Question about Samsung Surround Speaker System 2 Speakers Ps-ds2
Where can i find speaker brackets for samsung ps-ds2
Connecting sharp soundbar to new samsung smart tv?
Your TV does not have an audio out. If you want sound thru the sound bar then you have to hook it to your cable or satelite sourse.
Mar 21, 2013 | Samsung Televison & Video
I have a samsung subwoofer sealed box for an entertainment center, one of the wires came loose inside the box, how do i fix it
You cant fix it without virtually destroying the cabinet,as most active samsungs are glued together,designed to be replaced rather than repaired,sadlyUnless its a wire on the speaker,about the only removable part.Even the amplifier is inacessible on later models,such as the ps-we450 making any fault unrepairable.
Aug 09, 2010 | Samsung Audio Players & Recorders
DS2 to DSS format
Dss Player Pro release 5 has the option to automatically convert to dss or wav upon download.
Dec 20, 2008 | Olympus DS-2 Digital Voice Recorder
1999 Audi A4 Rear Speakers
The large block is a factory amplifier - in your car (as was in mine) you had a partially-amplified system. The front speakers were driven at speaker level from the head unit, but the rears were fed a line-level signal from the head unit to the amp, which then boosted to speaker level. The harness then sent the speaker level signal to each rear speaker.
What you can do is fit your new head unit. The fronts will interface perfectly with no issues. For the rear, run new wires from the adapter harness at the back of your head unit, back to the new rear speakers, and connect them directly. Then everything will work as it should.
Dec 17, 2008 | Alpine DDW-F30A Car Speaker
Rear speakers in audi 1999 audi a4
You don't want to fit that - it's the factory amplifier for the rear speakers (the rears are amped, the fronts are not). You need to run new wires from the head unit back to the new rear speakers so that the speaker-level outputs from the new head unit are used to drive the new speakers.
Dec 16, 2008 | 1999 Audi A4
Convert ds2 file to dss
Best option is to get the person using the recorder which creates the .ds2 files, which is likely to be an Olympus DS-5000, to set the recorder to record audio in "classic mode" which will produce .dss files. Here is a YouTube video on how to set the DS-5000 to record in classic mode.
http://au.youtube.com/watch?v=9qonqT3HwzA
Jun 18, 2008 | Olympus DS-2 Digital Voice Recorder
Speaker blown
check samsung parts had the same problem with speaker ordered replacement from samsung parts store works perfecct
Nov 06, 2007 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung Surround Speaker System 2 Speakers Ps-ds2 Logo
89 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
