Question about Electrolux 18 in. ESL424 Built-in Dishwasher
Water will not drain away from my Electrolux esl 424 dishwasher
4 Suggested Answers
  • 1314 Answers
SOURCE: Electrolux ESL 6225
before you operate the dishwasher get your water as hot at the sink as you can this will prevent filling the dish washer with cold water and i would use powder or liquid now if you not sure of your heating element turn your washer to dry close the door for about 2-3 minutes get a glass of cold water open the door and pour water on the element if it sizzles its working
Posted on Feb 12, 2008
SOURCE: electrolux esl 6251 built in dishwasher 2 years old
PROGRAM WONT RESPOND MACHINE NOT STARTING
Posted on Apr 11, 2009
  • 1214 Answers
SOURCE: it fills with water and then continues to wash but
Problem is either a bad controller board or bad heating element.
You will need to know how to diagnostic service work using a volt-ohm meter, and be mechanically handy if you want to diagnose and repair.
Posted on Dec 11, 2009
Hi, my dishwasher is stuck draining and issuing the three beeps 'anti-flood' error with no sign of a leak? Is it possible to re set this?
you need to remove the bottom plate and clean up any water. it most likely means there is a leak in the gasket around the door and it tripped the flood sensor. the only way to reset it, is to deal with any water and dry it up and then power down and power up the washer.
More importantly I would look for leaks. Bad hoses or possible rubber that dried out and cracked. Maybe someone spilled water and it got on the sensor too. Either way , water is what causes that sensor to activate.
Sep 02, 2015 | Dishwashers
Hi wont start. just making a loud whiring noise.
According to your description of the fault, something was blocking drain turbine of main motor. Dishwashers always first start drain water because calibration of water level inside dishwasher (empty). In your case, the main motor is same motor for washing and draining. Runing in one direction means washing, runing to oposite side means draining.
The solution is to open a turbine pump and remove all obstacles and visual check turbine impeller,ceramic seal and plastic sleeve on the motor shaft.
Dado
Mar 26, 2015 | Electrolux Dishwashers
Electrolux dishwasher esl 6114 door does not lock
Hi Peter Gumbrell - Often when the dishwasher door does not lock, it is because the of door lock assembly. The door lock or latch may either be faulty or damaged. If I was in your position, I would personally recommend consulting a professional to accurately diagnose the dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Mar 20, 2013 | Electrolux Dishwashers
Electrolux ESL 43010 does not get hot ,and the dishes are not clean any ideas?
Hi - If the unit is not drying nor cleaning properly, there are two main things to check first. Is the incoming water temperature at least 120F (49C)? If not, I strongly suggest that the temperature be adjusted on your water heater. Are you using rinse aid? Use a rinse agent to increase drying performance and using Sanitize or Air Dry Off mode also helps improve drying. If any proves to be ineffective, contact a professional to move forward accurately.
Oct 26, 2012 | Electrolux 23 in. ESL6114 Built-in...
Hi, I have an Electrolux ESL 4115. It seems to be stuck on 50 degrees but wont start as usual when I close the door, the on/off button works and lights functioning as normal but that's all. Thanks
I had a similar problem - seemingly stuck or locked with a solid light showing (in my case on the 65 degree wash). Nothing seemed to unlock it. But when I closed it and went away to think about what to do next - some 5 minutes later - it made its end-of-cycle peeps. It now works fine. All I can think of is that I must have interrupted the previous wash cycle l was using before it had ended, and had left the door ajar. all it needed was the door closing for the cycle to finish. Does that help?
Sep 22, 2010 | Electrolux 24 in. ESI6220X Free-standing...
It fills with water and then continues to wash but the water does not heat up.the program does not progress.electrolux esl 6114.
Dec 11, 2009 | Electrolux Dishwashers
Electrolux ESL 6225
Feb 12, 2008 | Electrolux 23 in. ESL624 Built-in...
Electrolux 18 in. ESL424 Built-in Dishwasher Logo
65 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
