Question about Vizio SV471XVT 47 in. LCD TV
Tested 68uf capacitor. Is 60uf accepable range? What is minimum?
Also looking fr suitable replacement capacitor. 68uf 450v BXA
  • Vizio Master
  • 933 Answers
It depends on the tolerance rating of the capacitor, but usually 8uf is withing tolerance
Posted on Jan 14, 2013
Range has a very dim display
I have a Jenn-Air double wall oven with a very dim display light. Replaced c3 capacitor 68uf 35w - with a 100uf 50w cost $1.60 closes size available at Radio Shack and works good as new. Requires soldering onto the circuit board. I price a replacement part for $276.00.
Mar 19, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
I recently bought a 100uf 450v capacitor to replace a 68uf 450v capacitor. Unfortunately there is no power being fed to the TV when plugged in. I was told by a local TV repairman that the uf rating...
The fault to your TV might not due to a defective capacitor. A higher capacitance valued capacitor, won't do nothing wrong. But as the capacitance value increases, the size of the capacitor will too increase. That's all. Check the fuse at the power supply regulator board. If it is found opened, make sure that something wrong with the power supply regulator board. Without rectifying the fault, never replace a fuse, as it will make things worse. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 17, 2013 | Akai LCT3201AD 32 in. LCD Television
450V 150UF WORK SAME AS 450V 68UF
no you could use a cap with the same UF rating and higher voltage without any issues but the uf rating must be the same.
Apr 06, 2013 | Televison & Video
I have aBostitch 2hp air compressor i like to get numbers off the starting capacitor mine got hot and i con;t read it . I call ther sev. and thay woud not give them to me .I whant to buy it localy .w
My compressor has a 60uf 330volt capacitor. With a bolt on the bottom, however, I have seen the same model compressor with other cap values. I suggest to try capacitor plus or minus in that range and read amp draw. Select the cap with best combination of start and run amp draw (lowest). Good luck
Apr 02, 2013 | Air Tools & Compressors
I have a floor fan with a bad capacitor. its a 1.5uF +-5% 450V. can i replace capacitor with a 33 uF 250 ~ 275 V capacitor ? or with some other one that i got ?
no, the capacity is way too high.... get a capacitor of at least 1,5 uF or up to max 4 uF if you happen to have one lying around
Oct 10, 2010 | Lakewood HV 18-c Floor / Box Fan
Sound but picture goes black after 10 min
is not the ballast. the problem is the control box
Nov 29, 2009 | Polaroid FLM-2632 Television
X20G-Naga III screen goes blank after 1-2 secs
FIXED!
Device : Spectra X20WG-Naga
Problem : monitor comes on then flickers then goes off
solution: Replace Capacitor C101 (150uf, 35V) and Fets U101 and U102 (4511GM)
Comments: This is a common problem with this monitor.
Oct 02, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sony SDM HS74P Screen Stays on for approx 15 seconds then shuts off but power light is still on?
PWI17LS285A, ACTUALLY THE CAPACITORS DOES NOT KEEP ENOUGH CHARGE TO KEEP THE LCD WORK...
so the big capicitor needs to replaced? 100µF 450V
Jul 07, 2008 | Sony SDM-HS74P/S 17" LCD Monitor
Jenn- Air SCE30600B
It's a bad capacitor on the clock/display board. The solution was posted elsewhere in FixYa. I had the same problem and was told I should replace the clock/display board, which would solve the problem, but costs about $150 plus labor. If you can desolder/solder small components on an electronic circuit board, you can fix this yourself. Mine was capacitor C3, originally a 68uF 35V component. I replaced it with a 68uF 63V as the closest one I could find at Jameco.com which was less than a $1. Lo and behold, my clock/display is back to normal! Saved a lot of money to fix it myself and I know it will happen again over time, so I know exactly what to do next time.
Jan 25, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Clock and oven control display
This solution worked great for me. I can't believe it was only a samll little cap. Thanks a bunch for this.it saved me a bunch.
Its real easy to do if you're handy.
IMPORTANT Turn circuit breaker OFF first
Open oven door
From underneath control panel remove 4 white screws with philips screw driver
this holds white cover strip
remove 4 hex head screws which will loosen the panel.
remove panel and support it's weight as many wires are connected.
remove 2 small plugs on board - you may need a small screw driver to pry away the locking mechanisms on the socket
Remove riggon type flat cable by squeezing black tabs on eand and lift up.
The board can now be removed by unclipping 2 of the clips holding the board while lifting up.
Take board to Radio Shack and ask for a suitable replacement for the C3 cap which is 35 volts and 68uf (microfarads). Remove and replace by careful soldering.
If traces lift off oard use a wire to jumper trace
ensure the cap goes in the same polarity there is negative signs on one side.
You can parallel caps to add uf together.
Voltage should be not less than 35volt slightly higher is OK.
Mar 25, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Vizio SV471XVT 47 in. LCD TV Logo
51 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
