Question about Sharp Elsi-mate El-1611 Calculator W/power Supply
Ink roller for elsimate el-1611l calculator
Wanting to buy ink rollers for above machine
freetek
  • 5568 Answers
SOURCE: sharp elsimate EL 2125E calculator
Lokks like it's available for download in several places; here's one:
http://esupport.sharp.hu/html/om/DataOutputDetail.php?TemplateLang=en&ID=2578
Posted on Apr 22, 2008
SOURCE: Replacing inking roller/ribbon?
i had a problem with this as well and found a user manual online. I thought the whole thing came out but it doesn't. If you pull up on the little red thing on right and then the black one on the right you have it. Imagine that! That's all that you change. Then just put some new ones in and your good to go.
Posted on Apr 10, 2009
SOURCE: Sharp ELSIMATE EL-240SA - how do you stop this
From the manual:
SETTING THE NUMBER OF DECIMAL DIGITS
Numbers of decimal digits of calculation results can be specified by pressing [C-CE] twice, then press [C-CE]and [M+] simultaneously.
The decimal digit assignment will appear as “F” (for “floating point”), “2” or “0” on the LCD. (The default is “F”.)
Press and hold [C-CE] and [M+] until the symbol changes.
Posted on Sep 29, 2009
SOURCE: EL 1197 G how do I change the ink roller
This old electric calculator - sharp el-1197g III - seems to have incorrect answers. Does it have a re-set to see if that is all that's needed to set it straight?
Posted on Jan 17, 2010
  • 23 Answers
SOURCE: Need new ink roller for Sharp EL-1801PIII. Do you
You need the IR40T Ink Roller
Posted on Mar 26, 2010
Replace ink cartridge
INK ROLLER REPLACEMENT
If printing is blurry even when the ink roller is in the proper
position, replace the roller.
Ink roller: Type EA-732R
WARNING
APPLYING INK TO WORN INK ROLLER OR USE OF
UNAPPROVED INK ROLLER MAY CAUSE SERIOUS
DAMAGE TO PRINTER.
1) Turn the power off.
2) Remove the printer cover. (Fig. 1)
3) Remove the ink roller by turning it counterclockwise and
pulling it upward. (Fig. 2)
4) Install the new ink roller and press it in the correct position.
Make sure that the ink roller is securely in place. (Fig. 3)
5) Put back the printer cover.
Jun 08, 2012 | Sharp EL-1611P Calculator
I have a Sharp EL-1801P that is low on ink. Can I add ink to the roller or do I need to buy a new roller?
Ink roller: Type EA-772R
WARNING: APPLYING INK TO WORN INK ROLLER OR USE OF
UNAPPROVED INK ROLLER MAY CAUSE SERIOUS DAMAGE TO PRINTER.
1) Set the power switch to OFF.
3) Hold the top of the ink roller and remove the roller by pulling
it toward you and then upward. (Fig. 2)
4) Install the new ink roller in the correct position. Make sure
that the roller is securely in place. (Fig. 3)
Feb 08, 2011 | Sharp EL-1801P Calculator
Can you change the ribbon
Yes you can. That type of calculator has two separate ink rollers, one black & one red. They are easy to remove by putting your finger around the little ink roller & sliding it out towards you, the new one will lightly click into place. You can buy the sharp brand of ink rollers or a generic brand that will fit your calculator.
Jan 25, 2011 | Sharp EL-1701C Calculator
Where can I purchase a ink roller replacement for my Sharp EL-1750P III calculator?
part# IR40T
EL-1750PIII http://www.gorillapaper.com/ink-roller-ir40t-b-r.html
Oct 21, 2009 | Sharp EL-1750PIII Calculator
WHAT KIND OF RIBBON DOES THE SHARP EL-1801V USE AND WERE DO I FIND IT?
Ink roller type EA-772R
You can find it in any good (refer your machine make and model). There are compatible roller with different references. Also check online (do a gGoogle search or check Amazon.com and you will find several links fopr different seller.
Note that the same type of ribbon is use by diffrent calculators, evem from different brands, so lok for the image of the print roller to see if it looks like t he roller of your machine)
Jul 16, 2009 | Sharp EL-1801P Calculator
How to change ink roller on Sharp Calculator EL-1611H
pulling it upward.
Apr 19, 2009 | Office Equipment & Supplies
Ink rollers
Unless the ink roller that you installed was dried out, usually, the replacement rollers just snap in place and are good to go. Check to make sure there is ink on the roller by either pulling the ink roller out again, and touching it with your finger. If no ink on your finger, you might have received a dried out replacement roller. Also the roller should be somewhat like a sponge. If you push against the sponge and it doesnt spring back and it stays indented, then the roller might also be bad. If you happen to have a bottle of ink for an ink pad, you can try soaking the roller with the ink so the roller is wet, (but not DRIPPING WET) and try it again in the calculator. IF you get some image for a little while, then I would say try a new fresh ink roller.
Hope this helps.
Feb 04, 2008 | Sharp EL-2192Rll Calculator
Ink Roller
Most Ink based machines can be re-inked with black ink available from the office supply store just buy ink for re inking a stamp pad remove cover{s} to get at ink roller and apply a few drops of ink and allow ink to soak into roll for 24 hours- we do this all the time with good results. any questions lemme know : }
May 11, 2007 | Sharp EL-2197GIII Calculator
Sharp Elsi-mate El-1611 Calculator W/power Supply Logo
71 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
