Question about ASUS Eee PC 1215P-MU17-RD Netbook
Tach paed properly not done - ASUS Eee PC 1215P-MU17-RD Netbook
  • 60 Answers
Instal the proper softwear or reinstal windows.
Posted on Jan 21, 2013
1996 Triumph 900 Tach problems
I have a similar problem with mine, but the drop from three to two cylinders only happens when moisture gets into the tach -- the tach itself has been jumping around for years and I pretty much ignored it until now that I'm having the problem. The Tach is connected to a coil, and the moisture appears to short the circuit, preventing the cylinder from firing properly. Perhaps other problems with your tach are causing similar problems with the coil, even in dry weather? I just ordered a new Tach from 2wheelpros.com after shopping around for a while. There may be some aftermarket alternatives for less, but I'm in a hurry to get my bike running again for a charity event, and don't have enough time to look into aftermarket parts and hope they work. I hope this helps -- good luck with yours.
Apr 13, 2013 | 1996 Triumph Triumph Thunderbird
Remote start python 533 attempts to start the car, shuts off, then on a again, does it 3 times, then stops
There are three possibilities for the situation you are describing especially if the vehicle has been cold for a while. The first possible cause occurs when the smart tach feature is used. In this case, the 533 is not receiving the proper signal from the vehicle that shows the engine is running. The remedy for this problem is to connect the tach wire from the 533 a proper tach source. The other two causes occur when the smart tach feature is not used and the tach wire is connected. If the tach wire is not connected to a good source for the tach signal in which case the wiring will need to be corrected. Otherwise, the tach signal will need to be relearned.
Jan 17, 2013 | 533 2way Security Remote Start System
No sound from either channel
Since it is a PA amp
• Check first if input signals are getting through the amp.
• Check if all the outputs are properly connected.
If you have already done, checking..
• Check for shorted power transistors, and extract in pairs.
If it powers up, without protect..
• Check again for possible additional components before replacing
the bad ones.
A good amp never produce an over of 0.7V on its output.
Sep 06, 2012 | Technical Pro PA-2000 4-Channel Amplifier
I have an 89camaro irocz 28 with 5.0, with a rebuilt tranny about 3 yes ago. While driving on overdrive at about 40-50 mph it will shift into od geer then back to 3rd then od again what could be causing...
Yes it can be what it is doing is called hunting, As for your RPM tach it has nothing to do with it, Now your transmission is a 4L60 and YES it does need a tach signal or the RPM signal it doesnt matter if your Tach gauge doest work but it need the tach signal for the transmission to work. And NO there is NO VSS it needs TACH. or it will hunt for a shift that is why its doing this.Youll need to restor the TACH to the transmission so it can shift properly, Now youll either have a 4pin connection,1 wire or youll have a 4 pin 2 wire connection or youll have a 4 pin 3 wire connection This transmission need tach signal so bear with me i am going to some how draw it pretend your looking at the switch. connection
l-------------------------------L
I A B I
I C D I Okay the C is TACH that has to work
Apr 23, 2011 | 1989 Chevrolet Camaro
Tach reads double of old one
look to the connection of the tach wire, see if its on the green wire of the coil, if it is, then clean the connection and see if that helps, if it still doesnt work properly you may have a faulty gauge
Jul 03, 2010 | Autometer Auto Meter TachometerSpeedometer...
Install 25/8 tach 2003 softtail
hd dealer carries plug in harness for it your computer wont tolerate a mistake on spliceing into existing harness although it can be done tach accuracy may suffer
Jan 02, 2010 | Harley Davidson Harley-Davidson Motorcycle...
2002 jeep grand cherokee with valet remote start. when remote start is activated jeep starts then shuts off immediatly
Apart from the inginition wires ( you must check if there are 12 volts), the alarm needs to read the tach reading properly from the car to stay running. If the tach rate is not learned by the system, it will cut out almost immediately. You need to ensure that this tach wire is connected to the tach under the hood. When this has been connected, you need to ensure that the alarm learns the rate. This can be done automatically on some models or manually on others. Ensure that the appropariate wire is connected to your tach wire; it should work properly after that
Jan 02, 2010 | Directed Dei Valet 561r Remote...
Fuse for tach
THERE IS A 10 AMP IGNITION 1 FUSE UNDER THE HOOD IN THE PDC.THERE IS NOT A FUSE FOR THE TACH.IF THAT FUSE WAS BLOW NONE OF THE GAUGES WOULD WORK.U COULD USE A SCAN TOOL AND CK FOR TROULE CODES.
Apr 21, 2009 | 2000 Chevrolet Silverado 1500
97 town and country LXI mini van speedometer and tach not working
the cluster needs to be calibrated to the pcm before the speedo and tach will work. You will have to take it to the dealer to have it done. The last time I had to do it, it cost me 70 dollars.
Feb 19, 2009 | 1999 Chrysler Town & Country
Tach on my 1995 eldorado is not correct
I have a complete dash for a 95 which should fix it. They are kind of a pain to replace, and the one I have has 91,000 on the odometer.
Dan Lemke
danl@mvn.net
Dec 14, 2008 | 1995 Cadillac Eldorado
ASUS Eee PC 1215P-MU17-RD Netbook Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
