil. Make sure you have battery voltage to that side of the coil. A test, take your plugs out and lay one on the engine where you can see it. Turn your ignition switch on, then turn it off. You should see a single spark when you turn the switch off. If so, you're electrical wiring and coil are alright. Your unit is bad. If you don't get a spark, you are not getting voltage to the coil for some reason.
If you are not getting power to the coil, make sure the "Run/STOP" switch is in the right position. If it is, you'll need a schematic to trace the voltage back to the source. I have a schematic for a FXDWG. If you want a copy, send me a personal e-mail at and I'll send one to you. This forum will not allow for a file over 150Kb. Remind me of what you need.
Good Luck
Posted on Nov 08, 2010
  • 4565 Answers
SOURCE: engine wont start. I replaced the coil and plug
To verify that the coil is working, take the plugs out of the heads. Put the plugs back in the plug wires and lay the plug against the head so that they get a good ground. Turn you ignition switch on and then turn it off while watching the plugs closely. They should spark one time when you turn the switch off. If so, your coil is working correctly. It sounds like either the sensor in the timing cavity of the engine is bad or the electronic ignition unit is bad.
Good Luck
Posted on Apr 03, 2011
1991 pontiac 6000 key
wd40 first easiest fix
remove steering wheel to see what is binding inside.
unhook small rod going to ignition switch to eliminate switch as a problem.
check ignition switch to see if it is loose. tighten as necessary.
Jan 28, 2013 | 1991 Pontiac 6000
A 93 flhs loosing charge in less than 2 hour
sounds like your battery is not charging from the engine. Most likely the cause of this is, a faulty Rectifier.
I suggest you charge your battery up, put it in the bike and start it up. Using a Volt meter, check the reading, to see if charge is going into the battery, reading should be about 14V with a little rev of the engine. If the reading remains at 12V, then ther is no charge going in.
If you have charge going in to your battery at idle, 13.5 - 14Volts,
Then i suggest your battery is faulty.
Jul 08, 2010 | 2003 Harley Davidson FLHTC Electra Glide...
I have a mark two golf gti 8v 1991,when i try to start her there is no turn over from the engine at all,the lights on the dash board come on for the battery and usual stuff but wont turn over.Have to jump...
check starter relay, and definately remove and clean the terminals on the negative ground battery cable. A voltmeter would be handy to test where the power begins and cuts out at
Apr 19, 2010 | 1991 Volkswagen GTI
Engine cutting out whilst riding along
If all the electrics go off then :-
A) Check tightness of battery terminals & condition of battery
B) Check for dodgy fuse or dirty connections
C) Check voltage across battery terminals when engine running - should be at least 12.5v rising with increasing revs to 15v max - if not then suspect the regulator/rectifier unit or the wiring from it to battery
I hope this helps, if so please mark as helpful.
Positive comments always appreciated
Ride Safe
Sep 19, 2009 | 1991 Honda CBR 250 RR
1991 park avenue The car will start right up in
Check for the number 1228253 on the ecm. If it's on there replace it as they will cause a cutting off problem. You may trying a new crank sensor too.
Jun 25, 2009 | 1990 Buick Century
Honda odyssey 2004
Replace the right front drive half shaft or drive shaft there are 2 drive shafts a left and a right.
Jun 06, 2009 | 2000 Mazda 626
Plasma cutter started cutting at an angle even when held perfectly perpendicular. New consumables were put on, same amperage, same air pressure. I'm stumped!
did you put all new consumables in ,sounds like there is still old one there.make sure nozzel is put back together right.I have worked on welders and plasmas for years,the torch head is very tempermental.
Mar 01, 2009 | Miller 903777012 SPECTRUM 2050 PLASMA...
1991 Sidekick 4 door misses terribly
check lo tension wires,, the power supply to the coil and any connections in this circuit
Sep 07, 2008 | 1991 Suzuki Sidekick
Harley Davidson HarleyDavidson FLHTCU Ultra Classic Electra Glide Logo
Top Harley Davidson Toys Experts
Tre Elkins
ray gallant
Mark McGinty
Mark McGinty
Are you a Harley Davidson Toy Expert? Answer questions, earn points and help others
