Question about Cambridge Audio Azur 640A Amplifier
No sound, no cap warnings
My 640a V2 died yesterday. No sound over speakers, with headphones I hear only crackling noises which somewhat resemble the playing track. The CAP5 projection LED does not light up. Symptoms: - the amp used to click twice when turned on, now it only clicks once - when turned on, there were blue LEDs flashing from Aux (leftmost) to TapeMon (rightmost) and back. Now its only from CD (2nd from the left) to TapeMon and back. - when I try to switch inputs from A to B sometimes the LED of A fades but that of B does not turn on, sometimes both turn on. - a faint 'burned' smell Looks serious to me, but I have not clue about electronics. Does anyone know what the problem could be / what part is likely the problem or should I just send it to CA? thanks!
5 Suggested Answers
  • 31 Answers
SOURCE: Using a tube pre amp with my CA Azur 640A?
There are many answers to your questions but Ill have a go with the basics...
Audio connections should be matched.... its called Frequency impedance,.... to get a signal along wires or cables (or Fibre) the Impedance of the cables and wires must be matched to the device they are connected to transfer the signal along the cables without distortion...
Manufacturers provide many sockets on the input side of amplifiers and preamplifiers to allow the consumer to connect various devices of different impedance.
They label these inputs like CD, or Tuner, or PHONO etc etc,
That means if you have a CD player it must be plugged into the CD input socket then the impedance will be correct and the sound will transfer along the CD cables correctly, without distortion..same with the Phono input etc...
You will find on the sound output to the speakers terminals are also labelled 4-6ohm, or 8-10ohm, these are the impedance expected for the coil ratings of the speakers them selves and its important to get the correct speakers to the correct out put terminals...
In your case all you have to do is follow these simple rules and all will be well....you say you have a squeeze box well there probably isnt a port labelled squeeze box so you need to experiment and try out each input port for the squeeze box to see what input gives you the correct sound output...Watch the Phono inputs as these are very sensative to input sound levels and must be treated very carefully as they have a double stage of sound amplification and as such you need to have the volume right down when connecting up the Phono inputs then increase the volume carefully after the cable connections are completed.
If you follow these rules then all will be well,,,,there is no difference if the Pre amp or Power amp is valve or transistor or FET or has IC outputs to the speaker the same impedance rules apply..just treat it as a box with input and output terminals and all the impedance will be taken care of for you...if you read the lables...
You need to connect you signal source to the Preamp inputs the out put from the Preamp connects to the power amp input then the power amp output goes to the speakers. this is a basic configuration for sound systems, there are other variations but are outside this discussion.
Cheers From YUBEUT
Posted on Nov 16, 2007
  • 31 Answers
SOURCE: Loss of sound Azur 640A
This is a classic dry joint,,,,,,,,When a box of electronics is assembled thousands of soldered connections are made, to connect all the components together correctly.
During this soldering process a special FLUX is used to ensure the components are electrically connected correctly and reliably....sometime this FLUX creates an air bubble and over time this bubble causes the outside air to corrode the electrical connection and thus the minute electrical voltages cannot pass though this connection correctly....
When you turn on... electricity and heat are generated just enough to allow the voltages to get through the faulty joint...
thats why the sound is weak and changing in intensity...
This fault needs to be located and resoldered. Its not an easy task to locate it... but the resoldering takes only 5 seconds,,,,but as you can imagine searching for it can be time consuming....
You will need a circuit diagram of the amp and some nowledge of the audio path from input to output to search effectively...
But please check your speaker wires very carefully as maybe the simplest thing is causing this problem!!!!!
Cheers From YUBEUT
petraman7
  • 1175 Answers
SOURCE: my azur 540a/640a v2.0 amplifier is not working.
I agree with hallsteve.
One or both of the output sections is blown.
What part of the country do you live?
I may be able to suggest someone.
Posted on Jan 22, 2009
technical114
  • 1851 Answers
SOURCE: Hello,
Why don't you try using the main outputs (the 2 XLR connectors). With 2 cables connect these two (left - right) outputs at your amplifier's aux in. In that case take care that the "output level" of the mixer works like master volume controlfor the signal that the mixer sends to the amplifier.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Posted on Feb 25, 2010
Ac adaptor crackling thru external speakers
Allan, It sounds like you have what is called a ground loop. A ground loop can occur when two pieces of equipment are connected together through a home or buildings safety ground through the same power source. For instance, your PC is connected to a power source through the AC adapter or plug, and your external powered speakers are receiving power from the same power source. The surrounding cables as well as the AC adapter(s) can act like an antenna. This will cause a low hum or crackling that would be audible through the speakers or headphones.
