Question about Samsung DMR78AHS Builtin Dishwasher
Samsung dishwasher stuck in drain cycle and no buttons work on the control panel. I have unplugged the dishwasher and when i plug it back in it goes to drain cycle even with the door open.
F3 comes up on mine as well and has the problem. It has been said that F3 means a water leak!!
Posted on Mar 03, 2013
3 Suggested Answers
  • 6 Answers
SOURCE: samsung dishwasher door lock stuck in closed position
take small flat head screwdriver and on the door were the latch is push the screwdriver in about an inchpull on the open handle at the same time ps unplug it first.
Posted on Jun 22, 2012
Testimonial: "thanks, ill try that now"
  • 8404 Answers
SOURCE: The dishwasher detergent box is not springing open
This is brand new? Simple. Call the salesman and tell him the trouble. It is covered under warranty. If you fool with it you will void the warranty.
Posted on Sep 19, 2011
About a week ago my Samsung dishwasher Model#DMR78AHS started powering off midcycle & randomly coming back on.
Hello. From the symptoms you describe, it sounds suspiciously like a shorted user interface(control panel). The clue is the control panel not responding to touch--think of an electronic device with a key you're holding down--it won't let you do anything else until you release that button. If the panel has a button that's shorted, the same type of thing is happening. I'm a tech and have seen this A LOT! The part number for the control panel is DD92-00104B. The number for the main board is DD92-00008A, if needed.
Aug 21, 2015 | Dishwashers
Miele Incognito G643 SCVI
It sounds like there are some faulty wiring connections to the motor.
You will have to check your wiring from the timer to the motor.
Does it do the same thing if you select a different cycle on the push buttons?
The wiring diagram should be in the bottom access panel of the dishwasher or in the control panel.
Mar 14, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool quiet partners II normal light flashing
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
Dec 18, 2013 | KitchenAid 24 in. KUDI02IR Built-in...
Reset button maytag dishwasher
  • 1 Open and close the dooricon1.png of your Maytag dishwasher.
  • 2 Locate the "Rinse" button on the dishwasher control panel. Press and release the button five times in quickicon1.png succession.
  • 3 Press and release the adjacent "Drain/Off" button on the control panel two times; this will deactivate the dishwasher's demo mode and reset your dishwasher.
  • If you need to restart your dishwasher or forgot some dishes and want to open it during a cycle and restart it
  • 1 Press the "Cancel Drain" button on the display. Allow about 2 minutes for the dishwasher to completely drain.
  • 2 Choose a cycle under "Cycles" on the panel.
  • 3 Select an option or options under "Options" on the panel.
  • 4 Push the "Start Resume" button.
  • Oct 24, 2013 | Dishwashers
    Edgestar DWP60ES prematurely ending wash cycle, will not drain properly, beeps alot
    most likely the dishwasher has a minor leak in the base under the wash sump. this could be tripping the flood switch which causes the pump to run continuously. when the leak dries up you are able to start normally until the leak trips the flood switch once again.
    Check for leaky door seal or hose. see edgestar site for instructions on getting to the area under the sump. make sure dishwasher is disconnected from mains when working on it.
    Jul 25, 2012 | Dishwashers
    Dishwasher won't drain when cycle is complete. Not even when press on the Cancel/Drain button. Engine starts working (at least sounds like something is going on) but not water goes out to the sink...
    Hi
    Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
    Daniel
    Aug 30, 2011 | Dishwashers
    I got the 'LE' error code for the LG LDF6810ST dishwasher.The serial number is 604KW02152. I removed the door cover as some of the other solutions suggested, but the wires looked fine. I was...
    This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
    Step 1: Unplug the washing machine.
    Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
    Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
    Are there soap suds visible in the drum?
    Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
    Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
    Step 2: Plug the washer back in and press [Power] to turn on the washer.
    Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
    Step 4: Press [Start/Pause] to begin a drain only cycle.
    Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
    Hope this helps.
    Jun 29, 2011 | LG LDF6810ST Stainless Steel Built-in...
    My Frigidaire Dishwasher FDB1050RES2 gets stuck in a rinse cycle. The light on the front will be lit "clean" but the bottom of the washer is full of water. Opening the door does not turn off...
    by the descrition you are giving you will need to replace the main control board.Part number 154568401.you may also need to check the float switch.The part will run about 110.00 dollars from a local parts store
    Dec 29, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
    Control panel on my whirlpool dishwaher not functioning properly
    The console (control panel) is defective. The buttons may be getting stuck and/or are corroded.
    Feb 20, 2009 | Whirlpool 24 in. ADG7540 Built-in...
    Whirlpool ADP951 Dishwasher
    Processor board sound bad. May be a loose plug ( or corroded connection on the plug ) . Unplug the dish washer from the wall plug before servicing. The open the front panel to expose the panel control board. Unplug the panel plugs and inspect them to assure no corrotion is apparent. If you see corrotion, use a pencil erracer to clean all contact points on the board and clean the plug the best possible. Plug the dishwasher plug back in the wall and check the unit for proper operation. If the operation is not correct, replace the circuit board. I hope this helps
    Ed
    NC Electronic
    Mills, Wyoming
    Jan 06, 2008 | Dishwashers
    Samsung DMR78AHS Builtin Dishwasher Logo
    498 people viewed this question
    Top Samsung Dishwashers Experts
    Dale Copeland
    Dale Copeland
    Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
