How to connect to ZyXEL P660 RU2 EE Windows8 through USB port. Windowse 8 does not detect the modem at all. USB drive connected via USB port free.
How to connect the ZyXEL P660 RU2 EE to a laptop Acer with Windows8 operating system through a USB port. Windows 8 does not detect the modem at all. That's the problem. USB drive connected via USB port free. Service call Acer. It said that if the flash drive is read then everything is normal and should contact the manufacturer modem. With the modem manufacturer's website downloaded and reinstalled all the latest drivers. Internet still not connected. Please help if you can!
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 77 Answers
WINDOW 8 IS NOT GOOD FOR DRIVERS WE HAVE TO INSTALL THEM AS ON WE DO IN xp
Posted on Jan 14, 2013
5 Suggested Answers
  • 65 Answers
SOURCE: ZTE service port FFFD (COM21) drivers for
try here
http://www.rcom.co.in/Communications/rcom/RNetconnect/ecare_downloads.html
Posted on Mar 16, 2009
WhiteFox4
  • 641 Answers
SOURCE: Driver will not install modem. New vista
Have you tried using Ubuntu?
Personally, I have had nothing but problems with Vista and Win-7, which is why I switched to GNU/Linux. I've been using computers, and microsoft operating systems since DOS and windows 95. Ubuntu is the most user-friendly operating system which doesn't require driver installation from the user 99% of the time. Burn the free software onto a disc and try it out to see if you like it.
If you really intend on sticking with Windows, Make sure you are using the right version of the driver for your operating system. There is a 32 bit Vista and a 64 bit Vista.
Posted on Jan 13, 2010
  • 213 Answers
SOURCE: usb device not recognized, works only when plugged on hub
All PCs provides power supply via USB port. The power is controlled by electronic circuit. Sometimes when overloaded the circuit burns out (the last controlling transistor, actually). This does not prevent the data communication, because it is separated circuit. But if the device is not powered it cannot communicate. When you plug the USB device to powered USB hub, then all go right.
Are you able to use the USB ports with other USB-powered devices like USB sticks, mouses, cameras? If not, the mentioned circuit is burned out. If they work OK, then your internal USB hub provides less power current than needed. In both cases there is nothing to do. The circuit resides on the mainboard of the laptop and replacement is expencive. Use it with that external USB hub you have.
Posted on Apr 08, 2012
Testimonial: "that makes sense, although sad that i have to get a powered usb hub somewhere, although i wouldn't know which ones are powered or not, i have this hub that has 4 ports that wouldn't work so i assume that one's not powered. tried to look for small hubs but it doesn't say anything about being powered or not, it'll be quite expensive to buy and try as much as i can. can you suggest a small enough powered hub anywhere? thanks again :)"
maxcarson
  • 7627 Answers
SOURCE: No working windows8 driver
Being a new OS the drivers are available for older systems or devices, sometimes you can use win 7 drivers 32 or 64 bit. The problem may be you have to modify the drivers to work with your specific machine. I had to do the same when I upgraded a Gateway MX6421 (born in 2005) to Win 7 pro N 64bit, I modified a few lines of code in the driver and changed the drivers compatible to win 7.
Posted on Nov 03, 2012
Zyxel P 660HN T1A as a wifi router to be connected to a modem
Website says its 802.11n Wireless ADSL2+ 4-port Gateway, so yes.
May 27, 2013 | Computers & Internet
Tip
Using Zyxel P-600 from two PCs
to use Zyxel router/modem from two pcs for internet usage : it has two ports 1 is USB 2nd is Rj-45 connector LAN port
connect it with one pc via USB cable and connect 2nd via LAN port using Cross cable then its one DSL connection from two PCs.
i am using it and it working good.
on Apr 20, 2010 | Computers & Internet
How does my psp connect to zyxel 280p modem ,its telling me not supported
For direct internet connections on the PSP, only the wireless fuction will work. Otherwise, you must connect the PSP to a computer with Sony's free MediaGo application (search for Sony MediaGo and download the application prior to connecting your PSP to the computer). The USB port on the PSP will not work with USB appliances such as modems, etc..
Jan 03, 2011 | Zyxel Computers & Internet
Can the modem's ethernet port connect to a video game console?
Most modems that have both usb & ethernet connectors are either/or, not both. I recommend using
the ethernet connection to your computer than the usb - the ethernet connection is faster & more
reliable. It also frees up your usb port for other use. If you want both your computer & game console on
the internet, then you need to buy a router which will allow you to share the modem.
Jul 08, 2009 | Computers & Internet
I have an external modem for broadband connection. it connects only via usb i am not able to connect via the phone cable port. what seems to be wrong?
The broadband modem connects to thecomputer using the USB or nework port not the phone cable port.
The network port has 8 wire connectors and whilst they both look similar the network (10baseT) port is wider than the phone port.
You also need to configure or reconfigure the model to let it know which cable you are using to connect the modem to the computer.
Apr 05, 2009 | Acer Aspire 1703SC Notebook
Wireless connection fine but internet connection impossible
if you only have usb connection in your modem, internet on the zyxel router will not work since it's using ethernet connection. in order for your zyxel device to work with tiscali, you will need a cable/dsl router that has ethernet connection as well. you can contact tiscali if they can provide you with that kind of modem.
hope this'll help you
ciao
Nov 10, 2008 | Zyxel Prestige 334 Router
Internet Connection
give the dns value properly in the zyxel p660 and re-installed the driver of the usb adpater
Jun 04, 2008 | Zyxel Prestige 660HW Wireless Router...
Zyxl P660 HW can not connect 1 pc wireless and 1 cabled at the same time. only 1 at a time
hi Bradius,
I suggest you update your P660 gateway's firmware to the latest version, seeing as how the latest firmware has the latest driver for the P660 wireless module. The new firmware can be downloaded at
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906164737&ModelIndexflags=0,420041221102511,420041221102520,420050117110858,420050117110916,420050117110934,420050831093216,420050831095441,420060420160946,420060816160116
After updating the firmware of your gateway, I suggest you update your PC's wireless network adapter's driver to the latest version (if you can supply me with the make and model I'll be happy to direct you to the site where you can download the driver).
If you still have problems connecting the PCs after you have updated as per above guidelines, I suggest looking into how to map the gateway's LAN port 1 and wireless LAN port to PVC (Private Virtual Connection) 1at
http://www.zyxel.com/web/support_knowledgebase_detail.php?KnowledgeBaseID=4805&pid=20040812093058
I hope you find this information helpful in solving the problem.
Please take the time to rate this solution.
Kind regards and thanks for using the FixYa service.
Mar 19, 2008 | Computers & Internet
Zyxel Prestige 600 series
List of user guides for Zyxel modems: http://www.zyxel.com/web/support_download_list.php?indexflag=20040906173729
Jul 26, 2007 | Zyxel Prestige 841 (91-004-226010) Modem
Computers & Internet Logo
126 people viewed this question
David Payne
David Payne
