Question about Epson - PowerLite S1+ Multimedia Projector
Overheat lite flashes as soon as you turn the projector on
I have changed the blub thinking it was bad but it is still flashing the fan is running is there an overheat switch that might be stuck/ Where is it?
Can I use a meter on it?
2 Suggested Answers
sherlyn c
  • 134 Answers
SOURCE: my epson Emp-53 projector lights up then shots off
Possible hardware failure, unfortunately.
Disconnect it from all the devices connected to it. Turn it on and off.
You can also log on to epson.com to check the user's manual http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=19626&prodoid=25951376.
If your unit is still under warranty please contact epson support to get a replacement.
If your unit is not under warranty anymore, please log on to epson.com. Go to the drivers and support page and click on help me find a service center to send your printer to an epson certified servicer near to your area.
Posted on May 03, 2009
Pj500 temp light blinking
It's for the fan only. Some time fan not rotate freely. It need to clean or replace.
Mar 31, 2014 | NEC VT460 Multimedia Projector
Sanyo pcl-xu50 flashing red power light when i turn on my projector the light goes green it powers up for about 20 seconds then the power light changes to a red flashing one for about 10 seconds then back...
Projectors shut off when they overheat. They overheat when air does not move through the projector cooling it. This happens when the fans are not working or air filters/vents are not working.
Check to see whether the fans are working. If they are working, open the cover and see whether air filters/vents are covered with dust. If so clean them.
Sep 26, 2011 | Office Equipment & Supplies
I was givin a sharp LCD projector XG-H400U and I am having a problem getting it to turn on. When I plug it in the lamp flashes then nothing! Is the lamp bad or is something else wrong?
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Aug 14, 2011 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
Light does not turn green lights come on fan
Try another blub and check to make sure the cover for the blub is on and the liltte switch is being triggerd by the cover to tell the unite the blub cover is on. Kinda like on a washing machine. Good Luck
Feb 18, 2010 | Mitsubishi SL1U Multimedia Projector
New bulb worked for a short trail run now wont light up. flashing green led colour wheel is turning on start up
when you changed the lamp, did you blow the dust out of the projector? if the screen on the side of the lamp is blocked (i.e. with dust), the lamp will blow quickly. if the projector were to overheat, by the fans not running or blocked vents, everything would shut down and the led would blink red.
Jan 01, 2010 | InFocus ScreenPlay 4805 Multimedia...
There is no air coming out of the back of the console and two red lights are flashing after it overheats we think the fan is broken because as soon as you put it on it switches off completely
2 flashing red lights means the unit powered off because of an overheat.
If there is no air moving out the back of the unit the fan is definitely shot. If you're still under warranty, send it back to Microsoft and let them fix it.
If not, buy a replacement fan for $5 and fix it yourself.
Oct 11, 2009 | Microsoft Xbox 360 Console
3m-X50 Lamp will not light up. Changed lamp.
you have a bad ballast. you'll have to replace it.
Aug 17, 2009 | 3M X50 Multimedia Projector
VT440K orange power flashing red status light, overheated.
Make sure all the air filter caps are all the way in and nothing is broken from it. that was my cause..i had the same problem
Apr 17, 2009 | NEC (50019497) Projector Lamp for VT440,...
Toshiba TDP SC25 projector
The manual says it might be because the power went out when it was on. Just a note here, as projectors age they become more sensitive to power outages. When not in use turn off completely if you can. They have an on/off button.
Otherwise not sure but think you may need to replace the fan. Try cleaning it first but gently.
Jan 31, 2009 | Toshiba TDP-SC25U Multimedia Projector
PJ-TX100
sounds like what 80% of the projectors on this page are seeing... bad power supply or lamp ballast.
Jun 07, 2008 | Hitachi PJTX100 Multimedia Projector
Epson - PowerLite S1+ Multimedia Projector Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