You may want to try plugging all components into a power strip so they are all on the same circuit. You may also want to be sure that the AC adapter cables are not not laying or running across other electrical components plugged into a different socket.
If you get the same hum through your headphones check to see if the headphones were manufactured with shielded cabling. A shielded cable is made with a wire mesh around the outside that helps reduce electrical noise. Hope this helps a little. Thanks!
Aug 31, 2012 | HP Pavilion dv6000z Notebook
Hello. With my HD205 headphones, in the left headphone it has a small crackling noise with certain songs.. I don't know if its meant to be like that? Its done it since I had them first - Happens to bass...
There are two likely causes for this. One is much, much easier to fix than the other.
1) You are turning up the volume too much. Headphones, especially non-top of the line headphones, are not meant to be listened to at very loud levels. In this case, the crackling you are hearing is the speaker trying to reproduce a bass sound that is "clipping", or exceeding the maximum output level for that system. Remember - headphone speakers are very small; they have a harder time producing low sounds accurately. The solution is to just turn them down a little.
2) Assuming problem 1 is not the problem, the other likely issue is that they came with some sort of mechanical defect built in. If you are not playing them loudly, but you are still getting a crackle, especially if it is only on one speaker, they probably are broken. It is probably the jack itself, or the wiring leading up to the earpieces. Either way, it is not a terribly hard fix if you have some electrical know-how, but if you don't, there are plenty of people who can rewire them for much cheaper than it would be to buy a new set. However, if this has been happening since you got them, I would call the manufacturer first and see if they will replace them. Sennheiser tends to pride themselves in the quality of their equipment, so I would not be surprised if they sent you a replacement set.
Hope this helps!
May 03, 2011 | Sennheiser HD 205 Professional Headphones
Blown headphones
I'm also a stickler for sound I was devastated when my iPod touch headphone jack broke. I think it's impossible to find a pair of headphones that never blow. I'm using skullcandy lowriders at the minute and they are great except you can hear the sound coming out of the headphones from a mile away. I would reccomend sending your headphones back to Bose or wherever you brought it from. Most stores have a 1 year return guarantee on all products. Hope I was of help, Jess.
Jan 12, 2010 | Skull Candy Lowrider Headphones
The sound on my laptop has been fine up until a couple of days ago, it makes an anoying crackling sound through both internal speakers and my headphones an i know my headphones are fine,???? help me please
There are several reasons why you could suddenly be getting a crackling noise. My best guess is you have the laptop near some kind of magnetic source - maybe a cell phone? My Boost mobile phone would do this to my speakers. Is this possibly the cause?
Oct 24, 2009 | Microsoft Windows XP Home Edition
Crackling noise from subwoofer!
If ayou have a system with speakers that works and a different set is crackling
the set that crackles is to be determined the bad set. Cones dry up a bad assembley just coinsidents having a bad set of speakers. It is an AUDIO problem not a computer problem
Jul 27, 2009 | Acer 90.00012.30B Computer Speakers
Speaker static noise
The first thing to try is plugging a set of headphones into the speaker plug and testing, see if the crackling continues, if it doesn't it sounds like a short in your speakers (or the sound card, but my guess would be the speakers).
Post your results here so we can further assist you.
Mar 24, 2009 | Gateway Media Center 610XL PC Desktop
Crackling noise from subwoofer????
sgangsta91,
i think your speaker cannot support the sound that your computer produce. it means to say that, they are not compatible. specially when your computer sound interface that you used is 5.1 or 7.1 interface but your speaker specs is only for generic sound, you really hear a crackling sound and more if you set to higher volume.
but it can help if you only set your computer interface to generic sound or set only in lower volume it can help. because if you continue that way, your speaker can be seriously damaged that even at the lowest volume can hear the crackling sound.
or if you really want a fine good sound system then, buy a speaker that can interface with 5.1 or 7.1 or see manuals of your computer/motherboard. for recommended specs
aclamonte
Nov 07, 2008 | Logitech X-220 Computer Speakers
Crackling noise
it might be the speaker or it break
Jul 29, 2008 | Sennheiser HDR 120 Consumer Headphones
Cambridge Audio Azur 640A Amplifier Logo
44 people viewed this question
Top Cambridge Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
