Question about Refrigerators
Ice build up under 'pantry' drawer.
Temps are at the recommended settings. Problem started about a month ago.
    Genius:
  • Refrigerators Master
  • 1,669 Answers
Please offer me some information so that I may help, like the manufacturer, model number and how old it is.
Posted on Jan 14, 2013
We have ice sheets forming under cool select pantry drawer of our refrigerator. What should we do?
the fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature. May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Feb 12, 2015 | Samsung RF267AERS French Door Refrigerator
Samsung Defrost Issue - RB215LASH (SAM0075 manual)
You'll sadly find that there is either a leak or low pressure in the gas , or the pump is failing.
Oct 02, 2014 | Samsung RB215LASH
What's your problem?ice buildup under french drawer refrigerator
It could just be condensation, especially if you live in a humid area. I'd consider adding some silica gel packets (the kind you find in shoeboxes,) to the place where the ice is building up and see if there are holes in the ice where the silica is. If so, it's moisture-based, and short of installing a dehumidifier in the house or running the AC constantly, your best bet is to invest in a thick rubber mat, like the kind offices have at the door, and place the fridge on it, possibly with a small one-inch-thick block of wood under each foot. That's what I had to do and to my surprise, my power bill went down. It turned out that the rubber mat caught the condensation and let it evaporate, plus the wooden blocks gave the refrigerator coils more ventilation, which made it run more efficiently. It was like a $5 difference per month on the electric bill, so definitely worth a try, plus if the rubber mat is rectangular, it'll protect the patch of floor in front of the fridge from any accidental spills.
Aug 29, 2012 | Cell Phones
Frost is building up in bottom freezer. Appliance is running nonstop. I believe that the freezer drawer has been shut completely. Foods in refrigerator section are fine; foods in freezer section are...
Frost can build up for multiple reasons. Most common is the start os an iceblock. Other reasons can include condensation from door being left open or opening too much. It can also happen from backsplash from the inlet tube for the ice maker. If the fridge is running non stop. It sounds like the ice block is forming and the temps are not getting to the program temps. If at factory setting the freezer should be at or around 0 degrees and fridge should be between 42 and 48 degrees. Has the fridge shutdown at all to go into defrost? The defrost timer may have went out and is causing an iceblock. If there is an ice block always change bimetal/ defrost thermostat.
If you need any further assistacne please feel free to comment me.
Jul 27, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
Samsung RFG297AA Thin Film of Ice Forming Under Deli Drawer
My be an air leak,wipe/check all seals on doors and make sure doors are closing tight on seals.
Jul 24, 2017 | Samsung RF265AA Bottom Freezer French Door...
Can not get temp. below +10 f
That is a Medium Temperature compressor, not Low.
May 08, 2009 | KitchenAid Refrigerators
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
