There's a green line running down my Samsung led tv.its only 15 months old
pgh_pa_guy
  • 2992 Answers
SOURCE: toshiba 19inch lcd tv green line down screen
A solid line down or across the screen is due to problems in the display itself. Unfortunately, there's no way to repair it because the bad circuitry is integrated into the display. The only cure is display replacement.
Not the solution you want, but that's how it is. (With the huge number of transistors that are part of the display, it's actually amazing there are as few failures as there are.)
Posted on Jan 22, 2009
jerryg50
  • 1689 Answers
SOURCE: plasma tv
If the set is under an extended warranty get it serviced.
On rare occasions it may be the Plasma screen itself that is defective. In more than 90% of the cases it is a circuit board that has to be changed.
This can be an addressing problem to the screen. The failure can be in the screen addressing circuits or probably in the processor circuits. After or during the signal conversion to the data buss, there are many areas of the set that can actually cause missing pixels, lines, or ailiasing in the image.
The service tech will swap out boards to find the fault. Once he finds the defective board, he will quote you for a new board.
Jerry G.
Posted on Apr 27, 2008
circuitworld
  • 335 Answers
SOURCE: green line down left side and geen snow
Horizontal or vertical bars on the screen could be from an ac line interference, adjacent magnetic field, bad input wire connections.....especially HDMI connector cables. A bad HDMI cable causes all kinds of unwanted picture interference. Check the conditon of all connection wires for proper fit and function. Keep in mind the method in which you connect your tv will result how the tv performs. As well this line problem could be a circuit issue too, requiring a technician to look at it.
Posted on Jan 04, 2009
  • 231 Answers
SOURCE: purple line down tv
tv needs repair ..possible bad buffer board or logic board bad and or possibly a bad panel ..
Posted on Mar 18, 2009
  • 8457 Answers
SOURCE: Black line Down middle of 50" plasma screen tv
The tv T-CON board it is dying to causes this problems.This T-CON board sit in the middle at the bottom of the tv plasma screen panel.Try website like Ebay.com to buy a whloe new refurbish T-CON board for the replacement.
Posted on Jul 18, 2011
From last 15 days, my TV screen become green, purple and pink after running of 10 - 20 mints and also horizontal lines in upper side. please give the solution
Horizontal lines are generally caused by panel issues, you can check the cables into and out of the tcon board and see if that helps, you could replace the board but I don't think it will fix it
Mar 16, 2018 | Samsung Televison & Video
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
Samsung 50" led un50h6350. The TV is about 18 months old and the picture went out, the audio and back light are working. I've replaced the t-con board and that didn't fix it. Someone please help!
Samsung LED TV Screed goes blank periodically for 1 sec - Forums ...
CNETJun 11, 2015 - Lately, my Samsung LED TV's screen will black out from 1 -2 seconds then come back. The TV has been ... The TV is about 6 months old. .... I've only notice this when I'm watching in HD. ... by Stlouib / January 13, 2012 11:18 PM PST ...Mine does the same thing - picture goes black for 1 - 2 seconds and then comes back. Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Jun 11, 2015
Are there still capacitor problems with Samsung TVs?
Dec 21, 2015 | Samsung Televison & Video
15 month old samsung tv - has sound but no picture
If it is an LCD or LED TV then the problem is likely to be the inverter board(s).
Mar 02, 2015 | Samsung LE37B550A5 37 in. HD-Ready LCD TV
Samsung Plasma won't power on
this is not a capacitor problem. set is only 18 months old - has something to do with x y sustain boards not allowing smps to power on the high voltages.
May 27, 2013 | Samsung Televison & Video
Green line running down my Samsung led tv
Will you please provide more details about the problem you faces with this TV?
Jan 14, 2013 | Televison & Video
SamsunG MODEL LN-T 4671F 6 HAS GREEN LINES IN PICTURE CAN STILL WATCH TV.
The screen has failed. It can't be fixed, but you can get a new screen fitted at the shop.
Oct 12, 2012 | Samsung Televison & Video
I have a red and green line running up the tv. It isn't overbearing but the tv is only 5 months old.
You have a bad panel. Take your TV to a service center, you are covered under a 1 year warranty.
Jul 28, 2011 | Apex Digital Televison & Video
Problem with the White vertical lines on Samsung 50 in DLP
Get DMD board part # and shop for best price.......
I will do the same......let me know.....T.
Nov 05, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Televison & Video Logo
1,043 people viewed this question
Top Televison & Video Experts
