I need the unlock code to play dvd and blurays from other regions
SOURCE: toshiba HD-A35 region unlock
I am in need to find what an error code is on my HD DVD player. The code is 408 bc 504.
SOURCE: WANT TO PLAY REGION 1 DVD ON REGION 2 DVD PLAYER TOSHIBA SD370EKB
try this:
http://www.avforums.com/forums/showthread.php?t=508285
SOURCE: Magnavox DP170MW8B DVD region code
After getting clarification from Fixya I can pass the links below to you to check yourself
Some players are harder than others to do this but you may want to try here or here
Comments:
Toshiba's and JVC's are the harder ones to do
I use a Phillips myself as it is not only cheaper but has much more going for it than many of the higher end units. i throw anything at it and it just plays
The older the unit that harder it is to do the region free thing with.
I let my EX have the panasonic (big grin)
If you cant find a fix then look at the codes available for cheaper brands and how easy it is to do it before you purchase one.
SOURCE: seeking unlock code for toshiba sd-2500 dvd player
Sort answer, you can't.
It's locked in by the manufacture.
But there are a lot of hacks that might allow you to unlock them.
http://www.videohelp.com/dvdhacks or similar site and see if your exact player model is in the list.
If so follow the instructions to unlock or reset the player.
Testimonial: "many thanks for your quick response"
