Question about Denon DCD-425 CD Player
My Denon DCD-425 CD Player will only play 1 or 2 tracks then stop of any cd. Tried cleaning cd lens but no better
  • Philip Homerstone Jan 16, 2013
    Perhaps a factory reset might help as I can play the tracks if I select them individually
2 Suggested Answers
cdj repairs
  • 68 Answers
SOURCE: Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Regards.
http://www.audiovisualservices.info/
Posted on Dec 13, 2008
I have a dcd 1650 and it won't read discs, but sometimes it does, I have checked and cleaned lens
A Laser Lens malfunction will cause this to happen and is a common problem. This can be fixed at home if a new Laser Lens or Laser Lens w/ transport can be found for your unit. I used ebay to purchase a new Laser Lens for my Denon DVD 5900. The part is also sometimes available from parts stores like Parts Express for a premium, $100+ Parts Express vs $17 ebay in my case. I would recommend purchasing a FACTORY SERVICE MANUAL from an online vendor. The manual will cost between $10 - $20 and is downloadable. The installation is very straight forward. The part that might not be clear would be the grounding shorts on the new Laser Lens. THE NEW LENS COMES SHORTED AND AFTER THE PART IS INSTALLED IN THE PLAYER THE GROUND SHORTS MUST BE UNSOLDERD FOR IT TO WORK CORECTLY. The part comes this way to protect the Laser from static shock damage.
The repair on a Denon DVD 5900 cost $30 and took about an hour to complete.
Jan 07, 2013 | Denon DCD-1650 CD Player
I have a Denon dcd 600 cd player. Old but little used and in good condition. Used to put in a cd, close the drawer and the entire display would light up, the disc having not been read at all. After...
it's most likely the belt that drives the cd tray has perished over time and certainly if you tilt the player to help it, that's just gravity giving it a push. replace the belt and all should be ok. hope this helps?
Jan 06, 2010 | Denon DCD-425 CD Player
Player stops mid track and shows ''no disc''.
HELLO
Have you tried cleaning the lens? It's incredible how a dirty lens can cause so much grief! You'll need the CD player cover removed and powered off then get some isopropyl alcohol and a cotton bud. Wet the bud but not too much get any excess moisture off.
Using a careful circular motion clean the lens, let it dry and try the player again. If this does not cure the problem, you may have a defective laser and that will need replacing.
ALL THE BEST (:-)
Oct 04, 2009 | Audio Players & Recorders
Have a Denon DCD-520 and it skips forward and back while playing
Hopefully, it may just need cleaning and lube.
I have a Denon DCM-460 purchased from Goodwill a couple days ago and had problem with one CD-R skipping and stuttering toward the end.
Cleaned the CD which helped a little but still started skipping and stuttering.
Noticed a scratch toward the outer end which I suspect is where the problems occurred.
Anyway, last night I cleaned laser, rails, lubed spindles and moving parts. I used 99.9% alcohol to clean. I used a light teflon oil (Tri-Flow) to lube spindles and rails. And white electronic grease where you see remnants of white grease.
Today, I now played through the problem CD-R with no problems.
Assuming placement is level and stable, certainly worth a try and the effort.
Feb 01, 2009 | Audio Players & Recorders
Regards.
Nov 28, 2008 | Denon Dns1000 Table Top CD Player CD...
DENON DCD-825 CD PLAYER stopped playing
Mine did the same and I cleaned the laser lens and it cured it
May 22, 2008 | Audio Players & Recorders
Having a problem with my CD Player's drawer
This has to do with a mini switch inside the door mechanism that it pushes once but with the bounce phainomenon in electric pulses it thinks that you pushed the cd door inside manualy and it tries to close the door. Try replacing this mini switch. this will solve your problem.
Apr 15, 2007 | Denon DCD-425 CD Player
Denon DCD-425 CD Player Logo
51 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
