Question about Home
What can I use that is insulated to carry a bottle of wine around for a couple hours on a hot day? Preferably something that looks normal and is easy to carry around.
    New Friend:
    Problem Solver:
  • 16 Answers
This tote is really cute. I would't mind walking around with it even when I'm not carrying around a bottle of wine.
http://sachi-bags.com/products/index.php?route=product/product&path=3&product_id=83
Posted on Jan 14, 2013
Is it safe to drink bottled water that was left in a car?
That depends on whether the water is the original water which came in the sealed bottle, how long its been in there, how hot it has become and how many times it's been heated. If you left it overnight and it didn't heat up, it's probably OK. If it's been in a hot closed up car all day, pitch it. Another mistake is to reuse the bottle, adding tap water repeatedly and never washing the bottle, allowing germs to grow and grow. Don't do it.
Jul 16, 2017 | Wine & Spirits
Danby DWC2121BLS dual commpartment wine cooler is cooling normally but after 2 days aprox the temperature increase and beeping and flashing hi
If evaporator starts to freeze up the ice accumulated serves as an insulator and the temps go up. If you turn it off and let ice buildup melt the unit will work fine again until it refreezes.
Check if unit has a device to prevent ice build up. If so, it is not working. If warm moist air is entering the area of evaporator coil, that could also be causing the buildup.
Sep 26, 2016 | Danby Silhouette Dual Zone DWBC14BLS 13.90...
The left side exterior gets too hot to touch at times,is this normal?
Yes it can get quite hot, remember there is a compressor running in there.
Aug 15, 2016 | Whirlpool 22" Dual Zone 38 Bottle Wine...
40 amp. fuse keeps blowing out on 2008 harley
You have a short. Check the insulation on all wiring that carries + voltage - possible that some wire may have lost insulation and is abutting some metal part shorting it out.
Aug 24, 2015 | 2008 Harley Davidson FXCWC Softail Rocker...
Food network electric wine opener will not open
Take a look at this review and see if you are missing something in its use. Basically, put in charger base, connect transformer to the mains and charge for 8 hours. Remove the foil from the bottle top, put the wine opener on top of the bottle and press the button.
Oster Electric Wine Opener Review
Feb 23, 2014 | Sunbeam Oster Electric Wine Bottle Opener
Cabernet 500ml carton
First off 500ml seems like quite a small amount of wine as the traditional bottle is 750ml, but okay. If the foil seal was punctured before your purchase there is an easy way to tell if the wine has gone bad. Pour about a shot glass worth of it into a typical wine glass and swirl it around in the glass for about 10 seconds. Smell it while it's still swirling and if you pick up any instant sour notes then your wine most likely has started to sherry. Not that this will hurt you in any way, but it makes the wine less enjoyable. If someone opened it before and allowed air into the wine that's all it takes. My advice, stick to boxed wines as they are engineered not to allow air into the wine at all and can keep for a very long time if refrigerated. Better yet, grab a bottle of some of the good stuff and drink within 2-3 days of opening, keep refrigerated.
Jun 29, 2013 | SONOMA VENDANGE WINERY Wine & Spirits
Condensation on wine bottles
door not sealing ! or seal around entrance for cold air is sucking in hot air with cold air to create condensation
Sep 03, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
Danby DWC2727BLS temperature does not go lower than 60 degrees
am having the same problem, and same circumstance. Did you find a solution?
Jun 11, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
Does not cool. Compressor Hot
Sounds like the compressor starting relay. This should be available from from most appliance parts retailers that carry refrigeration parts. It is probably a plug-in relay which is easy to replace. PULL THE PLUG UNTIL YOU GET IT! Constant cycling on the thermal protector will damage the unit.
Ray
Oct 19, 2008 | GE PWR04FANBB Wine Cooler
Home Logo
431 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
