Question about Pioneer Audio Players & Recorders
WHAT SIZE IS THE DRIVE BELT ON PLJ400 TURNTABLE
REPLACEMENT DRIVE BELT
  • 832 Answers
SOURCE: broken drive belt
Yes, just get the broken belt (to serve as sample) and
get your replacement from the electronic store.
Posted on Sep 28, 2009
lesliemurphy
  • 69 Answers
SOURCE: Broken drive belt replacement procedure P 680
Try contacting this company for a copy of the manual for your deck?
They will send you a full photocopy of the manual for a small charge?
Or they will tell you how to replace the belt?
service<remove>@turntableneedles.com
Posted on Oct 20, 2009
hondo73162
  • 132 Answers
SOURCE: Technics SL-J1 turntable drive belt
Hello Cliff,
You will need 2 belts, if the turntable belt is gone the other is not far behind . One for the turntable size 23.6 inch by .188 and one for the tracking motor that is in the top cover part, is a 3.0 inch by .046 belt. best place to get them is at kenselectronics.com part numbers 1407-201 and AV-SBS3.0 if you have been checking around you will see other sizes, I have a SL-J1 and have used these and they work perfectly.
Tony
Posted on Nov 13, 2009
SOURCE: Finding the drive belt size for a Sansui SR 222 Mk2 turntable
http://shop.ebay.com/dappletoft/m.html?_nkw=&_armrs=1&_from=&_ipg=25
Posted on Dec 13, 2009
SOURCE: what size belt do I need to get for an Akai APB1
Go to vintage electronics.com and put in model #. Very quick turnaround.
Posted on Jan 13, 2010
Turntable drive belt for model ITTRR-501
It is very difficult to hunt down a turntable belt, take the belt to a TV service shop, he should have a belt gauge to measure the belt in hopes he has that size in stock.
Mar 07, 2012 | Innovative Technology ITRR501 Audio Shelf...
Pioneer turntable is powering up but not not spinning?
Turntable Drive Belt
The chances are the rubber drive belt has either broken or stretched so that it has fallen off the drive pulleys.
You will need to gain access to the underside of the turntable to replace it.
With most turntables the process will be to secure the tone arm (a rubber band will do the trick) before turning the whole thing upside down and unscrewing the base.
Replacement drive belts are easily available on the internet. Search by make and model number of your turntable
Feb 18, 2011 | Pioneer PL-990 Turntable
The drive belt off my AWA turntable has come off and I cannot re-configure it
undo clip on centre of deck circlip normally (round clip) remove deck platter round plastic that records sit on...when removed turn over replace drive belt if brokern . if just come of place belt around the inner circle so there are no twists etc on the belt ....look at near outer edge of platter there is a clip you can stretch belt to to hold so you can put over drive motor...(belt stretch from centre to clip creating v with the bely as you veiw from above ..locate motor on the deck noe alifn top of v with positin above motor .. when done drop down platter onto centre shaft again.gently turn the platter clock wise until belt locates correctly with deck ..replace clip and test ..if ok done ..if not repeat until you get it right....sometimes over time belts stretch so a new belt may be required ..ebay can supply most belts . type in turntable drive belt ..measur size of belt by cutting is it..(if strectched and no use) measure lenght of belt find replacement belt that is smaller than measurment .i.e nearest size ...hope this helps yammandan
Aug 19, 2010 | Audio Players & Recorders
I need to put the belt back on th KD 48F turntable
its likely that the belt has stretched and therefore will keep happening as its no longer http://www.needledoctor.com/Online-Store/Turntable the right size? go to this site for a replacement?
Aug 21, 2009 | Kenwood Audio Players & Recorders
What size belt does a Sony PS-LX300H USB turntable use?
These replacement parts are purchased for the model turntable that they are to be installed in. They are not generic and are not bought by "size" as say a fan belt for a car would be. I googled "Sony PS-LX300H Belt" and got:
http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=STPSLX0300H
May 07, 2009 | Sony PS-LX250H Turntable
KM837 manual to fix belt on turntable
IF the belt fell off, it is likely that the belt is stretched and needs to be replaced. Use a couple of pencils to open up the belt and beasure the length. The belt should go around the two pencil erasures forming an oval. Use that measurement to determine the belt size and purchase a replacement belt. The belt will go around the platter and around the motor hub.
Dan
Feb 03, 2009 | Crosley CR248 Turntable
Hello Cliff,
Tony
Nov 15, 2008 | Technics SL-1210 Turntable
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
