Question about Teac Legacy DR-L700 DVD Player
Have a new refurbished teac 700 legary dvd unit and cannot get dvd set up or see films on tv?
I switched over old unit for refurbished exactly same connections. I cannot get dvd to show on tv screen. also cannot see dvd set up on screen so cant access when i press set up in shows only progscan OFF seems to be linking tv to dvd. I have Svideo link
cell expert
  • 30 Answers
SOURCE: teac dvd rom
CLEAN IT LENS BY A LENS CLEANER OR GET IT CLEANED BY A PRO..
Posted on Dec 01, 2007
SOURCE: TEAC MP111
If one of the files you uploaded has a different format (e.g. OGG), or a name with special characters,... the MP3 player will FREEZE.
Connect the device to your computer (USB port), remove the unrecognized files, unmount properly, empty the trash while unmounting.
It should work again.
So, when you upload additional files, do it gradualy. It will be easyer to identify the faulty...
Have fun, good luck
Posted on Jan 18, 2009
SOURCE: trying to set the clock on my TEAC CD-X60i - when
You have to set the clock with the unit in standby mode.
Posted on Dec 30, 2009
SOURCE: Teac MCDV 138 shows High
hi ...agnsesoh...i got the same problem since last night...did you get any feedback on this. ( same brand..same model)
Posted on Sep 12, 2010
SOURCE: Teac MCDV 138 shows High Definition Mode on TV
hi ..we're you abel to find a fix for this problem?..i got the same problem too since last night
Teac 6010 reel to reel makes static when not playing.
These units are old enough to need new electrolytic capacitors installed in them. I have seen wind like sounds and frying eggs type sound that are all resolved by a new set of caps. These things are from the Vietnam war era and when I was at Teac in the 80's they were considered old then.
Dec 17, 2016 | Teac Audio Players & Recorders
THE UNIT DOES NOT READ DVD'S WHEN LOADED.
the answer is "YES". You can replace the laser (lens), that's the only option you have left since cleaning the laser (lens) did not solve the problem. This shows that the laser (lens) is dead. You need a brand new one.
So go ahead and replace the laser unit, its a very good idea.
Good luck.
May 28, 2010 | Teac DV-L800 DVD Player
I have a Teac LCDV2655HD lcd tv and the dvd will not eject from the dvd player when I use the eject button. My lcd tv is only 6 months old. Any ideas how to eject the dvd. Also when I press the dvd button...
Sometimes there's a little pinhole on the cover where the DVD should exit. If you have one, straighten a paperclip and shove it into the hole. That should physically open the drawer/door.
Feb 18, 2018 | Teac DV-M5000 DVD Player
Picture roll, loss of vertical sync.
I opened the cover, found nothing smoked or loose, no tweaks available, in short there was nothing I could do without diagnostic gear. All other sources in my system were fine, so simple substitution confirmed the problem was output of Teac dvd player. Taking it to a repair shop would be $50 up front for fix-or-not... So, I went to Walmart and replaced it with a Sony DVD player for about $40. Regret loosing the look of matching components with my Teac receiver, cassette player but it's job is to play movies. Fixtya!
Jan 04, 2010 | Teac DV-3000 DVD Player
What is a USB tv box and what does it do?
This is Teac's description of what this unit can do.
TEAC's TV Tuner enables video and regular Television viewing on a notebook or desktop PC. Simply, turn your notebook PC into a portable TV! TEAC's USB TV Tuner is the smallest video capture USB2 device available today. The tuner allows you to watch, capture, and record your favorite TV/CATV, VCR, DVD or Video Camcorder on your PC, then burn them to VCD, SVCD or DVD disc with your CD or DVD Burner. Simply connect your analog cable or antenna to TEAC's TV Tuner, grab the remote and you are all set! The Tuner can be used to record video files or TV programs in DVD quality. With the bundled MPEG-1/MPEG-2 Encode software, recording a favorite video or TV program can be easily done. MPEG editor can be used to edit video files, which can then be burned into VCD, SVCD, DVD by using CD/DVD Maker software. The Tuner can support multiple video inputs, including S-Video, Composite Video, Coaxial/Antenna TV connector. It is a DVD quality TV/Video recorder.
Dec 08, 2009 | Teac USB2 TV TUNER (USB2TVTUNER) Video...
Can't change TV to AV input.
dont bother trying to do it but then i got the same problem :)
Nov 30, 2008 | Televison & Video
Hi, I bought a teac dvd and 5 speaker surround sound system yesterday. I am having trouble setting it up. I want to run the TV sound through it as well, but at the moment it is only going through the sub...
Whoa,ok.Sounds like things aren't connected properly.The first step is to disconnect the TV and concentrate on getting sound from a dvd or cd.Read the owners manual and double check that the speakers are hooked up correctly and that the unit is in the correct surround mode.Next, connect the TV.Use an RCA cable to go from an "Audio out" jack on the TV to an input jack on the Teac -e.g. "Aux, TV, etc.If your TV doesn't have the proper jack, I'm afraid you're out of luck.
Jul 21, 2008 | Teac Audio Players & Recorders
Connections
Hi If I'm understanding what you have written, the new DVD should hook up exactly the same way your old one did. You connect the red and white cable from the "Audio out" connectors on your new DVD to the "Audio In" connectors on the RF modulator, then connect the Svideo out on the DVD to the Svideo connector on the RF modulator. Then put your TV on channel 3 or 4 depending on what the switch on the modulator is set to, and all should work fine. I would advise you hook your old one back up, then if it works, simply unplug the cables from you old DVD and plug them into the proper jacks on the new one. This eliminates bad cables. If you then get sound, but no picture, the DVD may be set to progressive scan (check manual for procedure take it out of that mode),If you get nothing, then I suspect there is a problem with the new DVD player. The TV/VIDEO switch they mention, would be a switch on the TV or TV remote if you had a newer TV with RCA inputs.....You don't, so disregard that, it does not apply to your TV. You would not need the RF modulator if your TV had that switch. Good Luck!...These things can be a pain, I hope this helps!
Nov 28, 2006 | Daewoo DVG-9200N DVD Player
Teac Legacy DR-L700 DVD Player Logo
35 people viewed this question
Top Teac Televison & Video Experts
bengsoon Neo
JOHN TOPLISS
Are you a Teac Televison and Video Expert? Answer questions, earn points and help others
