Question about Rectorseal Safe-T-Switch
Water in the Safe-T Switch
AC is off and won't turn on
  • 22 Answers
It is a Condensate Overflow Control , your drain line may be clogged if it is clear and no water present you may have a bad sensor. If the unit is not draining properly it can cause a freeze up of the coil and compressor damage.
Posted on Jan 14, 2013
Won't power on
It might be that the water flow switch is faulty, this will allow the unit to light up but will not start
Jul 12, 2013 | Heating & Cooling
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
Jun 04, 2013 | Frigidaire FAX054P7A Wall/Window Air...
Previa rear ac switch won't turn on. relay, resistor and all fuses ok.
may be you should make a diagnostic and you can do it in a garage or you can do it by yourself if you want to do it by yourself you need some tools and you can find some good ones here: http://www.spobd2.com
Feb 17, 2013 | 2004 Chevrolet TrailBlazer
Won't turn on
Have you tried a different AC outlet? A different Cord/Charger? Has the AC jack been damaged? The on/off switch damaged? Is the battery Charging? Need more info.
Dec 20, 2012 | Gateway MX6441 Notebook
2008 impala got in this evening and ac won't turn
Someone will need to check the fuse for the blower, then the blower motor and the resistor.
Aug 09, 2012 | Cars & Trucks
SW1 AC will only go on high or turn off, it won't turn on a lower setting. Help? what could it be?
What you mean is the blower motor will only run on high, right ?
It could be the fan switch or the resistor.
Jul 09, 2012 | Saturn Cars & Trucks
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My Dell Inspiron m5030 won't turn on. It was
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
Just try this and leave a feedback for next steps.
Jun 16, 2011 | Dell Computers & Internet
If i remove my aircon compresser will my car still be safe to drive ???
If you remove the A/C compressor and don't make the needed changes for the serpentine belt to still be installed, then no it won't be safe ot drive. You won't have any power steering for one and that would make turning the wheels extremely difficult. Since the water pump also need the sepentine belt to operate, your engine will overheat in a short amount of time.
Apr 26, 2011 | 2000 Chrysler Grand Voyager
The heater/ac fan only works on speed settings 4 & 5
you might check your switch sounds like to me that your two lower speed sides of the switch maybe burnwed out.
Dec 19, 2009 | 2002 Chevrolet TrailBlazer
Rectorseal Safe-T-Switch Logo
143 people viewed this question
Top Rectorseal Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Rectorseal Heating and Cooling Expert? Answer questions, earn points and help others
