Question about Home Security
MY DIGI DOOR MOTOR LIGHT STAYS ON, WHAT COULD BE THE PROBLEM
How do you programme remote control to digi garage door motor ii
This youtube video may help you. Google docs is free, you can download the manual here: https://docs.google.com/document/d/1xfJFOC1aMNmSsDHtICYyC9bf1-z1oJiriAGHH6VjGBM/edit
Nov 16, 2016 | Building Materials
Hi,I have a Digidoor 3 motor & it open & closes as normal but after the garage door is closed it drops the chain about 15cm then slums it back into the track. Can anyone help me out please?
will need a digi door or roller door mechanic in your area
head office ? use contact us
DigiDoor Garage Door Motors Installations Repairs of DigiDoor 1000N...
three motor makes it harder
door drop is 15 cm is not a good thing
chain system needs to be retention ed
motors synchronized
event track may need to be re aligned
Oct 31, 2016 | Building Materials
I need to programme a remote for digi one 1000n garage door motor
the remote learning process id covered in detail in the operators manual
have the installer /retailer to come out and do ti for you
Oct 08, 2016 | Building Materials
How do i programme a digi key remote to my digidoor II garage motor, my original fell and no i bought new digi key remote. plz help
How to program a digi-key remote control :
- on the wall console press the light toggle button to switch the light off.
- press and hold the light toggle button, the light will come on and after 5 seconds go off.
- release the button and the light will go on again.
- within 30 seconds press the required key on the digi-e key transmitter (your remote control). The light on the digidoor ac/dc will go off.
- to confirm press again the same button the transmitter (remote), the light on the digidoor ac/dc will flash foor times. Done
Apr 22, 2011 | Audio Players & Recorders
I bought a second hand Digidoor 1 with garage door. The door opens and closes perfectly when the digidoor is off. When I power up the digidoor the motor will not open the garage door when the door is...
You are receiving interference from the digi door. You will have to return this unit and go with a different one on a different frequency. Chamberlain makes a clicker that would work well with that unit. Thanks BB
Sep 21, 2010 | liftmaster Chamberlain Garage Door Opener...
My stanley garage door opener motor runs but it won't open or close my door
If the motor runs and the chain does not then you have stripped the gears and will need to replace them. If the motor runs, the chain moves but the door does not move then the trolley is not attached or needs to be replaced. Thanks BB
Jul 27, 2010 | Digi-Code Digi Code 5202 Garage Door...
Hinari microwave doesn't cook
hello mam
i am having the solution for this problem check the lock terminals for loose connection and if its working and check the magnetron which produses the heat inside the microwave.
Sep 25, 2009 | Microwave Ovens
Home Security Logo
64 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
