Question about Bugaboo Cameleon Baby Gear
How to fit bugaboo cameleon in travel bag - Cameleon Bugaboo Baby Gear
  • 3 Answers
Fold it down just like you would to put in the car, then remove the two large back wheels and put them in the wheel bag, and then either turn both front wheels flat or take both swivel wheels off and place them inside the bag on top of the frame then place the seat on top.
Posted on Mar 23, 2013
  • 274 Answers
SOURCE: Cameleon Jogger Stroller: The brake cable has snapped on my Bugaboo Cameleon...
You should contact www.buggypitstop.co.uk they are the only company I know that sells bugaboo spare parts like brake cables and levers.
Posted on May 21, 2010
  • 19 Answers
SOURCE: how to fold bugaboo camaleon
Put the seat in first (upside down, with the back of the seat facing up). Then put the collapsed chassis (with the large rear wheel taken off) on top of the seat. Make sure the front wheels are facing up. The handle bar goes towards the skinnier part of the travel bag.
Posted on Jun 28, 2008
  • 274 Answers
SOURCE: how to unfold bugaboo cameleon stroller?
go to www.buggypitstop.co.uk they service and repair bugaboo and have a very helpfull advice you can phone them or email them and they will answer anyn questionsw on bugaboos
Posted on Apr 15, 2010
macnutz
  • 541 Answers
SOURCE: Cameleon Jogger Stroller: The hinge on my bugaboo cameleon is stuck-in and n...
How to fix a Bugaboo Handle
If you are not a handyperson type, take these instructions to you local Bicycle Mechanic or Small engineering shop.
The bugaboo handle fault is caused by two small plastic pins shearing of a plastic disk that actuates two metal locking rods. Why bugaboo uses a plastic disk for this critical component is beyond me!
1/. Remove the domed star lock washer. This is the hardest part of the job. Most people try to leaver this off in the hope of re using. First problem with this is you will mark or damage the surrounding plastic second is star locks are not intended for reuse and will never hold as well as when first used, so best find a new replacement. A hardware store should be able to source some for you. Quickest way to remove a dome washer is to carefully cut a slot in the dome with an angle grinder and then use a large screwdriver to prize off.
Note it is best to open and repair one side at a time, so your moving and flexing one side of the handle does not dislodge parts in the other side.
2/. The lock mechanism is very simple; a wire rod rotates a plastic disk. The disk has two plastic pins that move the locking rods in and out of the inner hub into and out of the outer hub. You need to ether repair the disk by drilling out the pin stumps and finding a replacement metal screw you can fit / glue in. Or (my preferred choice) have a new metal disk fabricated that will last a lifetime.
3/. Reassemble handle locking hub and check operation. (I use a small amount of the grease used for taps to give a smooth action) If all has well fit, the new star dome on the hub shaft and tap home. To protect the dome finish I use a large socket from my socket set and an old rubber washer from a toilet cistern.
4/. Repeat operation on the other side. Note the disks are mirror images of each other and are not interchangeable. Bugaboo calls the side with the brake lever “LEFT” the disk will have a serial number that ends with “L”. I have had metal disks laser cut and stainless steel pins fitted. Cost of a disk with a new star dome washer is $75 New Zealand. If you like one or a set, you can contact me macnutz@xnet.co.nz
Regards
Steve
Posted on Aug 01, 2010
  • 8 Answers
SOURCE: will a frog seat frame fit on a cameleon chassis
Yes it will fit. the fabric seats are not interchangeable but everything else is. Currently I have Cam wheels on my frog chassis. As well as a cameleon canopy, and a fabric flease set on my frog seat.
Posted on Nov 08, 2010
Hi, I have 2nd hand bugaboo travel system and am not sure how or where to attach the umbrella?
Umbrella should come with a detachable clip that fits to the handle. You can then easily attach or remove the umbrella. If it's not already on the stroller or on the umbrella contact the person you bought it from. Bugaboo don't sell the clip separately.
May 10, 2011 | Bugaboo 'Cameleon' Stroller
How do you pack a bugaboo travel bag? It does not seem to fit with the wheels on?
You can find detailed instructions on at www.bugaboo.com/userguides but short the answer is yes the back wheels have to come off to fit in the bag. There's a simple wire spring you compress with your fingers where the stub axel fits into the frame.
Apr 05, 2011 | Bugaboo Frog Stroller
I would like 2 know where i can get a reolacement harness for bugaboo cameleon
There's a shop in Holland that has a lot of Bugaboo parts ask them. www.babycare.nl/spare-parts-bugaboo-cameleon-c-34_124_153.html. If it's just a broken clip Mountain Buggy clips fit and they sell them as a part unlike Bugaboo but that will involve a bit of needle and thread work.
Dec 08, 2010 | Bugaboo Cameleon - Tailored Fabric...
Bugaboo Cameleon Manual
If you visit www.bugaboo.com you should be able to download this manual.
Hope this helps.
Dec 06, 2009 | Baby Gear
Hi, i have just purchased a travel bag for my bugaboo cameleon from Ebay which was sent without instructions.I dont want the pram to get damaged on the flight because i packed it incorrectly, can u help?...
You must completely un-assemble the stroller before storing it in the travel bag. That means removing all four wheels and detaching the bassinet fabric from the frame before placing it in the bag. There should be a diagram on the inside side of the bag which describes the order of placing the parts in the bag. The order from ground up is the seat frame with the fabric, then the stroller chassis, then the wheels.
Apr 28, 2009 | Bugaboo Cameleon Stroller
Bugaboo transport bag instructions? How do I make it fit in the bag????
If you visit www.bugaboo.com you can download the instruction manual from the 'Service' section.
I hope this helps.
Mar 06, 2009 | Bugaboo Cameleon Jogger
How to fold bugaboo camaleon to fit the bugaboo travel bag
Jun 21, 2008 | Bugaboo Cameleon Jogger
Baby Gear Logo
137 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
