Question about Casio Sea-Pathfinder SPF40-1V Wrist Watch
My casio spf40 2273 module went crazy and and move from one screen to another by itself non of the buttens is pressed how do i restart it?
Keep the Mode button pressed for 5 seconds, it will then revert to normal
Posted on Oct 09, 2013
  • Kareem Hamimy
    Kareem Hamimy Dec 07, 2013
    Thanks alot, it has been like this for 2 weeks
  • Ronnie Nunez
    Ronnie Nunez Mar 15, 2014
    Thank u guys
  • Casio Master
  • 18,402 Answers
  • tomgold87
    tomgold87 Jan 14, 2013
    where is the part that shows how to restart it?
2 Suggested Answers
tbreeze47
  • 3083 Answers
SOURCE: My casio Sport spw-1000-2ver has OPEN marked on
It sounds like the battery is dead, or low. Take it in to a watch repair shop and get it replaced, and if that doesn't work, they can probably give you an estimate on repair.
Good luck, and hope this helps. If you just want to try to replace the battery first, the Walmart jewelry sections can do that cheaply (for the nominal cost of the battery).
Posted on Dec 10, 2010
How to adjust the time on a CASIO W-59 watch
Hi Harry,
Your Module number is 2271.
1. To set the time, press and hold button A (left top) until Seconds digits start to flash.
2. Press button D (lower left) to move flashing in the following sequence to change other setting:
Seconds >> Hour >> Minutes >> 12/24 Hour Format >> Year >> Month >> Day >> (Then back to Seconds)
3. While a setting is flashing, use E (+) (bottom right) and B (-) (top right) to change it.
Note: When in the 12/24 Hour Mode, use E and B to toggle between 12-Hour and 24-Hour Mode.
4. Press buton A to exit setting screen.
Your time should now be set.
You may also download a manual for watch/Module number:
http://pathfinder.casio.com/resource/manuals/module_2271.pdf
This should give you all the info you need to operate all the functions of your watch. Thanks.
Regards, Bill
Sep 27, 2010 | Watches
How to restart my casio module no 2271 watch
mcdevito75 here, I'm figureing you"ve changed the battery, Pressing the MODE button should re-start your watch. If you didn"t change the battery and your watch just stopped, try pressing the MODE or any button to re-start the watch. If nothing, change the battery and repeat the above instructions.
Jun 23, 2010 | Casio PRG-40T-7 Pathfinder
How to change the time on my Casio F91W watch?
first you push the bottem left butten three tmes than push the top left corner to move threw the numbers than use the bottem right butten to change it
Mar 28, 2010 | Casio F91W-1 Wrist Watch
I cant turn the hourly alarm off on my casio W-96H
Press MODE button to get to the AL (alarm) screen.
Press 12/24H button to toggle to the :00 screen.
Press ADJUST button to toggle SIG (signal) off.
Sep 12, 2009 | Casio G-Shock G2600 watch
Reset itslelf. WIll not display correct time, day, or year
My Casio wave ceptor keep resetting itself like this when the bottom right (D button) is pressed. I need to make sure I reset the city code or before trying to receive as it defaults to Tokyo. Press & hold the top left (A button) and date changes to city code. Scrole through codes using right bottons.
Hope this helps.
Nick
May 29, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Instructions for casio wave ceptor 4303
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Nov 06, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio wave ceptor wvq 202hdu ibver
I don't have wvq 202hdu but I have a waveceptor that had the same problem. After not being able to find a solution online, I went back and started playing with it and I figured it out on my wva-430a. Hopefully my instruction helps:
The problem is that the daylight saving time is set to ON (or maybe OFF) whereas it has to be set on Automatic (A). To change that on my wva-430a, I held the "Adjust/Display" button for three seconds. It showed "US 60" for me. Then I used the "Mode/Select" button to go to the next screen which shows CHI for Chicago (Central Time). Here you have to choose the city that corresponds to your time zone. Again by pressing "Mode/Select" it took me to the next screen which was the daylight saving option. The choices were ON/OF/A that could be cycled by pressing "Receiving/Set+" button. Set it to "A" for automatic. Then press Adjust/Display to see the last option for 12H/24H setting. Press Adjust/Display one more time to go out of the settings menu. Your watch should adjust itself immediately.
Oct 29, 2007 | Casio W752V3AV men's watch
Setting analog time
go to; http://world.casio.com/wat/download/en/manual/ and enter the module number code on the back of your watch - hopefully will tell you what you need to know. Hope this helps :)
Mar 13, 2007 | Casio AW80-1AV Wrist Watch
I can't even set my Casio Marine Gear watch.
Go to this link and with the four digit module code from the back of the watch you should be able to get a manual; http://world.casio.com/wat/download/en/manual/ Hope this helps :)
Jan 15, 2007 | Casio Marine Gear MTD1042A-2AV Wrist Watch
Casio Sea-Pathfinder SPF40-1V Wrist Watch Logo
155 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
