Question about VinoTemp VT-58 Wine Cooler
Vinotemp vt 58 is cycling +/- 5 degrees F
New VT 58 from Vinotemp. Put a dozen bottles of wine in it and while it got down to the desired temperature, 55 F, it keeps cycling between 50 F and 60 F. That seems like too broad a range to me, not good for my wine.
  • Ron Sosnowski Jan 16, 2013
    I talked with Vinotemp customer support and they indicated that this was not unusual. Their spec is for the temp to cycle 7-8 degrees. Mine is a little outside of that when set at 55 F. But I turned it down to 53F, a drinking temp for complex whites, and it's now cycling between 50-57F. So I'm ok. I was concerned because my previous wine cabinet was thermoelectric and only cycled +/- 2 degrees. Vinotemp told me that thermoelectrics "run" constantly and thus can maintain that kind of precision. (I was wondering why the warranty is only 3 months for the thermoelectrics). Vinotemps testing indicates that when cycling 7-8 degrees, the temperature inside wine bottles changes less than 1 degree.
    Typo in my previous comment: my thermoelectric cycled only +/- 1 degree, with a range of 2 degree.
5 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: This VinoTemp vt 60 just quit working. No
if the evaporator coils are warm, you have a leak and no refrigerant.
Posted on Aug 26, 2009
  • 14 Answers
SOURCE: Vinotemp VT-16TEDS has light on but doesn't cool
You may need to change the cooling system on the unit if the unit is free of dust and still does not cool.
Posted on Sep 21, 2009
57 varieties
  • 1653 Answers
SOURCE: I have Vinotemp wine chiller model number
It will either be the thermal resistor or the controller of which the electronic thermostat is a part and yes it can be repaired. It is a reasonably common and cheap fault to repair. If you go to the following link you can get the service manual FOC
http://www.vinotemp.com/Resources/Documents/VT60.pdf
and you can contact a repair company via Vinotemp at the following link
http://www.vinotemp.com/Service-Support/Repair-Companies.aspx
Posted on Nov 07, 2009
  • 11800 Answers
SOURCE: I have a Vinotemp VT-12TEDS-2Z Dual Zone
This cooler uses the Peltier effect = the current passing thru a very special resistance provides the cooling. Because of that there are effectively 2 separate electrical circuits inside your cooler:
1, the mains voltage that powers the Peltier element and the cooling fan - controlled by a relay
2. the low voltage that powers the control board and the display - this is the one that failed in your case.
To fix it you will have to open the front cover , access the board and test it: if it gets power then the board itself has failed; if it doesn't then its the power source and you will have to find out why it failed - probably it was damaged when another component failed and you will have to find out which one before putting a new source in.
It's a relatively complicated job that requires a good experience - if you don't have it then call an certified repairman.
Posted on Jan 08, 2011
Need to replace compressor on vinotemp wine coooler
Return the compressor and buy another wine cooler. This work is too complex for people that do not do this every day, Thanks Sea Breeze
Nov 19, 2012 | VinoTemp VT-60 Wine Cooler
Is there such thing as a single bottle wine cooler?
Of course! There is a wide variety of single cooling systems for wine bottles. We don't drink a lot of wine, but when we have guests over I like to have the wine chilled properly. I prefer the stainless steel coolers, since the look more sleek and stylish.
http://www.amazon.com/Vinotemp-VT-CHILLER-SLVR-Bottle-Chiller/dp/B001NFX2QU
http://www.polyvore.com/danby_maitre_single-bottle_wine_chiller/thing?id=541026
Jul 31, 2012 | Furniture
Our 18 bottle vinotemp cooler quit cooling, the electrical is ok
Sounds like the cooling unit, i.e. heat sink and controller chip. $35 + $10 shipping from vinotemp, and you install yourself. I'm looking at the same thing (on the 28TEDS), though mine came after having to replace (for $45 and my own installation, incl. soldering) the circuit board. I hope yours doesn't go, too. I've read of others. Pretty poor quality parts they appear to use. I'm trying to find somewhere to buy the controller chip on its own, as the heat sink is simply a hunk of metal. Hopefully that's do-able, as it is with computer cpu's.
See:
http://www.vinotemp.com/Browse.aspx/446/Replacement-Parts
Dec 28, 2009 | VinoTemp VT-18TEDS 18-Bottle...
Vinotemp (VT-60), cools, but doesn't turn off regardless of the temp setting. It will run, cut off for aprox 5 seconds, then continue running. Is thermostat broken? Can it be repaired?
Nov 05, 2009 | VinoTemp VT-60 Wine Cooler
Aug 25, 2009 | VinoTemp VT-60 Wine Cooler
Vinotemp Wine Fridge Makes Noise, Doesn't Hold Temperature
Call the place you bought it and check on warranty .
Nov 15, 2017 | VinoTemp (VINO-24GN)
First check the grating over the fan in the back. If it is covered with dust, there won't be enough air flow and the unit won't cool. Clean the dust off and see if it cools back down. It may take a long time to cool down if it is full of wine, so I recommend taking the wine out to test if it works.
Jan 17, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
Vinotemp VT-60 Condenser won't shut off, unit running way too cold
It might be a sensor or control board problem. Any appliance repair place should be able to help you out with this. Or you can try contacting the manufacturer directly for help or if you need to purchase replacement parts. Otherwise, my cheapest suggestion would be to hook the cooler up to a timer, so you can turn the unit on and off maybe every 20 minutes or so. That should help keep it from causing more harm and then you can monitor the temperature with a thermometer. Hope that helps!
Aug 29, 2008 | VinoTemp (VT60GNV) Wine Cooler
Wine-cicles
I found the vinotemp trouble shooting webpage that has good info for several different VT models. Here is the link. http://www.vinotemp.com/troubleshoot_pdf.htm
I emailed VT and they gave me a price for the parts
VT-TC32ECB -$34.95 (control board)
VT-60Sensor -$14.95
here is their services information
Jane Barron
Service Department
VINOTEMP INTERNATIONAL
jbarron@vinotemp.com
T 310.886.3332 x231
800.777.8466
F 310.886.3310
Mar 18, 2008 | VinoTemp (VT60GNV) Wine Cooler
VinoTemp VT-58 Wine Cooler Logo
32 people viewed this question
Top VinoTemp Refrigerators Experts
Vernon Taylor
Ilia Bichin
Are you a VinoTemp Refrigerator Expert? Answer questions, earn points and help others
