Question about Home
What is braising? - Home
    Problem Solver:
  • 18 Answers
This is first braising the meat, cooking the food at a high temperature to brown it. Some liquid is then added and it is left to simmer. Braising allows us to eat tough meat we were previously unable to eat.
Posted on Jan 14, 2013
How can you choose your own time and temperature. And what is the buttons for sauting, braising and simmering?
as you do not refer to the make and model and fixya site has nothing to do with cooking appliances there is no possible way you can expect an answer , other that to get the correct web page for that manufacturer and address the question to them
Jul 10, 2017 | The Office Equipment & Supplies
Braise cook chuck roast
http://www.cooks.com/rec/search/0,1-0,chuck_roast_dutch_oven,FF.html
Mar 05, 2015 | Kitchen Appliances - Others
What would be the solution to fix the item if the error code the item is giving is "flame rod short"? the item will not turn on.
This probably means that the flame sensor is shorted to Ground. This sensor is usually a flame rod that is partway into the flame and detects a current flow through the unit. Unplug the braising pan.
Check the wire between the flame rod and the control unit. It may have damaged shielding or be touching another part of the braising pan. Replace the damaged wire. Next you need to check the flame rod is in the correct position. It will be mounted near the igniter or pilot light. Then the rod needs to be partway into the flame. Sometimes moisture gets into the unit; this can be dealt with by cleaning the flame rod with steel wool. (Remove it first.) Next check the rod for damage and replace it if there is damage.
You may want to have a professional check the unit. If the flame rod ceramic housing is damaged, that should be replaced by a professional. If the rod isn't correctly positioned, the braising pan could become hazardous.
I hope this helps.
Sep 08, 2014 | Vulcan VG40 Gas V Series Braising Pan - 40...
6 letter word using these letters iefsrbmajac
briefs, camber, fabric, fascia, frames, camera, safari, racism, scream, fibers, braces, scream, crimes, scarab, carafe, rabies, braise
I'm sure there are many more, but these are a start.
Sep 06, 2014 | Computers & Internet
How to install freon
On a sealed system ports have to be braised into the lines. This should be done by a professional since hi pressured systems can be fatal
Aug 17, 2014 | Heating & Cooling
I have a recipe which requires braising ( browning and then adding liquid). is a saute pan best for this?
definitely! The walls of the saute pan prevent you from spilling while you stir.
Apr 10, 2013 | Home
Does a braiser look like a dutch oven?
Braising has no liquid or at maximum, just a little, so the sides of the braiser are much more shallow than a dutch oven's. this way the meat doesn't cook like a stew in water, but rather from the steam.
Jan 14, 2013 | Home
Got JB weld or braising in my fuel breather
remove the fuel tank leave the cap off and get a small drill bit and re drill the hole using a hand brace or a nut driver. if your careful you can use a battery powered drill or electric drill. why did they cover the breather hole?
Jan 21, 2009 | 1993 Harley Davidson XLH Sportster 883
Home Logo
825 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
