Question about Pentax EG-2930K Gastroscope
Pentax EG-2930K Video Gastroscope
Connected parties Video Camera Cable Board
How do I connect my K7 to a 1394 socket
Your Pentax K7 lacks firewire (1394) connectivity, so a connection to a fireware jack will not be possible without purchasing an inexpensive Firewire to USB adapter . From the manual:
Available Ports:
  • USB 2.0 hi-speed, AV out, HDMI out, DC in, cable switch, 3.5mm stereo microphone.
  • Video out: HD (1080i30, 720p30, 480p30), NTSC, PAL
  • Printer interfaces: n/a
The I/O (input /output) panel on a Pentax K7 camera.
You can connect a USB cable from the "PC/AV" on the camera to your computer's USB port with an appropriate cable to transfer image files for editing, etc. Additionally, you can send video directly to a TV with an appropriate cable via the camera's HDMI jack.
I hope this helps!
Oct 04, 2013 | Pentax K7 Digital Camera
When the Pentax USB cable is connected to the computer USB outlet pictures do not appear on computer
make sure camera is in the play mode and powered on. If this does not work, sub out the cable to make sure it is not the cable. The last thing is to reinstall the usb ports - this is almost never necessary - but to do this start/control panel/system/device mgr, find usb root hub and right click uninstall to each. reboot and they will reinstall automatically.
good luck
Jun 16, 2011 | Pentax Optio M60 Digital Camera
MY SONY CAMERA DCR TRV 260 IS NOT RECOGNISED BY PC WHEN CONNECTED WITH USB CABLE.NO ICON COMES IN MY COMPUTER.HOW CAN I TRANSFER MY VIDEO TO PC.
Use a firewire cab le to connect to the computer. Then open Windows Movie Maker to capture. With Digital-8 you may have to start the camera manually. eg. push the play button on the camera
Apr 29, 2011 | Sony Handycam DCR-TRV260 Digital Camcorder
What other brand lens fit this camera? Thank you. the camera is a P30 35mm
All Pentax bayonet mount lenses.(Third party) lenses:Vivitar,Sears,Tamron,Later Chinon,...In Reality almost all third party lens maker have produced bayonet mount lenses,and most of them are marked with a PK.Best third party lenses are Vivitar.Hope this helps.
Feb 07, 2011 | Pentax P30T 35mm Film Camera
I need a driver for Pentax *istDL2 digital camera.
Bypass the USB cable and buy a card reader.
Your camera takes an SD card so all you need is a SD card reader. You take the SD card out of the camera and stick it into the card reader and that goes into your USB on your computer.
I believe ritz camera sells them for around 15 dollars. You can get them at ANY place that sells electronics. Such as Best buy, Ritz camera, penn camera, staples, walmart, target, etc.
You really dont need the USB cable considering SLR have no built in memory.
A card reader would serve you better.
******* As far as your camera not working when hooked up to your USB, some cameras require you to install there software. This means its not a "Mass Storage" device. Think of it like an Ipod, it hooks into the USB, but you need itunes to see it.
or you can try this website for software
http://www.pentax.jp/english/support/digital/photo3_win.html
This is for the PENTAX PHOTO Browser 3 and PENTAX PHOTO Laboratory 3
Mar 30, 2009 | Pentax *istDL2 Digital Camera
Bad USB conection?
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Feb 11, 2009 | Pentax K100D Digital Camera
Black screen
Was the camera turned off, it must be turned on and set to USB to PC in settings menu.
Jun 20, 2017 | Pentax Optio S5i Digital Camera
Computer connection pentax optio m40
This colud be
1. a cable fault
2. camera3. memory card fault.
The only weay to discover which is by experimentation with the help of friends .
Connect the camera to another computer.
Try another cable.
Try a card reader if available.
Feb 11, 2008 | Pentax Optio M40 Digital Camera
Won't turn on at all
My Optio 33LF gave the same "card not formatted" message and then shut down completely at a family party.  I took it to the Pentax Canada depot which is nearby and the technician said the main circuit board was gone.  A C$130 part + labour estimate = time for a new camera !
Sep 17, 2007 | Pentax Optio 33LF Digital Camera
Pentax EG-2930K Gastroscope Logo
24 people viewed this question
Top Pentax Video Cameras Experts
Are you a Pentax Video Camera Expert? Answer questions, earn points and help others
