I need to get into the case of a Samson V25 laptop.
After removing all the screws, I am unable to get inside this laptop. I need to repair the power supply socket. Any help would be wonderful
Barrie
  • 2,229 Answers
The case comes apart at the seam that runs all the way around it. The bottom part has little projections in it that little tabs in the top part fit into. You can use a small screwdriver to pry the case apart (acutally something plastic will ensure you don't leave marks).
But--be careful. You actually have to press in a little on the top half (or possibly the bottom half--depending on the computer) as you are prying apart so you don't break the tabs. Take your time!
Also, you probably will have to remove the posts holding the video and printer plugs.
Posted on Jan 23, 2009
HOw Do I Take Apart a Dell Inspiron1764
LOL, just get some paper cups and label them with the screws you take off so that you will know how to put them back. It would take too long to go into details on how to tear a laptop down, but basically you remove the power cord, remove the battery, remove screws from the bottom case, remove the disk drive, remove the memory, remove the cd drive, remove the wifi card, remove the dvd drive, remove screws inside battery case, remove screws inside the hard drive case, remove screws inside the cd case, turn the laptop over, open the lid, remove the strip above the keyboard, remove screws holding the keyboard, remove the keyboard, remove screws holding the palmrest, remove the palmrest, remove the lcd hinges, remove the wires coming from the lcd going down thru the palmrest. Lift the motherboard out.
Apr 01, 2012 | Computers & Internet
Reset sens v25 bios
to reset the BIOS, remove/reinsert the CMOS battery which is inside of your laptop ryanpajaro20_10.jpg Kindly consult your PC dealer for the teardown of this device
Mar 23, 2011 | Samsung V25 CXTD 2000 Notebook
Power jack needs replacing aspire 5050 model zr3 laptop
There are TONS of screws in laptops, mainly hidden.  I just took apart a laptop today, and it took me a couple of hours to get the screws out.  There are so many screws!  They are usually under the panels in the back as well.  Here is a link for your computer model Acer Aspire 5100 http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
May 12, 2009 | Acer Aspire 5100 Notebook
Blank screen
Might be the VGA connector to the motherboard.
Turn upside-down. Remove screw in the centre marked KBD.
There are 4 screws running along the back. Remove the 2 inner ones.
Lever up the keypad with a small screwdriver - Careful not to disconnect the ribbon underneath.
Undo the 3 screws along the strip above the keyboard and remove the strip.
VGA connector is next to the power button. Check it is pushed down firmly.
NKYG
Dec 03, 2008 | Samsung V25 XVC 2800 Notebook
Compaq Presario 1000
I have a Presario X1050, not sure if they are similar. Remove the screws from the bottom, carefully remove the keyboard with a small flat head screwdriver. You'll find many screws hidden by small plastic covers and rubber feet that will all need to be removed with the screwdriver. You may have to remove the display to get inside the laptop. Ultimately though, the power supply is actually external included on the power cable.
Jul 01, 2008 | Compaq Presario Notebook
Samsung V25 fan replacement
It may not be the fan, I have a V25 and it was the motherboard, it wouldnt power the fans anymore when the CPU required it so would crash lots.
If the fans twitch or run for a second or two when you first turn the laptop on then it's the motherboard that is faulty.
Careful with the monitor to motherboard plug as I damaged mine and the screen is now a permanent shade of blue.
Jun 25, 2008 | Samsung V25 XVC 2800 Notebook
Upgrading memory on a V25 Samsung laptop
Make sure you are ONLY taking off the cover needed to change the RAM. Other screws may hold sensitive parts in place. Go to the laptops makers website and see which screws need to be removed. Its a good idea to also see if you need to change any settings in the BIOS once RAM is installed.
Apr 27, 2008 | Computers & Internet
Samsung v25 laptop
open your laptop back side.
the ram is on the battery position.
replace it.
Apr 02, 2008 | Samsung V25 XVC 2800 Notebook
Samsung V25 Laptop When it is powered up nothing is showing on the screen although the power light is on and you can hear a noise. This has happened before and it just came on.
One way to make sure the system is still working, remove the Batery, then plug the power adapter only and turn the computer back on, normally if the laptop goes into Hybernation mode and the battery is low on power this can happen. If that fixes the system then you can do a safe shutdown and re-install the battery and turn your laptop on and it should come on, the fact that you mentioned this has happened before makes me believe it is Hybernation issue. Good Luck.
Jan 07, 2008 | Samsung V25 CXTD 2000 Notebook
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
