Question about Antec TriCool 3.125" LED CPU Cooling Fan - Blue
Cooling Fans compatible with Toshiba A15 laptop
None of the applications on my computer is working because there is a problem with the cooling system. I cleaned it up to no avail and so i thought of replacing the fan. Which ones are compatible with Toshiba A15 laptops.
Thanks
  • Roberta Smith
    Roberta Smith May 11, 2010
    unfortunately... with a laptop you don't have as many choices as you do with a desktop computer.. pretty much as to be the exact part.
    Robert
  • 741 Answers
You can't replace the fan, you have to replace the power supply. In order to find out whih one you need the best thing to do is open your PC and find out the Wattage. It will be marked on the outside of your power supply. Just in case you do not know where the power supply is, if yo see where the vents are on your computer the power supply is there. It has a fan to blow the hot air out of it..
Don't forget to rate this solution with four stars before you log out.
Posted on Jan 23, 2009
My Toshiba is having cooling system issues, the laptop makes noise when the fan is on, and it stops and starts arbitrarily. The system becomes terribly slow and shows a popup saying "cooling system...
Hi, you can try to clean fan with a compressed air can, if the fan works most of the time this helps and you will not need to take anything apart, just pick up one at your local electronic store, follow the safety instruction on the can and spray all the air ways starting with the openning under your fan, but start SLOW and gradually increase the air flow and be very careful not to let the air pressure break the fan fins by sudden changes in the air flow... As for the pop-up it may not nessesarly mean it is heating problem, it may be a virus and you may want to install and anti virus just in case... Best od Luck
Jan 17, 2011 | Toshiba Satellite A15-S1292 A15-S157...
Noisy fan
Ebay is a good source to get parts for Toshiba satellite. Look at Toshiba satellite for parts. Ton of them on regular basic.
Jun 04, 2009 | Toshiba Satellite A15-S129 Notebook
Problem with cooling system
Hi there
hey if you flip over the laptop you will see a long coverpiece about a inch or so wide about 4 inches long remove this cover and you will see a silver piece in there dirt and dust and bad things can get in between the fins of this and cause it to overheat if you can remove it clean it out the best you can and reinstall it and replace the cover piece now restart and see what happnes ok best of luck mike
Feb 17, 2009 | Toshiba Satellite A15-S127 Notebook
I'm need to replace the hard drive without having a system disk.
Google "TOSHIBA RECOVERY AND APPLICATIONS/DRIVERS SATELLITE A100/A105 SERIES" to find the cd delivered with a TOSHIBA. the fourth entry shows what appears to be the real thing. On their webpage EDIT>FIND "A15" to locate the CD.
There may be others in the 355 Google pages listed.
On the original factory disk gives a TOSHIBA Phone number, 1-800-457-7777, for support. I think they sell the disk for @$40.
good luck.
Dec 18, 2008 | Toshiba Satellite A15-S129 Notebook
Satellite A15-S125 Cooling fan
Hi, the part number of your fan Cooler is: P000377310 type this code in Google, good luck
Aug 10, 2008 | Toshiba Satellite A15-S129 Notebook
Cooling Warning Setting pop-up
Check Toshiba.com for an upgrade on the thermostat.
Does it feel too hot to you yet?
Jun 11, 2008 | Toshiba Satellite A15-S127 Notebook
System warning pop-up
Are you sure that nothing is overheating? If your cpu fan is turning too slow it won't disipate the heat. Do you have a program showing cpu temp:? I would take the access off the bottom and make sure the cpu fan is clean. If that is not the problem I believe you can turn the warnings off in the bios settings
Jun 08, 2008 | Toshiba (K000016310) Cooling Fan
Toshiba cooling system
If u have a laptop (that's what i found out that toshiba Qosmio is ) then is no problem that the fans stop (as long as the temp. is within the normal working margins ). U might have a setting problem - a bad software, managing the cooling system; - a bad BIOS setting regarding system temperature protection; - or the temperature detectors malfunctions, and must be changed (if possible)
Jan 14, 2008 | Toshiba (K000016310) Cooling Fan
Antec TriCool 3.125" LED CPU Cooling Fan - Blue Logo
203 people viewed this question
Top Antec Computers & Internet Experts
Steven Wander
Steven Wander
Dimitar Todorov
Julie Endres
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
