Question about Locks & Locksmithing
I have a garrison deadblot lock with remote #046-2667-4 i tried to program it but with no success please help
Unable to program it. wont let me get in the program mode
SOURCE: unable to program the remote to my mognavox
UNABLE TO PROGRAM MY REMOTE TO MY APEX TV I NEED THE CODE.
Posted on Jan 29, 2009
SOURCE: jumbo remote control wont program
if u still have the manual to it---- look at the top right corner of page 11.. there are separate codes for for emerson tv's listed as---
TV VCR/DVD
036 041
39 027
155 002
198 008
231 u could try these---
good luck.
Posted on Feb 13, 2009
  • 5 Answers
SOURCE: remote starter wont work
there are a number of things you need to check.Make sure you have all of your voltages,acc,ign,constant12v.Make sure you have a good tach signal.On the Auto start brands a goood ground is needed.make sure your brake wire is connected.If there is a nuetral saftey wire,please connect it to ground.
Posted on Feb 27, 2009
SOURCE: Memorex MVD 2042 DVD Player ''Key Lock on''
mt memorex dvd player says ``key lock on´´ and i don't know how to quit that and i can't opened with the remot control
Help please!!!!!
Posted on Feb 21, 2010
  • 5 Answers
SOURCE: How to fix the 2004 CAMRY remote?
1. Start with the key out of the ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Perform these steps within 5 seconds.
A. Insert the key into the ignition(Do NOT Turn) Pull key out.
B. Insert the key into the ignition(Do NOT Turn) Pull key out.
3. Perform these steps within 40 seconds.
A. Close then open the drivers door.
B. Close then open the drivers door.
C. Insert the key into the ignition(Do NOT Turn) Pull key out.
4. Perform these steps within 40 seconds.
C. Insert the key into ignition and leave it in ignition.
D. Close the drivers door.
E. Turn the ignition to ON (Do NOT Start) then back to OFF.
F. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically
indicating successful entry into programming mode.
Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remtoe simutaneously for 1.5 seconds.
B. Immediately after letting go of the lock and unlock buttons,
Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door
locks should lock and then unlock once indicating successful programming. If
the door locks cycle twice, repeat steps A and B in step 6 as the remote was
not accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Open drivers door.
Posted on Jul 07, 2012
I am not able to get my 2006 Tundra into programing mode so that I can program the remote
Hello Randy,
Try this procedure I found on a blog...
Get in your truck,lock the doors with the button on the door,key in ignition, in RAPID succession turn ignition on/off seven times,leave key in ignition, hold down lock button on remote until door unlocks....remote is programed.
Need help Tundra wont go into programming mode
There is another procedure at the bottom of the above blog in a .pdf format that you will have to register on the site to gain access to...
Aug 16, 2017 | Cars & Trucks
Garrison keyless entry will lock but struggles to open when code entered. Doesn't unlock.
needs cleaning and re oil the mech inside is starting to froze up
Nov 23, 2014 | Cars & Trucks
Garrison
The manufacturer has a video for installing the electronic deadbolt, it might be helpful.
https://www.youtube.com/watch?v=UZ0nsArpesc
English vision
https://www.youtube.com/watch?v=SqAP2Jgd9n8
French vision
Should you still experience difficulty, please return to your store.
by
CanadianTireTeam
- CanadianTireAnswers
1 month, 2 weeks ago
May 18, 2014 | Locks & Locksmithing
Problem programming keyless remote
You will need to see the dealer on this issue, the control module needs to be scanned.
Jun 12, 2013 | 2001 Toyota Highlander
2003 remote control for 2005 van?
Transmitter Programming
If you lose a transmitter, program the old and new transmitter(s) into the remote control door lock receiver's memory. Up to 4 transmitters may be programmed.
Important
Once the remote control door lock receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information, requiring the programming of all transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If more than 1 receiver is being programmed at the same time, it is possible that the same transmitter could be programmed to more than 1 remote control door lock receiver.
Perform the following steps in order to program the transmitter:
Remove the ignition key from the ignition lock cylinder.
Remove the BCM PRGRM fuse from the fuse panel. Refer to Fuse Block in Wiring Systems.
Close all of the doors.
Close the liftgate.
Turn the ignition lock cylinder to ACC.
Turn the ignition lock cylinder to OFF, and then back to ACC within 1 second.
Open and close any vehicle door. A chime will be heard when the system enters the BCM programming/diagnostic mode.
Important
After 7 seconds, a chime may be heard confirming successful synchronization. It is necessary to wait approximately 14 seconds for a second chime that will confirm successful programming.
Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
Repeat the previous step on each additional transmitter to be programmed.
Install the BCM PRGRM fuse back into the fuse panel. Refer to Fuse Block in Wiring Systems. IF THIS WAS HELPFUL,PLEASE RATE,THANK YOU
Jul 15, 2010 | 2005 Pontiac Montana
Remote wont work
GRAND PRIX KEY FOB PROGRAMMING INSTRUCTIONS
Important
Once the Keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If you program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver.
Perform the following steps:
Sit in the vehicle driver's seat. (actually it’s much eazy er from the front pass seat)
Close all of the vehicle's doors.
Remove the MALL PGM fuse from the fuse panel. Refer to Electronic Diagnosis in Body and Chassis.
Turn the ignition lock cylinder to the ACC position.
Turn the ignition lock cylinder OFF, then back to ACC within 1 second.
Open and then close any vehicle door. You will hear a chime when the remote control door lock receiver enters the programming/diagnostic mode. If you do not hear a chime, start again at step 1.
Important
After 7 seconds, you may hear a chime confirming successful synchronization. After approximately 14 seconds, you will hear a chime confirming successful programming.
Repeat step 8 in order to program each additional transmitter.
Install the MALL PGM fuse back into the fuse panel. Refer to Electrical Diagnosis in Body and Chassis.
Validate that all the transmitters that were programmed operate properly. Refer to Keyless Entry System Operation.
Good luck and hope this helps.
Jun 17, 2009 | 2000 Pontiac Grand Prix
Unable to program the remote to my mognavox
Jan 29, 2009 | RCA RCR450 Remote Control
Programming sky+remote to sanyo tv
Sanyo
0159
236,073,100,064,174,185,367,039,245,246,398,241
Try these
Dec 08, 2008 | RCA RCR660 Remote Control
Help please!!!!!
Nov 17, 2008 | Memorex MVD2037
Locks & Locksmithing Logo
319 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
