Question about LG LFX25960ST Stainless Steel French Door Refrigerator
LG French door refrigerator clean drain pan
Clean self defrosting
22yooper
  • 828 Answers
SOURCE: LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Posted on Jul 31, 2008
SOURCE: how do I reset the lg water filter indicator light
i fixed the problem by asking my son. he has more patience than i and just held down the button longer and it worked.
Posted on Oct 15, 2009
  • 161 Answers
SOURCE: LG Refrigerator; light stays on, not cooling
There is a recall for that problem the main board is bad. Contact LF for advise
Posted on Jan 24, 2010
  • 5 Answers
SOURCE: LG Frig LFC23760ST 3 Door French Refrigerator : No power!
Little late, but the same thing happened to me. With a continuity tester you should be able to check to see if the fuse is good/bad, but make sure there is no power going to the board. Mine went bad but since the fuses are integral to the board, the entire board was bad. $20 later after a visit to RadioShak, I was able to remove the fuse, and install a fuse holder in its place. Never soldered on a printed circuit board before, but thought it worth a shot since the board is $200! I say try and trouble shoot it yourself. It worked out well for me.
Posted on May 08, 2010
TheMobilian
  • 8220 Answers
SOURCE: French door LG refrigerator with freezer on the
It might be something simple like the water faucet is not open all the way
LG FRENCH DOOR SERVICE MANUAL
Posted on May 21, 2010
LFC25760. I saw an answer to my question but now I can't find it.
It may be a good idea to pay somebody to come out and clean the defrost condensate drain it's pretty complicated for just the homeowner to do. I do this all the time that requires taking the freezer drawer out the freezer door the rear wall of the freezer and defrosting the drain and forcing water through the drain to ensure that the drain is open before you close it back up I also install a piece of copper wire from the defrost heater element into the opening of the drain to ensure it does not freeze over again.
Aug 08, 2016 | LG LFX25974ST Energy Star 24.7 Cu. Ft....
Refrigerator not cooling
The self defrosting mechanism is fubar. Check out the defrost timer and defrost element for proper operation. Chances are that the element is open.
Jun 25, 2016 | Samsung RF266ABRS Bottom Freezer...
I have a Samsung model RF4287HA French door refrigerator. Has anyone had success cleaning the drip pan located at the bottom rear of the refrigerator? I know that this pan can't be removed, but I can'
Hello Derek;
My name is Peter. I am a retired field service refrigeration technician.
In answer to your question, the drain pan is removable. This drain pan is available for purchase. The problem is both Samsung and LG are not service friendly. The drain pan is not secured with fasteners and just lifts up.
However, There is the interference from the seal system (refrigerant) tubing and compressor which prevents you from pulling the drain pan out.
On my service calls with drain pan leakage, I just repaired the drain pan with duct tape an silicone adhesive. Because I could not get the drain pan out with out moving the compressor.
Both, Samsung and LG are the worst service friendly and highest cost for repair.
Jan 19, 2015 | Samsung RF4287HA 28 cu. ft. French Door...
Why Icing on bottom freezer
Your drain hose in the bottom back of the freezer is clogged and Iced up and all the defrost water is staying in the freezer and building up. You need to take the freezer back panel off, remove all the ice, defrost the drain, clean, flush with hot water and test the drain line to reach the drain pan under the fridge.
Aug 18, 2014 | Whirlpool Whirpool 26 cu. ft. French Door...
I have an LG french door bottom freezer refrigerator. Water is coming out of the back freezer vents and then pooling and freezing on the freezer floor. If we don't remove it periodically it leaks onto the...
This has nothing to do with the ice maker. The defrost drain has frozen over. Inside the freezer you will see that the whole back is a panel. Unplug the unit and gently pry at the top of this panel. It will come forward and then you can lift it out. unplug the fans and take the panel out. You will see the coils. and underneath the coils, the drain pan. Mine was completely filled with ice. I used a hair dryer to melt it and remove the large chunks. Be gentle. Use a turkey baster to remove excess water. Then pour some very hot water in to clear the drain itself.
Sep 04, 2013 | LG LFX28968ST Refrigeration : Refrigerator...
LG LFX25975
If you have water in front of the refrigerator often your drain hole is frozen over and not allowing the water from your defrost cycle to drain into the drain pan. You can manually defrost this by disassembling the rear of your freezer and using a hair dryer. I would suggest that you simply unplug your refrigerator make sure you prop the doors open and allow it to defrost for at least 12 hours.
http://www.on-timeappliance.com/refrigeratorrepair.html
Mar 28, 2012 | LG LRFD25850 French Door Refrigerator
We have a LG french door refrig, Model #LRFC25750TT. Ice forms in the bottom of the freezer which causes the door to stick when opening and closing. It appears that water may be coming from the vent on...
You have a frozen drain tube. Remove the back cover after unplugging the unit. Locate the drain tube running down to the drip pan. If it is frozen, thew it with a hair dryer. In the inside, find the drain hole and pour hot water in it until it drains properly. I f it happens again your defrost element is too far away from the aluminum drain pan and needs to be GENTLY lowered closer to the drain
Dec 03, 2010 | LG LRFC25750 Refrigerator French Door
Ice forms in bottom frezer of lg unit
THE BOTTOM DRAIN MAY BE CLOGGED CLEAN THE DRAIN AND CHECK THE DEFROST TIMER
Oct 24, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Water accumulating under the vegetable boxes in the refrigerators
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 06, 2009 | Refrigerators
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
