Question about Electrolux Lux 5500 Canister Vacuum
Need wiring diagram for electrolux 1521
Wires came off to change motor. Now they make no sense.
A simple hookup diagram would sure help, please!!!
4 Suggested Answers
  • 3 Answers
SOURCE: electrolux 2100 canister vacuum
Open the door to remove the bag. Pull the side bumpers forward when the door is open. The profile of the edge of the top and the bottom of the vacum body is a "L" shape. The cross section of the bumper is a "I" and that holds the body together. Carefully lift up the top just a little to free the plastic end cap that conceals the cord spool. There are two plastic pins on the top and bottom that hold this piece on and they frequently get broken. (If that happens repair shops drill and hole and insert a screw.)
There is a plastic protector plate that lifts up on either end and then is slid about 1/8th inch clockwise and then up.
Copy the wiring pattern on the four male connectors on the motor and the wire spool.
Post your wiring diagram and it will solve a lot of people's problem trying to reassemble this machine's -- including mine.
Posted on Jan 07, 2008
LizDahl
  • 75 Answers
SOURCE: electrolux canister vacuum
The easiest solution would be to call your local Aerus/ Electrolux representative, because the corporation doesnt publish diagrams.
Posted on Jan 12, 2008
  • 140 Answers
SOURCE: Electrolux Model E switch wiring diagram
The black wire coming from the power cord connects to one side of the switch and the other black and the red wire go to the other side of the switch. If it turns on with the switch in the off position reverse the sides. Good luck. If you need anymore help just ask. Please rate me so I know if I helped. Thanks.
Posted on Dec 31, 2008
Accessory compatibility between Electrolux Models 1521 and Epic 6500 SR
No, they have different connectors. 1521 uses a pigtail hose that has little metal clips. 6500 has a plastic end with an arrow that helps guide you for proper placement. Unfortunately you will need 2 separate hoses for the respective models.
May 12, 2015 | Electrolux Vacuums
Why does my 1521 overheats and turn off
Its probably full of dust and lint, and most likely has something wrapped around the motor shaft. Take it apart and inspect in and around the moving parts of the motor, impeller, shaft etc Best way if you are not too handy and poor memory. Either make a video of disassemble or detailed diagrams as you take it apart. It will make your life a lot easier when you re-assemble it!
Aug 30, 2014 | Electrolux Diamond Jubilee 1521 Vacuum...
How to replace an Electrolux Z331 motor?
Did you follow how motor was taken apart? If not, hopefully color goes with color.
May 06, 2014 | Electrolux Vacuums
I have an Electrolux Epic Model 6500sr canister apart and I need the wiring diagram for it Thanks Jim
Unfortunaly I don't have that wiring diagram. I am sure that the service manual can be ordred thru sears as they are the carriers for this material. What excactly is the issue and maybe we won't need the diagram.
Nov 21, 2011 | Electrolux Epic 6500 Vacuum
How hard is it to replace the motor brushes on a electrolux model 1590 central vac. do they just pull out or is there a proceedure and any special tools required
No it is very simple. You will probably need a pair of pliers, wire cutters and maybe some wire nuts. Remove the nuts that hold the motor down (some have springs that hold them down). Pull out the old motor, there will be three wires that go to it, (2) power and (1) Ground. Most likely you'll have to cut those and splice in the new motors wires with some wire nuts. Then simply reattach the motor the way you removed it and that's it. Good luck!
Nov 24, 2009 | Vacuums
The vaccuum overheats after about 10 min. i have cleaned out all vissable particals , is it the brushes? this is the electralux 1521 model
Have you changed the bag and filter ?
This usually happens when the motor dosen't get enough air over the motor to keep it cool. Try dropping a coin thru the hose and see if it comes out the other end. If it dosen't, try pushing a broom handle thru the hose to move the blockage. NEVER use a coat hanger or anything that could damage the hose and there are electrical wires that run thru it. If you still have the problem, take your vac to the Aerus/Electrolux store.
Joe
Nov 16, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Need a wiring diargam to look at
You won't find a diagram.
You will have series of yellow and white and sometimes gray wires on the outside of the motor housing and often a letter code etched on the housing , indicating the original wiring from years ago, red, blue, yellow, however the newer wiring eliminated those colors.
These wires are almost fool proof as they will align with the longest wire at the furthest point,a center one piggy backed , etc however before starting please post back to advise if you have removed the rewind and or motor and if so, did you disturb the motor wiring inside the motor shroud.
Please post the original problem you opened the vac for as well and I will try to walk you through this
Nov 06, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Dec 30, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux 2100 canister vacuum
Oct 07, 2007 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux Lux 5500 Canister Vacuum Logo
315 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
