Question about Epson Artisan 730 All-in-One Printer
My Epson Artisan 730 Printer keeps ejecting its CD/DVD Print tray, saying that there is a cd there. There, of course isn't. Can anyone help me? I really need to print.
Keeps saying that there is a CD in the tray, but there isn't one, and it keeps ejecting it. I can't print anything anymore unless I can get this fixed.
My husband adjusted the CD/DVD tray, then we selected the icon that looks like a wrench on the printer's message window, then "restore default settings" on it. Turned computer off then on again, and it FINALLY started working again :)
Posted on Sep 19, 2014
PABLOCSA
  • 1124 Answers
SOURCE: Epson Stylus R320 - cant align the CD tray to print....keeps showing error.
This printer has a bad system tray. If doesn't work in regular way, try inserting the cd tray from the back using the back slot and see what happen (usually works)
Posted on Oct 03, 2008
SOURCE: Epson R300 CD/DVD Tray ERROR message with Leopard any Solutions?
One of the guys on this site said read the manual over and over again, and he was right.
You must go to system preferences and choose print and fax. Set the default media to A4. Then in the Print CD program when you hit print your will see fifth line down Epson Print CD on offer. Hit the arrows on the right and choose print settings from the drop down menu and then media type and choose CD / DVD. All should then work. It does on mine.
Regards and best wishes. David
Posted on Jan 07, 2008
  • 55 Answers
SOURCE: the epson printer driver dealing with cd printing is not installed
is there an ok button on that error message? if so just click on OK button and click on a button says manual.
It will let you check on the settings on the printer. paper size should be A4.
on print settings it should let you select on cd/dvd
Note: this only works if you have installed the epson easy print from the epson.com website of your printer model
Posted on Feb 09, 2009
  • 3 Answers
SOURCE: Epson Stylus Photo R300 Inkjet Printer
The cd/dvd tray door has a small opening on right edge. Inside there is a slide switch. Use a toothpick to see if it is stuck. Check where it closes to the main body. A thin strip protrudes out to mate and close the plastic actuator of the switch. The door may not be closing well enough the actuate the switch. Make sure it is fully closed and retry to print. Also, there will be a small click as you raist the door before it snaps into place. If not, check to see if there may be some debris causing it to not actuate properly.
Good luck,
Posted on Feb 23, 2009
SOURCE: Epson stylus photo R300 cd/dvd tray not set correctly
I had the same problem. Restarted the printer. Reinstalled the drivers. Scratched my head ... nothing! then I moved the printer away from the wall - problem solved! I can't say that this will work for you but if everything else is working, as it was and still is on mine then it's worth a try.
What I didn't realsie was that the cd tray comes out of the back of the printer when it's checking the alignment. I had inadvertantly pushed the printer back, too close to the wall. Moved it forward slightly and it's fixed.
Hope that solves it for everyone.
Posted on Feb 27, 2009
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
Tip
My 2910 player has similar issue. The tray gets stuck on eject. Started with not...
1)just open the player
2)remove the rubber belt connecting the dc motor
3)you can open the disc tray now
4)if there are any dust particles or obstacles in the door way just clear them up by using the cloth(dry cloth preferred)
5)if you have any greasy material like vaseline,oil,etc then just put that in the door for easy movement of the disc tray
6)if needed change the rubber belt which is connecting the dc motor
7) just reconnect the rubber belt again and then just fit all screws that s all
what s more your player s disc tray will start ejecting like the previous how you were using..
any doubts you can reply me
i am always here to assist you
thank you
bye
on Jan 06, 2009 | Samsung DVD-V4600 DVD Player/VCR
I have a Sharp CD-DK891N Mini System. The 5 tray CD system will not play any CD's, there isn't anything stuck in any of the trays. How do I get the CD 's to play??? Any help would be appre
Get a CD cleaning kit and follow instructions, if no change the laser pickup assembly will need to be replaced, far cheaper to buy a new player.
May 12, 2012 | Sharp Audio Players & Recorders
My camera wont charge in the tray or the charge light won't come on. Camera keeps saying low battery.
My guess is that with the age of the battery it isn't able to hold a charge anymore which means you'll need to purchase a new battery. Your best bet for that will be to go through Sony or the website Dr. Battery.
May 11, 2011 | Sony DCR-HC52E Mini DV Camcorder
CD Player Tray keeps opening and closing by it self
This is either caused by the drive belt slipping, the closed sensor being faulty or an obstruction to the tray.
Basically the tray isn't makeing it to or registering as being in the fully closed position.
May 02, 2011 | Tascam CC-222mkIII CD Player / Recorder
CD wont eject from drive
Have you already tried to mannually open the tray, by inserting a thin straight object (like a unbent paper clip) in the manual eject hole on the optical disk drive? The hole exists for that pupose.
Jul 18, 2009 | Dell Studio 15 Laptop
Printing CDs using the CD tray - now won't work
sometimes those cd label print papers are too thick..and need to fed in one at a time
Feb 25, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Discs will not play.
Could be some dirt on laser lenses. Try to clean it.
Sep 25, 2007 | NAD C541 CD Player
Won´t read any Disc
I have the same problem since the early beginning after purchase. I'm very upset with NAD for the zero-value technical service in Italy. After 2 months they gave me back my C541 with new defects (the tray now doesn't work properly). They have tried - they said - different optics without fixing the problem. Does anybody know if a compatible optic / tray exists?
Thank you
Marcello
mcl.vlb@tiscali.it
Epson Artisan 730 All-in-One Printer Logo
419 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
