Question about Symbol DS9808-SR00007NNWR - Motorola Ds9808Sr Bar Code Reader - Handheld Bar Code Reader - Wired - Imager
123scan - leanguage problem
We've got a serious problem in our company. We have just got the scanner, but it doesnt provide all type of letters. Let's have a look: we are scanning QR code that cotains Polish letters The problem is: we've got a QR code that contains: PLAC"O"WKA "Z"ABI"E"CICE Let's say "O" "Z" and "E" is a polish letters (I cannot post it here - fixYa doesnt allow me to) When we scan QR with scanner what we got is: PLACWKA ABCICE The scanner misses the polish letters. We've installed 123scan for Motorola scanners, and we scanned barcodes from manual, tried A LOT of options and nothing works for us. We cant work with this problem, and we are stuck since yesterday. Please help.
    Sergeant:
  • 378 Answers
Http://www.motorola.com/web/Business/Products/Bar%20Code%20Scanning/Bar%20Code%20Scanners/General%20Purpose%20Scanners/DS9808/_Documents/_Static%20files/SYMBOL%20DS9808%20Quick%20Start%20Guide.pdf
there are bar codes for the country you are in underneth programing bar codes 3rd one down in the 3rd colom
if this helps you out pleazse take a moment to rate this. anything else i could assist you with?
Posted on Jan 31, 2013
  • 25 Answers
SOURCE: barcode scanner won't scan.
You are likely experiencing power sag. If you are using a 15 foot usb cable try a 6 foot one instead. Even if that doesn't work it still could be power sag.
We sell an external power cable kit that replaces your USB cable with one that includes a power pack on the computer side.
The power pack provides the extra power you need.
It happens when it does becuase when the laser comes on more power is needed than available. The 5 VDC sags and the processor whigs out on you.
Posted on Jan 05, 2008
  • 25 Answers
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
SOURCE: LS2208 beeps to ignolage the scan but puts no information
I don't know if this applies to the LS22208.
Symbol Support FAQ says;
A slow continuous flashing LED on the LS9208 indicates that the LS9208 has been put into “programming mode” and is ready to scan programming bar codes. Once the LS9208 is correctly programmed, the LED should stop flashing and remain on, indicating that the scanner is ready for use.
A fast, continuously flashing LED on the LS9208 indicates an internal problem. When the LED is in this state, the LS9208 laser is also shut off for regulatory reasons.
We support these for some big retailers. When they call with that issue 99/100 it's reseat the cable from the base of the scanner (or the system if accesible), no re-programming).
Posted on Jan 16, 2009
thesuperdude
  • 97 Answers
SOURCE: Types of Barcode that can be scanned using Symbol MC9090
It can read all standard symbologies apart from PDF symbologies unless it is equipped with an imager scan engine.
Posted on Mar 26, 2009
  • 74 Answers
SOURCE: Symbol scanners (several models) not recognizing Code 39 Extended
The barcode must be a Code 39 barcode, not a Code 39 Extended or Full ASCII barcode. The Enable Code 39 Full ASCII must be scanned from the Symbologies section of the LS2208 Product Reference Guide (page 186 of 342). The Enable Function Key Mapping barcodes would have to be scanned if you are seeing something other than the tab happen when you scan into your application. In Word, for instance you will see the italics enable/disbled whenever the $I is encountered in the barcode.
As for the Covert to Code 39 Full ASCII- that is for Wand and Scanner emulation. The setting was having no effect because you were not connecting to either of these hosts.
Posted on Oct 26, 2009
Drive Reads & writes CDs but only reads DVDs. Attempts to write a DVD ejects the disc with a 'insert writable media' prompt. Device manager says driver 'up to date'. Am I using the...
my desktop computer will not write to a dvd, but will play a dvd
& my laptop will play a cd but will only write to a dvd
it's just the way the drives are,,I've tried different types of dvd also nothing helped
Sep 07, 2011 | Computers & Internet
I have installed HP PHoto and Imaging Softward for ScanJet 3570c 48 bit. Everytime I try to click on icons on the scanner, my computer shows an error message that there is a problem with connecting to the...
Does the same error occur if you launch a scan from the computer? What OS do you have? Vista only has a basic driver available and does not support the scanner buttons. (You can launch the scans from a number of options: third-party software, Windows Fax and Scan (new scan), Microsoft Paint (File > Import from Scanner or Camera > New Scan) and Windows Photo Gallery.)
If the error occurs when you launch the scan from the computer, try a new data cable and different USB ports. Try a direct USB connection if you use a hub. Then check your USB ports and the drivers for the USB. (For Windows, look in the Device Manager. Start > Control Panel > System > Device Manager (exact directions will depend on the OS).
The HP Photo and Imaging software requires you to set the default scan destinations in the software before you can use the buttons on the scanner (for those OS/driver versions that support the feature). Always open the software and scan from the computer to see what the defaults will be. Each version of HP's imaging software set up these buttons differently; the help option is useful. Try Scan > Scan settings to find where to set the color and black & white destinations.
I hope this helps. If you add a comment with your OS and whether the computer can launch a scan, I'll provide additional help if I can.
(who inherited a scanner when a USB hub failure aggravated the original user into buying a new scanner thinking it was a scanner problem.)
