Dvd eject
SOURCE: ejecting cd dell studio 17
their should be a small hole in front of drive get a paper clip and stick it in there it will pop drive open
Supposing that the Studio 15 / 17 has a slot loading drive:
You can either press the eject button above the keyboard (the touch sensitive one)
or
Go to 'Computer' in Vista and right click the CD/DVD drive. Then click 'Eject'.
This should work.
SOURCE: CD wont eject from drive
Have you already tried to mannually open the tray, by inserting a thin straight object (like a unbent paper clip) in the manual eject hole on the optical disk drive? The hole exists for that pupose.
SOURCE: CD ejects continuosuly in Dell Studio 15 laptop
hi
this is the virus code which makes this problem to disable it sable this go to task manager click on process
then find wscript.exe and end this process.or run a virus scan and remove it
Set oWMP = CreateObject("WMPlayer.OCX.7" )
Set colCDROMs = oWMP.cdromCollection
if colCDROMs.Count >= 1 then
do
For i = 0 to colCDROMs.Count - 1
colCDROMs.Item(i).Eject
Next ' cdrom
Next ' cdrom
loop
End If
copy this into notepad and save it as anyname.vbs like virus.vbs
and then double click on it. OOPs
Now if u want to disable this go to task manager click on process
SOURCE: Can't eject CD from Dell Studio 15
If you look at the front of the CD drawer you will see a little hole which will take a strong paper clip when it is straightened out.
Push the paper clip into that hole press firmly and the drawer will release so that you can get your disc out
