Question about MSI G31M3-L V2 Motherboard
Long beep mother board give long beep when start
  • MSI Master
  • 3,606 Answers
Hello here is a list of beep codes:
http://www.computerhope.com/beep.htm
The problem could be the ram modules, or the graphic card, or the power supply failing.
Try remove the ram module, and insert one, and try to reboot.
Please take antistatic precautions, when working on the mainboard.
Here is the msi homepage:
http://www.msi.com/product/mb/G31M3-L-V2---G31M3-LS-V2.html#/?div=Manual
For downloading the manual.
You need adobe reader to read content.
Good luck
Posted on Jan 15, 2013
P 4M800PRO-M V1.0A ECS mother board does not beep ,it gives click sound . but some time it start and run good condition .and next restart ,mother broad doesn't start
Sounds like that board is on its way out. Had a good run too!
I'd seek out a complete system upgrade.
Small things you could try is reseating the RAM and testing it with a new power supply.
Hope this helps!
Sep 16, 2014 | Computers & Internet
I have a 848p-A7 motherboard with a intel pentium 4 processor. I just got everything, set up the cpu fan, and etc. but whenever i try to start up the computer, the onboard speaker keeps going off. It's a...
1. Along beep on a motherboard indicates something is connected backward such a a fan or a data cable to the hard drive.
If it is the hard drive cable then you must have pin 1 connector turn around and therefore the mother board is giving a warning.
2. You may have a power supply failure that is the power supply is not giving proper voltage to the mother board.
3. Your ram chip is not properly seated in the RAM slot or in backwards.
4. The CMOS battery to the mother board need to be replaced.
Sep 10, 2010 | EliteGroup 848P-A7 Motherboard
No ram beep is ok but there is no display
pls. replace with a new same rating RAM
Apr 06, 2010 | Intel Motherboard
I have a zebronics mother board with intel 845 chip. Now whem i power on that it give long beep and no disply,RAM is ok, then what i can do?
Hi ieb_amit,
Typically a long single beep indicates that your display adapter or card is bad. If you haven't put in a new graphics card, then I might suggest doing so, to eliminate the beep.
Good Luck
mark
Dec 04, 2009 | Computers & Internet
ASUS K8S-MX PC powers up but no display on monitor and no error codes. Hard drives spin and sounds as if it is in boot routine
OPEN UR CPU AND OUT UR RAM FROM MOTHERBOARD AND START UR PC WITHOUT RAM IS IT BEEP OR NOT IF IT BEEP THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC IS IT OK
IF NOT THEN PICOUT BATERY CELL 2032 FROM MOTHER BOARD AND THEN START UR PC
IS IT BEEP WITHOUT RAM AND CELL IF YES THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC
IF IT IS OK THEN CHANGE UR BATTERY WITH NEW ONE
IF UR PC BEEP WITHOUT RAM BUT NO DISPLAY WITH RAM THEN CHANGE UR RAM WITH NEW ONE.
Jul 01, 2009 | ASUS K8S-MX Motherboard
Emachine will not power up
By nothing else, from a technical standpoint this would mean literally nothing, the CPU fan, power supply fan, aux fan, disk drive not spinning up, etc. My experience with EMachines is their motherboards aint the best, have been known to take out hard drives and other peripherals to the mother board. If you are technically inclined the first thing to do is to bare out the system, Power Supply attached to the Mother Board w/ Cpu Monitor and Keyboard no Hard Drive and no Non esential boards installed, very carefully remove the memory and start it up all should be fine except it should give you a long beep from the PC Speaker indicating the Mother Board is aware there is no memory installed if it will not do this most basic of tests this is not good. If it does give you a health beep continue to install one item at a time, first the memory, the display should, if working, tell you there is a boot failure, of course, the hard drive is not connected, do so and keep on testing. Without knowing what type of mother board you have, most likely an AT with integrated peripherials the process to determine exactly what the problem is would take hands on trouble shooting. If you dont get the beep indicating the mother board cant determine if memory is installed and truley nothing else is on it is more likely the mother board. There are several good ones online that will fit your case if you want to go this route. Or is it time to upgrade ?
Jun 04, 2009 | E-Machines eMachines Desktop PC
No Display
hi, when you start your computer its giving a beep if not check your memory(Ram) remove it and check it your motherboard giving a continous beep, if yes replace your ram
Sep 26, 2008 | MSI K8MM-V Motherboard
Mother board
have u checked the power supply and all of its connections and the system board fan to make sure they are operatring correctly and also is the beep code a straight 5 beeps or is sthere any thing else kplease let me know so i can try to give you some more help
Aug 18, 2008 | EliteGroup P4VMM2 Motherboard
Intel 845 chipset mother board no reaction - expecting solution
this is normal No-Ram. No-Beep.
The ram is all part of the bios analysis beep codes.
install memory, and setup the board to the manufacturers specification.
1 beep at post is normal on many bioses.
Mike @ compurepair.
Feb 22, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
MSI G31M3-L V2 Motherboard Logo
148 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
