Question about Hitachi (hts545050b9a300) 500 GB SATA Hard Drive
Drivers windows 7-64 laptop needs drivers for hitachi hts545050b9a300 500 gb external drive
Plug in Acer external harddrive, has a Hitachi hts545050b9a300 usb drive inside, computer cannot install drivers for this device
  • Hitachi Master
  • 27,725 Answers
Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps.
Posted on Jan 14, 2013
5 Suggested Answers
  • 146 Answers
SOURCE: windows xp will not restart with usb plugged in
Sir, your PC might have been checking for external devices which plugged in to boot from. Thats wrong. So get into the bios of your computer while startup and change the 1st boot device to your computer's hard disk. And its a bad idea, starting your computer with a usb device plugged in.
Posted on Jun 29, 2010
drifterK
  • 4924 Answers
SOURCE: I installed Windows 7 and
Try to install it ...Probably the installation will be automatically ...Just insert it ..and after that go to device manager if it do not start auto ..and in the device manager list click right on it ..and update driver...This will kick it to start the add new hardware wizard and install it ..This is a removable storage device ..and it should have been given a drive letter automatically in Computer folder..anyway ..Look again first maybe you missed it somehow ..and if it came with a driver install it ..or ..much more simpler is to get into control panel and start the add new hardware wizard directly and let it be installed ..if the computer do not sense it when you add it in usb ...
If it wont work ...let me know more..
Posted on Mar 22, 2011
spyd3r
  • 82 Answers
SOURCE: i have a extra hitachi
1. Decide which hard drive will be the startup (master) drive. If this drive was the startup drive previously, or if it's a new hard drive, then the master drive designation will already be set.
2. To change the designation of a new drive to be a slave drive, skip to step 4.
3. To change the designation of an existing drive to be a slave drive: Turn off the computer, unplug the power cord, remove the drive from its drive bay, and disconnect the drive from its power cord and ribbon cable.
4. Check the hard drive documentation or the label on the drive itself for master/slave jumper settings.
5. Find the jumpers on the circuit board of the drive. Jumpers are plastic plugs with metal sleeves that form a circuit between a pair of pins. Jumper locations are labeled on the board with a J followed by a number (such as J20).
6. Use tweezers or very small pliers to remove or reposition the jumpers to the configuration shown in the documentation or on the disk label.
Say "Thanks" by clicking the thumb icon in the post that helped you. Please click "YES" in solution that solves your problem as "was this helpful?"
Posted on Apr 18, 2011
bronk50
  • 27725 Answers
SOURCE: the external harddrive cannot
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Posted on Jun 24, 2011
MY QUESTION IS HOW DO I Disable the "SECURITY FREEZE LOCK" on my hitachi HTS54503289a300, 320 GB sata hard Drive? originally WAS INTALLED IN MY ACER TRAVELMATE LAPTOP NANUFACTURED IN 2012 BUT THE LAP
Maybe if you can format the disk-but you loose data, maybe there is a program that can do it, probably in linux, or bootable itself, maybe ask acer for master password or something, if you still own original laptop and it runs then try to remove disk encryption while the hdd is accessible with laptop (i think its in bios), otherwise the hdd may be unusable to prevent data theft. you can plug any sata hdd into any sata device if you can hook all the cables, no compatibility issues there. try googling and youtubing for more answers
Sep 14, 2014 | Computers & Internet
Drive address setting with Hitachi (39T2703) 60 GB SATA Hard Drive
i'd go to the hitachi website and download the driver to your pc,then install/update,look on ystem administrator specs for info about hard drive,simple
Jun 10, 2012 | Hitachi (39T2703) 60 GB SATA Hard Drive
Hard drive clicks, fails to read but powers up. Approx 100GB of music files held and needs recovering. Laptop initially picks up drive on connecting to USB port but then drops out due to read failure.Drive...
Inside that plastic external case of the Hitachi XL 1000 external harddrive, is a regular desktop computer sized harddrive.
It is a SATA type of harddrive.
It is 3.5 inches across in Width. (3 and a half inches)
1 TB in size.
Looks similar to this example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5589521&CatId=2459
On the back end of the Harddrive is where it's power cable, and data cable are attached.
Inside the case of the Hitachi also is a small circuit board. (PCB or Printed Circuit Board)
The SATA harddrive is connected to this small circuit board.
The small circuit board, or Interface PCB , is attached directly to the Harddrive.
Or cables (Wires) are used to connect it to the Harddrive.
The Interface PCB is connected to the computer, via the USB cable that is attached to the Interface PCB.
It is this small circuit board that usually goes bad.
(Unless the external harddrive was on, and dropped. Then the problem is the Harddrive)
There are two solutions;
One, buy an 3.5 SATA external enclosure, and use the Harddrive as an external harddrive again.
Two, install it as a Slave drive in a desktop computer, and retrieve all your information. Burn to disk/s, or flashdrive/s.
When using a SATA harddrive as a Slave drive, there are NO jumper pins to mess with.
DO NOT change any jumpers on the back of a SATA harddrive.
(These are for the factory)
This is an example of a 3.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
There are no guides to open a Hitachi XL 1000's case, to my knowledge.
It isn't something the manufacturer wants stated.
However opening the external enclosure (Case) isn't that tough. It falls under the same as this model,
http://www.youtube.com/watch?v=hQ_vjyvK28A
Here we see at 3:00 through 5:00, that the Harddrive is attached directly to the Interface PCB.
