Question about Equestrian
Is it ok to wash horse boots in the washing machine?
    Guru:
  • 269 Answers
Yes. You don't even need to use the delicate cycle. Just use a hose to get the mud off and them put them in a normal cycle. You can even put them in the drier when they're done.
Posted on Jan 14, 2013
Mr christmas carousel lights above each horse won't turn on
i would check any bulbs it might have some times it only takes one to blow to stop the others working.not saying this is what is going on with yours .
Nov 30, 2016 | Washing Machines
Why is it not spinning out
Ok is it at least washing? if so may not be ur motor coupler? if direct drive. But may be a bad clutch or tranny? Even a bad belt if belt driven? sometimes even a bad door switch will not allow it to go into spin? u can check with a multi meter.
Aug 30, 2014 | Crosley Washing Machine CAH4205AWJ,...
Can i put air lite tendon boots in the washing machine?
You can but the best way to clean them is with a medium bristled brush and shampoo
Apr 30, 2014 | Equilibrium Tri-Zone Airlite Tendon Boots...
Where to find a Dyson washing machine engineer in the Weston-super-Mare area?
Dyson no longer manufacture or supply the parts. Your only hope is to get a second hand part. Not hard to fix.
Apr 29, 2014 | Dyson Washing Machines
SAMSUNG WF-J1254 washer very shaky when it's spinning, Help.
machine must be level there are 4 adjustable legs (1 in each corner) place a level on machine , level left to right and front to back.also check manual for initial set up there may be shipping screws that need to be removed on the back of the washer. good luck
Jun 11, 2012 | Samsung 3.7 Cu. Ft. Stackable Front-Load...
My daughter washed a horse blanket and afterwards, my washer doesn't spin, the clothes get wet and lay there. Could she have snapped a belt or thrown the drum off track with the weight of the horse...
Yes , it is quite possible that a load exceeding the limit of the washer can damage the belt or the drive of the washer and so it is important that a first hand observation is most important before we can speculate on the issue.
Please remove power and check manually on the motor and drive, now connect and with precaution check the drive , if there is power on motor or if there is a failure from the program controller unit.
Aug 31, 2011 | Maytag Neptune MAH5500B Front Load Washer
Puddling on floor during high speed spin cycle
you have a leak in your outlet hose normally caused by rubbing on the drum barrel / repair with tape or replace whole hose but this brand of wASHER ITS VERY HARD TO REPLACE IF DONT KNOW HOW TO
Apr 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Oct 05, 2009 | Hotpoint WMA31 Front Load Washer
I have a 4 year old Calypso Sears washer. With medium to large loads, and heavy loads, such as towels and blankets, it will wash the clothes, but stops and shows a code of CA or Cl when it goes to do the...
If you want a work horse, find your local Speed Queen dealer and buy a Top loading washer, Look for a model like an AWS76NW or AWS52NW. Basic Top loader, work horse.
Let me know if you have questions.
Aug 21, 2008 | Washing Machines
Equestrian Logo
766 people viewed this question
Top Equestrian Experts
JOHN BROWN
Bill Taylor
Bill Taylor
Level 1 Expert
Bill Boyd
Are you an Equestrian Expert? Answer questions, earn points and help others
