Question about Toshiba Canvio Plus 320 GB 2.0 Portable External E05A032CAU2XK (Raven Black) Hard Drive
My toshiba external hard drive won't be opened
It won't work and be opened. Every time I open My Computer it does not appear although it is plugged in. But when I look at the device manager, it appears as one of the disk drives. However, not in the Universal Serial Bus section.
  • Toshiba Master
  • 27,725 Answers
Some external storage devices work poorly or not at all when connected to a hub; try connecting the drive directly to a port on the computer. Also check if it's detected in "Disk Management". Here you can verify if the partition and format are correct for the Operating System. Check the Drive's status in Device manager. This will verify if the external drive has a drive letter designation. Check Partition and Format. Log in as Administrator account in windows or any other account with administrative privileges Insert your removable disk into the USB port. Click Start, right click on computer and select manage. Now, click Disk Management. Check whether drive letter for the device is present. Check the lower window to find whether the device is detected (such as Disk 1, Disk 2, etc). If the device is detected with a drive letter, verify that no other device is using that drive letter. If it is, change it to unused drive letter. Hope this helps.
Posted on Jan 14, 2013
  • 1019 Answers
SOURCE: Toshiba Hard Drive Crash
if the datas aleady deleted, then you have nothing to lose. Right ?
What you need is a 2.5 to 3.5 inch IDE ribbon cable connector.
this will enable you to put the drive into an IDE slot on the PC internal motherboard ( primary/secondary )
Unless it,s already 3.5"
boot the computer, see if it recognises the drive. And format it.
then you may be able, to re-fit back into the external casing, and use as an external again.
Mike @ compurepair.
Posted on Feb 25, 2008
  • 236 Answers
SOURCE: External Hard Drive stopped working
u might have to format it in safe mode or buy a new one, if you try it on some one elses comp. and it works it ur comp. but it is most of the time a software issue
Posted on May 08, 2010
virtualhost
  • 2185 Answers
SOURCE: I have a 320gb toshiba
This is because there is a connection problem between the external drive and the computer. If you have changed cables to no avail, you can open the casing of the external drive where you will find the hard disk inside. Unplug the two cables connected to the harddisk and replug it after a minute. Then try again. If it still does not work, then you need to buy just a usb enclosure and plug the harddisk there to be able to use it again.
Hope this helps. Thank you for using FixYa.
Posted on Jan 13, 2011
  • 6 Answers
SOURCE: I have a 500gb Toshiba
Check the ff:
1. sometimes it needs two sources of power (2 usb ports)
2. wait for some minutes, maybe it takes time to load
Posted on Jun 20, 2011
  • 22 Answers
SOURCE: I have a Toshiba 1Tb External Hard Disk. When I
If your using xp, right click on my computer, click manage and then disk manager and see if the drive is in thereright click and you can explore the drive, if t not in there go to device manager and see if the drive is in there if not try in different usbports on your machine if same issue try on a different PC if possible and if same issue drive is faulty, contact toshiba for replacement (although they take ages to replace a drive)
Posted on Sep 18, 2011
Toshiba external drive won't instal on Windows 7 Home Premium
Will the external drive work on another computer? Has the external drive been dropped, bumped, jarred? If it works on another computer, shut down the Win7 laptop, unplug, remove battery, remove the USB external plug, plug into AC, reboot, when it is finished, plug in USB.
Jan 13, 2013 | Computers & Internet
Computer won't recognize external usb hard drive
Format drive NTFS sounds like its corrupt, use mini partition wizard...
may also need 3TB Unlocker from manufacturer of Hdd
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
Toshiba l645 bootstrap
The Windows operating sustem appears to be corrupted and most like to get a working computer you need to restore it back to the factore default condition.
Before you attemp to do this and to back up data, remove the hard disk from the Toshiba and connect this hard disk to an USB hard drive adapter, then plug this adapter into the USB port of a working computer. This computer will see this as an external storage device. You can then open the various folders on this drive and back up your data on this computer or an USB memory stick.
To restore your Toshiba, insert the hard disk back into the Toshiba and follow these instructions..
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.http://www.fixya.com/support/r8248520-restore_toshiba_out_box_condition
Mar 05, 2012 | Toshiba Satellite L645DS4037 Notebook PC
I have a Toshiba 1Tb External Hard Disk. When I plug in my drive, the drive gets detected in the systems tray but the drive does not appear in 'My Computer'. Please provide a remedy for my
Sep 18, 2011 | Toshiba 10TB USB 30 Desktop External 1 TB...
I purchased a Toshiba Canvio 3.0 500 GB portable hard drive, and plugged it into my MacBook with Mac OS X Tiger. The icon for Toshiba EXT came up on the desktop but wouldn't do anything. The box came...
1 . Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
2. Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
3.
Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
4. Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs.
  • 5. Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
  • 6. Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
    Aug 30, 2011 | Toshiba Canvio 500 GB USB 20 Portable...
    Hi! I've got a Toshiba Satellite L300 and it won't boot anymore. I get past the initial toshiba-screen where I can press F2 and F12 but afterwards there's just a black screen with a little...
    You can retrieve your data by removing the hard drive and connecting it to an USB hard drive adapter then plug it into the USB port of a working computer. This computer will see this as an external storage device, you can then open the various folders and files to back up your data.
    You can then return the hard drive back into the Toshiba then format the hard drive and reinstall Windows to get your Toshiba working again.
    You can download thedevice drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
    Jul 05, 2011 | Toshiba Satellite Pro L300 Notebook
    Reformatting toshiba portable hard drive for mac, since the one i have says for windows pc
    Note: I'm assuming you have a working mac; if you don't, then post back to this solution with that information.
    1. Connect the external hard drive to your mac.
    2. Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
    3. Select the external hard drive that needs to be formatted on the left.
    4. Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
    5. Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X.
    6. Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
    7. Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
    Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
    Apr 28, 2011 | Computers & Internet
    I have a 320gb toshiba external hard drive, i've been using it around 3 years without any trouble. A few days ago i lost the cable connecting it to the PC. I bought a few cables but no use. Doesn't...
    Jan 13, 2011 | Toshiba 120GB USB 2.0 Portable External...
    I have just bought 2.5 inch toshiba external hard drive for my lap top and it is not working
    you've probably popped it smell the connections for the smell of burning,check the fuse in the plug should be 5Amp,
    there easy to blow, if you don't get the USB plugged in the right way first time it sparks & shorts the ports out on the computer & if you've got the hard drive plugged in & switched on before you plug the USB in then it shorts the drive out as well.
    take it back to the shop & tell them two replace it.if they won't then open the unit & take out the drive because that will still work & sell it on e-bay or put it in a desktop pc.
    Sep 27, 2010 | Toshiba 120GB USB 2.0 Portable External...
    May 08, 2010 | Toshiba 120GB USB 2.0 Portable External...
    Toshiba Canvio Plus 320 GB 2.0 Portable External E05A032CAU2XK (Raven Black) Hard Drive Logo
    178 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