Just remove the Harddrive from the chassis, and unplug it from the Interface PCB.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 02, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
I have a Hitachi external USB hard disk 320 GB. it was working fine at may laptop but when i tried using it with computer, the Windows cannot detect the USB Drive. i tried it with 2 computers. but its...
i have a Hitachi external USB hard disk 320 GB it was working fine at may laptop but when i tried using it with the computer ; the windows cannot detect the USB Drive . i tried it with 2 computer . but its still the same .pleas help i badly need my files
Dec 05, 2010 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
I have several computers at home, and none og them can recognize this portable device. Hitachi 250 GB Mod: SDM/250RW
1) Power:
It may be the problem that occurs with a lot of USB powered devices jrherrer. Not enough power provided.
The USB cable plugged into the computer, provides signal wires for transferring information back, and forth, and also provides 5 Volts DC for power. (Two D cell flashlight batteries produce 3 Volts DC)
http://en.wikipedia.org/wiki/USB
[ Below shows the Signal pins, and the Voltage pins of the USB B Mini style connector, (Male), used to connect to the SimpleDrive Mini external harddrive,
Pin 1 is for the 5 Volts DC Positive (Wire color - Red)
Pin 2 is for the D- Signal (Wire color - White)
Pin 3 is for the D+ Signal (Wire color - Green)
Pin 4 is not connected. (Or sometimes joined to Pin 5 with a Resistor)
Pin 5 is for the Ground (Wire color - Black)
Just added info in case you wanted to know ]
From what I see the SDM/250RW has a USB port on the side, and a DC Power Jack, used for an AC adapter, also.
(Round port with a pin in the center)
http://www.hitachigst.com/tech/techlib.nsf/techdocs/0C876B7AB91B23988825773F006BEA02/$file/SD_Mini_DS_final.pdf
From what I see stated from Hitachi, and sellers on the 'net, the AC adapter may not be provided.
Many of those who provide a review state that both the USB cable, and the AC adapter is needed to provide enough power. Seems to be a power hungry external harddrive
It's a 2.5 Hitachi SATA laptop harddrive inside that external case. (The Harddrive is 2 and a half inches across in Width. Common size used for laptops)
When using an external device powered by a USB cable there are general guidelines to follow,
A) The USB cable should not be more than 2 feet in length
B) Connect the device directly to your computer, instead of through a hub, or other device, unless the USB hub has it's own power.
2) USB cable:
Could be a faulty USB cable, although I imagine you have tried different ones by now.
3) Interface Circuit Board:
The Hitachi SATA 2.5 harddrive inside the SImpleDrive Mini SDM/250RW, plugs into a small circuit board located inside that external case.
Components on the circuit board may be fried, or the Harddrive may have come loose from the interface.
Loose from the interface
To explain;
The back of the harddrive has connector pins sticking out.
The interface has socket holes which the pins insert into.
Faulty circuit board
The external case of the SimpleDrive Mini SDM/250RW can be carefully opened up, and the Hitachi SATA 2.5 harddrive extracted out.
Another inexpensive external case for a 2.5 SATA harddrive can be procured, and the Hitachi harddrive put in it.
Example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3743049&CatId=2781
Nov 22, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
I want a converter for Hitachi HTS541612J9SA00 120 GB SATA Hard Drive to usb do you know wich one I need..?
You need a 2.5" inch SATA to USB external harddrive enclosure.
since its a laptop hard drive you need a small case.
for example this one http://www.amazon.com/2-5-SATA-HDD-Enclosure-Black/dp/B0018TCB0O
Aug 07, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
I have a acer aspire t180 desktop with a 250gb hitachi scsi (ide) hd. I would like to know which hard drives are compatible so that I can exchange it. thanks
It's a SATA harddrive, not SCSI.
Serial ATA
Acer Support > Aspire T180 > Specifications >
http://www.acersupport.com/acerpanam/desktop/0000/Acer/AspireT180/AspireT180sp2.shtml
Will use up to a 400GB SATA harddrive according to Acer.
IDE stands for Integrated Drive Electronics.
Another name is PATA.
Parallel ATA
Used to distinguish between IDE and SATA.
1) http://en.wikipedia.org/wiki/Integrated_Drive_Electronics
2) http://en.wikipedia.org/wiki/Serial_ATA
3) http://en.wikipedia.org/wiki/SCSI
Exchange it?
Your harddrive has the Operating System on it.
A new harddrive will not have an O/S on it.
(Windows XP is an example of an O/S)
It would be much easier to install the harddrive you wish into an external enclosure, and plug the external enclosure's USB cable into your T180.
One example of a desktop size harddrive SATA external enclosure,
(3.5 inch SATA external enclosure.
3 and 1/2 inches across in width, for a desktop harddrive.
Laptop HD's are 2.5)
Jun 18, 2010 | Acer Aspire™ T180 PC Desktop
Hitachi DK23FB-40 not detected
the external hard drive casing may need a driver for some operating systems
and then the unit must be in the on postion
Jul 19, 2009 | Hitachi TravelStar DK23FB (08K1427) 40 GB...
Hitachi easy drive 1tb problem
I have a 640 GB easy drive. It hit the floor and now when I turn it on, all I get is beeps and hear movement in the harddrive but it does not work
Jul 09, 2009 | Hitachi 1TB External USB 2.0 Hard Drive
Hitachi (hts545050b9a300) 500 GB SATA Hard Drive Logo
384 people viewed this question
Top Hitachi Computers & Internet Experts
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
