Question about Health & Beauty
Salter mibody scale has ERR reading - Health & Beauty
  • 86 Answers
SOURCE: how do i contact salter scale customer service i
you can contact our customer service by this email address
sales@accurate-scales.com
Posted on Aug 04, 2009
SOURCE: HealthSmart bathroom scale displays "Err"
Put scale in round file can. Buy another cheap scale.
Posted on Oct 05, 2009
Testimonial: "The new scale works great and was on sale at Wal-mart for only $29."
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Posted on Oct 18, 2009
SOURCE: setting the clock on salter scale model 5007
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h option.press the g-oz key to set the time.
And your done.
Posted on May 23, 2010
SOURCE: Kitchen scale, Salter, model 2006: change batteries
The 1 part just slides off.
Posted on Jun 28, 2010
After changing battery, why does err appear and not a 0?
The replacement battery could be defective or installed incorrectly.
Sep 05, 2015 | Salter 9037 - Digital Bathroom Scales /...
Salter
I have been able to locate a manual for Salter Mibody scales. Not sure if this is what you are after.
http://www.mibody.co.uk/EN/9119/downloads/Instructions.pdf
Aug 08, 2014 | Health & Beauty
My Salter bathroom scales (model 929) are showing an ERR message. They seem to think everything weighs more than it does as if u press gently on them the weight goes up really quickly until limit reached...
The best day chessboard type is the traditional type of weight, in contrast, electronic weight scale error degreehighestelectronic
tems, affected by environments, bumps can make reading deviation.The use of electronic weight meter can more precisely?
Electronic scales are generally placed in the hard flat floor use, not on the carpet or other soft object surface by using.Each weight to body weight in the same place, the same time, wear the same clothes.
Hello, I just see a online stores
http://www.tmart.com/Digital-Scales/ sell digital scales. Some advice, for reference purposes only and finally I wish you luck!
Jul 25, 2011 | Salter Health & Beauty
Using Salter Mibody scales software - when trying to upload from the usb stick, i get the following error message - Wrong Data: Cannot update. Database or objet is read-only. I am running on Vista. Any...
I had this problem in Windows 8 recently , my solution was to enable administrator settings by right clicking the shortcut
- click properties - click shortcut tab - click advanced
- tick run as administrator
- click ok - click apply - click ok
Then to be sure I right clicked shortcut
- click properties - open file location to find where it was installed
- right click salter mibody.exe
- click properties- click compatibility tab
- tick run this program as administrator
- click apply - click change settings for all users
- click apply - click ok - click ok
not sure what bits of this made it work :)
but it worked for me
Feb 06, 2011 | Health & Beauty
E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
Sep 18, 2009 | Salter 2001 electronic kitchen scale
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Health & Beauty Logo
204 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
