Question about Maytag Dependable Care LAT9706
Washing maching maytag dependable care
It fills with water fine, but then when it gets to the agitation or any other cycle it will only work about 30 seconds then stop. If I turn it off and wait about 20 minutes to turn it on again, it works about another 30 seconds. This is a darn slow way to get the washing done. Whats wrong? It does this til the very end of the spin cycle. The only time it does not stop early is when it is filling with water.
  • lissa hamilton Jul 12, 2007
    I did not get the results soon enough to keep me from calling a repair man, I thought when it said LIVE it meant really soon. I ended up buying a new machine.
  • 944 Answers
It sounds as if there could be an overheating problem in the control electronics - perhaps just due to one faulty component that could be replaced, perhaps the whole board is faulty. If you have a user manual (sorry i had no luck finding one online), then just check if there is a "reset" - usually would be either unplugging the machine and leaving it for a few minutes, or pressing and holding a combination of buttons. (ask again if you don't have a manual, I can look more but Maytag manuals are hard to find) Are you keen to try and investigate this further yourself? If so please ask again and we can try and talk you through opening it up and what to check. You will most likely need a selection of screwdrivers, a flashlight, a digital camera and a few hours. If you would rather get a service agent in to have a look, please post back with your general area and we can hopefully locate one for you. It sounds repairable. Hope this helps :)
Posted on Jul 09, 2007
  • Anonymous Jul 09, 2007
    There could also possibly be a motor fault, although I would expect an error message/light/beep to show if so, but perhaps not.
SOURCE:
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Maytag model lat 9605 aae fills with water but want agitate or spin out but works fine on delacate cycle thought it was timer put one on still doing the same thing
replace the motor brushes this is common it wont spin or do main cycles but easy go it does is worn brushes
take one and and check the lenght if its less than 50mm replace them
when they get shorter the motor draws more standing current etc running hotter so....
also check the vacume switch and for and rubbish inside the drum skin
Sep 24, 2014 | Washing Machines
Fills with water, skips wash and rinse cycle, starts spin cycle and sprays water out of the top
I would look at lid switch on this model and plunger to lid .Under lid is spray flume that can be damaged by large loads ,check that close. put it in wash full and drop lid hard it may come on.
Nov 19, 2013 | Maytag Dependable Care LAT9206
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
Not filling with water. everything else works. it will agitate without the water in the tub. it thinks there is water in it
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 30, 2010 | Maytag Dependable Care LAT9706
Maytag Dependable Care Plus LAT8824
I think that you mean "Agitate" some of the time that you write "Spin" Yes?
If I understand you correctly, you have no agitation during the "wash" cycle, this is almost certainly a corroded agitator shaft seized up in the transmission.
Oct 05, 2017 | Maytag Dependable Care LAT9706
IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Mar 24, 2008 | Maytag Performa PAV2200
Washing machine buzzing
buy a new washing machine
Nov 03, 2007 | Washing Machines
Washing machine wont work on certain settings
the selector switch for loads is just a switch that connects parts of the timed cycle to the timer circuit. if the timer is not rotating then nothing will work. check the connections through the selector switch. burnt or melted contacts within the switch calls for a new switch. try repair clinic dot com for a replacement.
Apr 19, 2007 | Maytag Dependable Care LAT9706
Washing Machines Logo
79 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
