Question about Refrigerators
Problem installing door gasket
I'm having trouble installing the refrigerator door gasket. It doesn't seem to seat into the track in several areas.
  • 700 Answers
Only do 2 sides at a time
Posted on Jan 24, 2009
  • Todd Born
    Todd Born Jan 24, 2009
    only do 2 sides at a time
I changed the gasket but it does not have a tight door close. it closes but it very light to the touch close
You have to form the door gasket. That means you have to use a heat gun (please don't use the heat gun if you are not familiar) to form the gasket to the seating surface. You can use a hair dryer which is less heat intensive. You got to be very careful, since too much heat is going to burn out your gasket and has to buy another one.
This is what you do.... Where the gasket is not seating properly to surface..... Those areas in the gasket you slightly heat up and let the rubber heat up and close the door. So the heated rubber will form into the shape of the seating surface.
Please check some YOU TUBE video's on this before doing. Otherwise you might burn out the gasket and will have to buy a new one again.
Oct 13, 2014 | Sub-Zero Refrigerators
How do I repair the gasket on my LG refrigerator door?
Both door gaskets are torn at the top, doors not closing. Where can I get new gaskets? How do I install them?
Thanks
Apr 11, 2010 | LG LRFC25750 Refrigerator French Door
I am getting water on my top shelves inside the refrigerator and don't know why. Nothing seems to be leaking. I cleared the area in the freezer to ensure proper circulation. That didn't seem to help. Would...
Check for a door gasket leak. If you put a single sheet of paper between the gasket and door it should stay in place without any assistance when the door is closed. Use a strip about 3 x 3 inches and work your way around the gasket.
Good Luck,
Gil
Mar 01, 2010 | Refrigerators
Trouble installing freezer track
Hi
Thanks for using FixYa. Please tell me if you want to replace the door gasket, or the Run screws back up against the metal holding strip snugly, not fully tight. Go to the bottom and do the bottom half. By doing the top half first and tightening, then doing the bottom half, you will minimize any warping of the door. If there is warping of the door, we have not yet fully tightened the screws. so you can realign the door easily and then tighten the screws. Check the alignment of the door and be sure the gasket is sealing properly before fully tightening the screws.
Also see these pictures for details--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks Rylee
Sep 18, 2009 | Kenmore Refrigerators
GE model PSC23SGRC SS refrigerator freezer door disassembly
Access from front of freezer door. Trim is just pushed into friction holders. Selector area snaps in. Phillip screws under that removes ice shoot.
Sep 16, 2009 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Uline Icemaker has dammaged gasket door
no, you will need to replace the gasket. U-line gasket is easy to install. You can visit their website and under customer service you will see parts locator. The gasket just pulls out of the track and the new one pushes back in the track. www.u-line.com
Mar 18, 2009 | U-Line Uline Origins Series...
On my GE Profile side by side the Fridge side the door will close and then pop open. The door has been making a clicking sound when opened. When it pops open it does not close again.
This can happen if the door gasket is not seating properly. If it is deformed you can correct this by pouring boiling water along the deformed area, then closing the door and keeping it closed while the gasket cools and sets. Please check first that it has been correctly installed, there are screws and a bracket behind the gasket. Another problem could be the alignment of the door. It is possible to adjust alignment on the hinges. One other thing is to raise the front "feet" so that the fridge slightly leans backwards.
Mar 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water leaking from the front-bottom of the freezer drawer
A faulty door gasket will definitely cause excessive condensate and running time. There is also a door heating system which is from heated refrigerant circulating around the area where door gasket meets cabinet. You should be able to feel a certain amount of warmth in this area. If not there could be condensation again from cold leaking out of the gasket and being formed on the actual cabinet.
Mar 03, 2009 | Sub-Zero 650 / O Bottom Freezer...
Condensation on refrigerator front btwn top freezer and refrigerator doors
I have the same problem with my frig in the basement. I get condensation and resulting mold on the top outer surface and related areas. This is from the surface being cold, with resulting outside moist air condensing on the cold surface. Best solution - spray/wipe the surface with a bleach and water solution, let it soak a few minutes, then wipe off with a rag. Add a drop of dishwasher soap to a mixture of roughly 4 parts water to one part bleach. Repeat if necessary. Do this as often as the problem seems to creep up again. Good luck!
Handyman in NJ
Oct 01, 2008 | Frigidaire FRT18B4A Top Freezer...
Concaved out freezer door
If concave is severe you will have to replace door. You can try to alleviate a slight gap by using a hairdryer and blowing hot air on the gasket in the area of the gap....move the dryer in up and down motions and the gasket will expand! Just make sure that there is no ice pressing against the door inner first! Oshie
Jun 18, 2007 | Maytag MTF2195AE Top Freezer Refrigerator
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
