Question about Boating
What companies have 3 passengers watercrafts?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
A bunch of companies make 3 passangers watercrafts: Yamaha, seadoo, Kawasaki, Honda, Suzuki, KTM.
You may want to try to read more about each and then decide which one you would like. I suggest that you will type the specific model you want in google and get more information.
Posted on Jan 14, 2013
What size propellers should be on a 1999 mainship 430 with 350 3116 cats
The size that lets the engines turn the proper RPM with the load aboard the it is usually going to run with (fuel, water, supplies, passengers. That is too involved a calculation for the little info given.
Oct 14, 2014 | Boating
Google comvaxhall 1.3cdti
Check tires for sidewall damage or 'Wavey-treads', (Indicates broken-belts inside the tires.) and make sure the rim's lugnuts are tight. If the vibration smoothes-out above 50-55 MPH, get your tires balanced, if the vibration increases above 55MPH (and the car is a frontwheel-drive.), likely a constant-velocity-joint is failing. Usually the passenger-side fails most often.
Sep 05, 2014 | Boating
Why does my car shudder when doing approx 40klms an hr? Its a automatic car.
Check the tires to see if the rims/lugnuts are loose, then inspect the tire tread for 'wavey' spots in the tread and/or sidewalls. (Indicates broken belts inside the tire)...If the vibration smoothes-out after 5-55 MPH, it would be tires out of balance...if it gets worse, and is a frontwheel-drive, likely a constant-velocity-joint going bad in one of the front axles. Generally the one one the passenger-side fails first.
Sep 01, 2014 | Boating
PRICE OF PULLEY DRIVE BELT, 5/8' WD X 3/16' THK. REINFORCED RUBBER. MFG : WATERCRAFT, P/N : 722161010, FOR BOAT NO : 9513584, YEAR 1995
Good day,I will appreciate if you can provide us with a quote for the item(s) below.
POWER SUPPLY, P/N:RA0200551510 1 each Manufacturer: ELCON
Manufacturer Part No: IRQ502051221
POWER SUPPLY, MFG: ELCON, VENDOR: GE OIL & GAS, GE O&G P/N:
IRQ502051221 Kindly indicate any discounts and Total Material weight plus packaging in kg. You can contact me via my phone number below.
Best regards.
James Bassey
9700 Leawood BLVD,1716
Houston TX, 77099 USA
Tel: +15123175858
Oct 02, 2013 | Mercury Boating
After seating for 3 years would not run
clean injecters and replace fuel ! compressions 100psi or more !?? sparks on all 3 cylinders ?
Aug 25, 2013 | WSM 1996-2003 Kawasaki Zxi 1100cc Jet Ski...
My 95 yamaha waverunner 3 will crank but won't stay ctanked what's going on?
check connections clean and no breaks in wires , check solinoid and starter in good order !
Jun 22, 2013 | Covercraft Personal Watercraft Cover -...
Seadoo jetski
have you got any fault codes on the screen ? has the intercooler been checked for leaking in to the intake manifold ? press the set button 5 times to see codes if any ! how old is the fuel ? over 5mths then replace !!
Jun 20, 2013 | Boating
Where is the fuel filter on a 1992 bmw 525i located?
I believe on this particular year model, the filter is located inline on the passenger-side near the rear tire.
Aug 01, 2011 | Moeller InLine Fuel Filters Replacement...
Boating Logo
336 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