Aug 12, 2011 | HP ScanJet 3570C Flatbed Scanner
I have a 1995 mercury sable. I've it for 5 years with no transmission problems until June, 2011. I've noticed that when I drive short distances, the car drives great but if I do 12 miles on the...
The average life of a taurus or sable transaxles is a
surprising 65,000 miles,then you have to rebuild it
I only recently read that
In the early 1990's I owned a trans repair business
& over half my work was taurus & caravans
The rest was japanese
I can not see that being the original transaxle from
1995, but I wouldn't hold out hope of any type of
simple fix
There are non to my recall ,other than a cable on
the throttle body & I don't even know if they still exist
Aug 04, 2011 | 1995 Mercury Sable
Its does not have a cd-rom... the usb doesnt work why? is the usb 2.0 already?
More information is required to provide a thorough solution to your problem. Here is a general solution based on what you have said.
First, unplug the barcode scanner from your computer. Next, go to the website of the barcode scanner's manufacturer. If you do not know the website, search for the manufacturer on Google or another search engine.
Once you've found the manufacturer's website, look for a "support" section. Often times, you will likely be prompted to select the product you're seeking support for, either by clicking it from a list or typing in the product's item number.
After identifying your model, you should be taken to a support page specifically dedicated to your device. Look for a "downloads" or "drivers" link or section. Download any software provided on the site, making sure to select the one compatible with your operating system.
Launch the downloaded file and follow any on-screen instructions to Install the software. You may be prompted to restart your computer once installation completes. If so, go ahead and restart your computer. After you restart (or after the install completes, if no restart is required), plug in your barcode scanner. Your computer should recognize the new hardware (assuming it is "plug-n-play," as most USB devices are) and begin installing the drivers automatically.
If you locate and install the relevant software, but this solution still does not work, try using a different USB port.
If you cannot locate any installation software on the internet, you should contact the retailer from whom you bought the barcode scanner.
Jun 14, 2011 | Computers & Internet
I need to strip the last character from the barcode when scanned with a Symbol P370 scanner. Is there a procedure for that?
If the barcode is a UPC-A or UPC-E you would scan the Do Not Transmit UPC-A or UPC-E Check Digit barcode from the P370 Product Reference Guide.
If the barcode is something other than a UPC-A or UPC-E the last character can be stripped using Advanced Data Formatting which would require the use of 123Scan. You can download 123Scan from support.symbol.com.
The P370 is NOT supported by the newer 123Scan2.
Jan 21, 2011 | Symbol P370 Wireless Barcode Scanner
Barcode reader language
Concerning the Z issue you should select german keyboard from 123scan
Else you will have to program macro to substitute the caracters
Sep 03, 2009 | Symbol LS2208-7AZK0100S Handheld
Symbol P470 Enter key for field enter
Go to this page and follow the instructions in item #2. It will force the scanner to insert and "Enter" after every code is scanned. We use this option with most point of sale terminals and some inventory control programs to speed things up.
You will need to have you manual handy or download a copy from symbol to set the programming and you will have to print the 2 pages reffered to as you can't scan a screen... yet
Apr 24, 2009 | Computers & Internet
Scanner symbol ls3070-i100US
These are the only drivers i could find that fit your description. Hope it helps.
Simple COM Port Emulation USB driver version 1.8.5
1.8.5 DRIVER Simple COM Port Emulation is one of the USB (Universal Serial Bus) interface modes supported by Symbol scanner devices. In this mode, a Symbol scanner...
123Scan Scanner Configuration Utility v2.7
2.7 UTILITY SOFTWARE 123Scan is an easy-to-use PC based application that will help you program your Symbol Technologies bar code scanning products. Allows easy scanner...
OPOS Driver for Symbol Scanners v3.24
3.24 DRIVER The OPOS Driver for Symbol Scanners v3.24 provides the tools necessary for scanning bar codes. OPOS (OLE for Retail Point-Of-Sale) is a standard programming...
JavaPOS Driver for Symbol Scanners v1.9.1
1.9.1 DRIVER  This driver provides the Java objects necessary to connect a Symbol barcode scanner to a host system based on the Java POS specification (a part of the NRF...
Oct 06, 2008 | Computers & Internet
Part of code
Everything you need is came from your system mechanism. The only way to control your requirements is came from your programm coding.
at the start of the string sending must be filtered and rearrange from your program mechanism.
From what system you need to used barcode scanner? Are you using POS? I would like to recommend you to used visual basic 6.0 for better outcome.
Hope you like my solution please rate me Solved.
best regards,
Philip
Nov 02, 2007 | Symbol LS2208-1AZU0300S Handheld
123Scan File
P370 WILL NOT connect with your terminal or base, so forget about this intent and go for the goal which is loading your programming to your scanner. According to Motorola the work around is simple and faster than trying to resolve this.
Start with Reseting the scanner completly back to Defaults.
In the 123Scan, PRINT Barcodes and the rules ADF Rules of your programming.
Start scanning from
"Parameter Settings" until the last page barcode "Reset Scanner".
That is it. Problem solved.
You will need to do this for every new programming Rule.
Nov 18, 2006 | Symbol P370 Handheld
Symbol DS9808-SR00007NNWR - Motorola Ds9808Sr Bar Code Reader - Handheld Bar Code Reader - Wired - Imager Logo
221 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
